O RING
USING A O RING
Phillip weaver16/08/2017 18:03:01
4 forum posts
WHEN USING A O RING THAT'S 1"X3/4X1/8 HOW DEEP DO YOU MAKE THE RECESS
Edited By JasonB on 16/08/2017 19:48:03
Dave Halford16/08/2017 20:20:35
2536 forum posts
24 photos
You type o ring clearance into google
smiley
mechman4816/08/2017 20:22:13
2947 forum posts
468 photos
Dave beat me to it !
​Geo.
JasonB16/08/2017 20:35:19
Problem is you will probably get an industrial standard from google, for model work the sizes are different so that teh ring is compressed less which makes for an engine that turns over more easily.
Assuming you want the groove in a piston then groove depth is 0.132" and width 0.166" wide.
SAE would be 0.124" deep and 0.188" wide which makes things a lot tighter but is meant for pressures upto 1500psi
Edited By JasonB on 16/08/2017 20:37:59
HOWARDT16/08/2017 20:48:19
1081 forum posts
39 photos
What is the o ring being used for, is it static or dynamic, pressure, operating medium.
vintagengineer16/08/2017 20:56:53
469 forum posts
6 photos
Also you need to keep clearances as tight as possible to stop the O ring being extruded into the gap. If it is being used for high pressure you use back up rings.
Russell Eberhardt16/08/2017 21:01:09
2785 forum posts
87 photos
It's well worth getting a copy of Tubal Cain's Model Engineers Handbook. That gives the appropriate figures for various sizes of O-rings and the ideal profile of the groove for various applications. Lots more useful information as well.
Russell
Phillip weaver17/08/2017 10:39:28
4 forum posts
Thanks All for your replies. I am making a model of VICTORIA Steam engine and its my first go A real ham HI HI its coming along nicely building from scratch no casts that way I will learn a lot more . And Russell I will get a copy of Model Engineers Handbook
JasonB17/08/2017 11:12:48
In that case the sizes I gave will do just fine as I took them out of said book.
