Bill Davies 2 | 11/10/2017 23:34:59 |
357 forum posts 13 photos | A friend sent a picture for me to identify. It's like a lathe dog but the wrong way round. The thread is on the vee side. It has a countersunk hole on the other side. I guess it's some kind of clamp, but I've never seen anything like it. |
Neil Wyatt | 11/10/2017 23:54:38 |
![]() 19226 forum posts 749 photos 86 articles | One of these : |
Neil Wyatt | 11/10/2017 23:56:10 |
![]() 19226 forum posts 749 photos 86 articles | Actually it may be a nut splitter, a hardened wedge fits in the square hole. |
"Bill Hancox" | 12/10/2017 02:19:11 |
![]() 257 forum posts 77 photos | Appears to be a pipe hanger |
Simon Williams 3 | 12/10/2017 08:12:26 |
728 forum posts 90 photos | If it were stainless, it would possibly be a clamp off the regulator for a diving bottle. But it looks like its cast or malleable iron. So the tensile strength isn't huge. Still, my bet's on something along those lines |
john carruthers | 12/10/2017 08:31:11 |
![]() 617 forum posts 180 photos | Nutcracker? |
Bill Davies 2 | 12/10/2017 09:22:17 |
357 forum posts 13 photos | I like the nutcracker! and Neil's nut splitter. I had wondered if it was half of an old scaffolding connector, the type to allow for angle between the tube, but it's nothing like the 'modern' split pattern. Bill's hanger and Simon's clamp of a pressurised bottle seem plausible, too. It looks like a double start thread, if it is, then faster locking would be more important than applied force.
Bill Davies 2 | 12/10/2017 09:26:04 |
357 forum posts 13 photos | I note, too, that the range of travel of the thread looks like the entire space inside the ring. So perhaps not a dedicated item. I discounted a puller due to the radius opposing the thread and the hole, and various other reasons. |
JasonB | 12/10/2017 09:59:23 |
![]() 25215 forum posts 3105 photos 1 articles | Is the small hole theaded or plain? |
Colin Heseltine | 12/10/2017 16:37:56 |
744 forum posts 375 photos | As a diver there is no way on this earth I would have that as a clamp on a first stage and I'm certain that is not its function. I would go for a nut cracker. Again it is not strong enough to use as a splitter for metal nuts. Colin |
Rik Shaw | 12/10/2017 17:25:34 |
![]() 1494 forum posts 403 photos | Scarfing clamp for gluing rods together to make gunwales for small boats and fishing net mouths - for instance. Rik |
Mike | 12/10/2017 18:00:15 |
![]() 713 forum posts 6 photos | Another vote for a nutcracker. Google for "screw-type nutcracker" and you will find many variations on this theme. Or build your own with instruction at http://www.instructables.com/id/Over-Engineered-Nutcracker/ |
Alan Vos | 12/10/2017 18:54:38 |
162 forum posts 7 photos | Looks like a multi-start thread, If so, speed of operation was a consideration. |
Bill Davies 2 | 12/10/2017 19:00:17 |
357 forum posts 13 photos | I took Mike's advice to Google and found some which similar, although nothing identical. There would appear to be a pad or (on some designs) a handle that makes use of the hole. My friend says he's been told it's a pecan nut cracker. I've never cracked those, so I don't know why it would be specific for this nut. Many thanks, all. |
Tony Dimnick | 14/10/2017 04:18:53 |
15 forum posts | Posted by Neil Wyatt on 11/10/2017 23:56:10:
Actually it may be a nut splitter, a hardened wedge fits in the square hole. I guess so too. |
MW | 14/10/2017 07:12:04 |
![]() 2052 forum posts 56 photos | It looks a bit too big to be a nutcracker to me. You could almost pass a coconut through that opening |
not done it yet | 14/10/2017 07:28:17 |
7517 forum posts 20 photos | I think it may be a controlled cushing device, such as using a couple plates,with grain between, for preparation of samples for early moisture testers, or for compacting those ground samples into a standard sized pellet for use in the testing instrument. Early machines were far better than the farmer collecting a few grains and biting them between his/teeth as a test for readiness for combine harvesting. |
Martin Connelly | 15/10/2017 09:25:14 |
![]() 2549 forum posts 235 photos | Maybe a parallel pin pusher for removing or refitting them without banging a parallel pin punch against the pin. Martin C |
