Chuck key missing?
Nige16/07/2017 07:42:14
370 forum posts
65 photos
As a novice I was particularly pleased to see the front of the latest MEW, 257. The advertised article "Making a Chuck Key" was exactly what I needed and could probably cope with, a true 'article for beginners'. My joy has turned to sadness as I cannot find said article anywhere 😢
John P16/07/2017 09:03:32
451 forum posts
268 photos
Hi Nige,
Keep digging you will find some more of these if you look,i have to say i was somewhat confused by the caption
on the photo bottom right on page 55 ,see top left page 54.
Neil Wyatt16/07/2017 10:14:52
19226 forum posts
749 photos
86 articles
We had to hold it and Tom Senior over to the next issue, but the cover didn't get updated - sorry!
John C16/07/2017 10:19:16
273 forum posts
95 photos
A 'Senior Moment'......?
I'll get me coat.
Edited By John C on 16/07/2017 10:19:46
SillyOldDuffer16/07/2017 10:36:31
10668 forum posts
2415 photos
Hi Nige,
Make two chuck keys for your 4-jaw. Being able to slacken and tighten opposing jaws at the same time makes it much easier to centre work.
By the way your 0.01mm run-out was good for a first effort. Took me a few sessions to get the hang of it and I'm still slow.
Bazyle16/07/2017 11:16:36
6956 forum posts
229 photos
If making a key make it + shaped rather than T shape. The other end can be used for another chuck or for a hex for the tool holder screws.
Hopper16/07/2017 12:55:12
7881 forum posts
397 photos
Chuck keys are like that: they disappear as soon as nobody is holding them down. I even painted mine bright red and made a special clip for it to hang from right there on the lathe where I need it - and the b!@#$%y thing still can never be found.
Harry Wilkes16/07/2017 14:55:22
1613 forum posts
72 photos
Posted by Hopper on 16/07/2017 12:55:12:
Must be a cousin to my pillar drill chuck key, now my old Bosch pistol drill chuck key never run's away maybe because it's so old wink
H
Nige16/07/2017 14:59:03
370 forum posts
65 photos
Dave: Thanks, that was exactly why I was happy to see that making a chuck key was to be found inside the latest issue. I watched a great YouTube video on using the 4 jaw which used two chuck keys. I can manage the simple challenge of making a chuck key using hand tools though 😀
Nige
Howard Lewis18/07/2017 12:35:06
7227 forum posts
21 photos
Shouldn't be too difficult. In the crudest from, take the bar intended for the Key, diameter such that it can be filed down to the size of the square (or hexagon - see later) , and cross drill for the metal intended for the Handle.
File, ideally mill, to the size of square that fits the socket for the chuck jaw, (round the corners a little before trying in the socket). Once the business end is the required fit,,preferably drill and tap the end for the Handle, to take a securing grubscrew. Fit the handle , tighten grubscrew, and you are in business.
The nice way to do it is to mill the square, if possible.
For a chuck with hexagon sockets, find a piece of hexagon bar of the right size, or using the flats as a guide, file down each flat in turn, to fit the socket, and put the Handle on in the same way.
Two Keys can be a big help in centering the work in a four jaw.
SillyOldDuffer18/07/2017 12:52:13
10668 forum posts
2415 photos
Posted by Nige on 16/07/2017 14:59:03:
Nige
I disagree Nige. Hand tools are a complete waste of your valuable time.
The need to make a pair of chuck keys is the perfect justification for buying a milling machine, rotary table, collet chuck, collet set, clamps, machine vice, DTI, DRO and cutters. Go on, you know you want to...
smiley
MW18/07/2017 13:54:01
2052 forum posts
56 photos
Posted by SillyOldDuffer on 18/07/2017 12:52:13:
Nige
smiley
Indeed, Keeping the commercial interests of the hobby alive means always buying more! stay well away from those simple curmudgeons your grandfather may have used and stick to modern technology. That way we can make £3000 out of you rather than £30.
Michael W
Neil Wyatt18/07/2017 14:13:48
19226 forum posts
749 photos
86 articles
Nige
smiley
Damn, my plastic 3D printed chuck key has snapped! I had better invest in a laser sintering version
Gordon W18/07/2017 16:41:39
2011 forum posts
Just find a bit of already square bar of the right size aprox. Door handle bar is ok for a lot of smaller chucks. Does not need anything exotic, not a lot of force needed.
Nige18/07/2017 17:26:27
370 forum posts
65 photos
Get thee behind me Satan, or in this case Dave and Micheal W. I would spend the money if I had it but I don't so I can't I'm not even going to think about asking the "What Mill should I buy" question
larry Phelan18/07/2017 17:41:50
544 forum posts
17 photos
My drill chuck key is fitted to a length of chain fixed to the machine itself,so no more hunting around for it. The mill tool for knocking out the morse taper sleeves is also on a chain,always to hand. Lathe keys clipped to the outside of the gear housing.
Now regarding centering work in the 4 jaw chuck,I came across a photo on the cover of a book by no less a man than Tubal Cain. He admits himself that when he saw the picture,he went into shock,thinking of all the time he had wasted over the years ! I tried it,and Bingo! ,it works ! Simple and effective.
SillyOldDuffer18/07/2017 18:14:54
10668 forum posts
2415 photos
Posted by Nige on 18/07/2017 17:26:27:
A misprint surely! That should be 'Santa', not 'Satan'.
You deserve a treat, the more expensive the better. I have it on good authority that Neil's already ordered a Laser Sintering 3D printer. You can trust us, honest: I'm a doctor.
Mills available in all good toyshops, easy terms available; what could possibly go wrong?
Edited By SillyOldDuffer on 18/07/2017 18:15:20
