Drilling holes using drill and mills
petro1head20/09/2017 15:31:16
984 forum posts
207 photos
I am not sure why this is but here we go
I have notices when I use a mill to drill a partial hole and then chage to a drill the drill is off ctr and vica vera.
This photos shows a puch mark done with the drill chuck and then the mill chuck and as you can see the mark is in the same position.
However I then drilled a 6mm hole, remove the chuck and fitted the collet chuck and as you can see in the second photo there is a step.  The table has not been moved
Any idea why?
Edited By petro1head on 20/09/2017 15:31:36
Edited By petro1head on 20/09/2017 15:32:19
Nick_G20/09/2017 15:36:12
1808 forum posts
744 photos
What mill is it and has it got a round or a dovetail column.?
Nick
Frances IoM20/09/2017 15:41:43
1395 forum posts
30 photos
on an SX-1 mill if you forget to lock head you get a small error as head can move on dovetail
petro1head20/09/2017 15:44:19
984 forum posts
207 photos
Its a warco WM18 with dovetail
HOWARDT20/09/2017 15:59:09
1081 forum posts
39 photos
Are you saying you are re-drilling the same hole, not starting a new one at a new centre punch position. If you a trying to use a two flute drill in an already partially drilled hole then put the drill into the hole before running the spindle. This will stop the drill from snatching in the hole and pulling of centre. There was a discussion recently regarding trying to enlarge an already drilled hole, in that case you need to use a drill with more than two flutes. Using more flutes centres the drill on the already performed hole.
Tony Pratt 120/09/2017 16:05:34
2319 forum posts
13 photos
Is the spindle at 90 degrees to the table? If not you will get the error you describe [if I understand you correctly].
Tony
Nick_G20/09/2017 16:17:37
1808 forum posts
744 photos
Are you locking X and Y.?
Nick
JasonB20/09/2017 16:30:21
As Tony says it sounds like a tram issue, as the head/quill will be nearer the work when using a short milling cutter rather than a longer drill the error will show the result you are getting
SillyOldDuffer20/09/2017 16:32:52
10668 forum posts
2415 photos
Perhaps the rough button thingy isn't being held firmly on the mill's table. You get odd shaped holes if work moves whilst it's being cut. (You can guess how I know...)
Andrew Tinsley20/09/2017 16:40:56
1817 forum posts
Maybe the drill has been sharpened with unequal length cutting edges?
Andrew,
petro1head20/09/2017 16:47:36
984 forum posts
207 photos
Cheers for the replies
X and Y are locked and so it the head, just use the quill.
Tony and Jason, good point, I have a ground shaft that I can use to check the head is 90deg to the table.
Will report back
fishy-steve20/09/2017 16:50:02
122 forum posts
30 photos
Have you checked if it's trammed ? Although it would have to be out by a mile to see what your getting.
Steve.
fishy-steve20/09/2017 16:51:17
122 forum posts
30 photos
Wow. You lot are quick. laugh
SillyOldDuffer20/09/2017 17:00:07
10668 forum posts
2415 photos
Hi Petro1head,
An easy way to check the tram is with a DTI at right angles to the chuck as shown in the picture.
By swinging the DTI round in a circle on the table top, you can measure how far the head and table are out, right/left and forward/back. The DTI being on an arm means you can see tilt of 0.01mm over a distance of 200mm quite easily.
petro1head20/09/2017 17:23:59
984 forum posts
207 photos
You guys were right, I am such a duffer
Not as technical as a dial guage
Before
After
Thanks guys
