Key types - any advantages?
Ignatz10/08/2017 08:14:47
173 forum posts
102 photos
I've got to make a replacement countershaft for my ML10 lathe. This shaft has Woodruff keys at either end for the drive pulleys.
I see that the cost for the correct Woodruff key milling cutter is pretty steep... most especially when considering that this is essentially for one-time use.
Would an alternate straight, 'feather key' work just as well in this situation?  This is something that I could mill out much more easily with the tooling at hand.  (see illustration)
Edited By Ignatz on 10/08/2017 08:15:44
roy entwistle10/08/2017 08:25:24
1716 forum posts
A feather key would be ok if fitted correctly
After all it's what youv'e got on the motor
Edited By roy entwistle on 10/08/2017 08:43:09
Brian Wood10/08/2017 09:30:48
2742 forum posts
39 photos
John Stephenson replaces them at every opportunity and any job that comes to him has straight keys put in as a matter of course.
​That would seem to be a good endorsement by someone with long practical experience.
​Brian
vintagengineer10/08/2017 09:43:25
469 forum posts
6 photos
I assume woodruff keys are fitted as it easier to manufacture for mass production work, but tend to be weaker as they take out more material than needed.
I prefer straight gears as you only need to remove a minimal amount of material from the shaft.
JasonB10/08/2017 10:21:41
Woodruff keys are often used on tapered shafts where it is easier to machine than setting the work at and angle to mill the slot and the taper takes the load and key just acts to locate the item on the shaft such a timing gears/pulleys.
ega10/08/2017 11:00:56
2805 forum posts
219 photos
Posted by JasonB on 10/08/2017 10:21:41:
I seem to remember that the Austin Seven had this arrangement on its halfshafts.
Either type of key seat can be machined on a vertical mill but the straight key way would perhaps be more difficult on a horizontal mill.
Woodruff keys and cutters are readily made in the amateur workshop.
I assume that model makers would aim for authenticity of key type.
PS Excellent illustration, Ignatz!
Edited By ega on 10/08/2017 11:02:24
Nick_G10/08/2017 11:04:49
1808 forum posts
744 photos
Motorbike flywheels and timing gears often have such as they may house the ignition sensor magnets. Quite common for such an engine to also have a 'wasted spark' in the cycle.
Nick
larry Phelan10/08/2017 11:09:32
544 forum posts
17 photos
Can,t see how it would make much difference,the key is not going to fly out anyway once the pulley is locked in place,is it?
I suspect Woodruff keys are just easier and cheaper to make/
Speedy Builder510/08/2017 11:42:00
2878 forum posts
248 photos
problem with Woodruff is that they weaken the shaft more than a flat key, but reduce the possibility of stress fractures caused at the ends of the flat keyway slots. Another problem with Woodruf is that they can 'rock' whilst the pulley is fitted to the shaft which can be a nuisance during assembly.
JasonB10/08/2017 11:52:34
If they are being used as I mentioned above purely to locate the part on the shaft and not to transmit any power then they can be far smaller than a straight key that has to transmit the load so may not take as much out the shaft as the straight key.
Suppose it all comes down to using the right thing for the job in hand and designing the shaft to allow for what is cut away
Andrew Tinsley10/08/2017 12:42:14
1817 forum posts
I lost the Woodruff key for my electric motor. In desperation I just bolted up the pulley wheel very tightly and ran the machine sans Woodruff key. It stayed that way for weeks until I sourced the correct Woodruff key. On disassembling, there wasn't any sign of the pulley wheel having spun on the shaft!
So I reckon your solution would do fine. Before people berate me for being idiotic. I was desperate to get a job done and it was worth sucking and seeing.
Andrew.
Ignatz10/08/2017 14:53:13
173 forum posts
102 photos
Thanks, everyone, for the feedback. I think that i can safely alter the design of the replacement countershaft to use those captive straight 'feather' keys. There is a tiny bit more fuss-n-bother making multiple passes with a small slotting end mill, but the end result should be far easier on the pocketbook. wink
PS  Illustration prepared using Blender 3D software with a few adjustments in the Photoshop.
Edited By Ignatz on 10/08/2017 14:56:26
Bob Rodgerson10/08/2017 17:43:28
612 forum posts
174 photos
Woodruff cutters are easily made by grinding down an end mill to the correct thickness. I used to use cutters that had maybe chipped a tooth but who,s flanks were still in good condition. They work well.
Howard Lewis10/08/2017 18:36:45
7227 forum posts
21 photos
If a key is needed PURELY for alignment, a short stud set into the shaft can be used. (Example: Stanadyne Fuel Injection Pumps) but ONLY for alignment; precious little use for transmitting torque.
Neil Wyatt10/08/2017 20:16:56
19226 forum posts
749 photos
86 articles
Posted by Howard Lewis on 10/08/2017 18:36:45:
That's what I did for my dividing attachment
Money spent on a woodruff cutter is not necessarily wasted, they have other uses, such as cutting horizontal slots using a vertical mill.
