When is MT2 not an MT2 arbor
Andy Carruthers15/07/2017 18:22:09
317 forum posts
23 photos
Sooo, my mini mill says the arbor is MT#2 and I bought an MT2 22mm arbor but doesn't match - the quill(?) is far too long and has threaded end http://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Slitting-Saws-and-Arbors/MT2-Stub-Milling-Arbor-22mm
I am probably having a senior moment - can anyone offer advice please?
Plenty more dumb questions where this one came from
Vic15/07/2017 18:31:18
3453 forum posts
23 photos
The link shows an arbor for a slitting saw, is that what you wanted? It's threaded for a draw bar to stop it falling out.
JasonB15/07/2017 18:31:57
Should fit an MT2 equiped machine without a problem.
What make Mini-mill do you have and does other MT2 tooling fit OK?
Edited By JasonB on 15/07/2017 18:32:15
Robbo15/07/2017 19:23:59
1504 forum posts
142 photos
I have had a couple of these from Arc. The MT2 taper is the usual length, about 68mm. Do you have a captive draw bar in your mill which you need to engage as you insert the taper? If so is it 10mm?
Tim Stevens15/07/2017 20:22:01
1779 forum posts
If not 10mm or M10, the drawbar might be 3/8" Whitworth. Looks much the same (confusingly) but it is an imperial thread, and slightly smaller diameter. It was intended for use with inch-versions of a mill. Therefore, if your mill is calibrated in inches and thousandths, rather than millimeters and hundredths, this is likely to be the thread on your draw-bar. But it could be that you have no draw-bar at all (which is why details of the model would help us to help you0.
It could be, of course, that there is something else up the MT2 hole already ...
Regards, Tim
Andy Carruthers15/07/2017 20:43:57
317 forum posts
23 photos
Funny you should say that Tim, and being a complete novice it is more than probable I have made an error
​I don't have a manual for the mill nor have I found a manufacturers label otherwise I would RTFM which for other devices I have found very helpful in the past...
Tim Stevens15/07/2017 20:56:17
1779 forum posts
As you are a novice, you may find it helpful (in other cases) to know that there are two styles of MT2 taper fitting. Both have the same tapered body. One has an internal thread (M10 or 3/8W, see above) but the other has an extension called a 'tang' which forms a tab at the small end of the taper. This is designed for use in column drills etc, (and not usually for mills or lathes in hobby sizes) where the tang fits in an interrnal slot and ensures a firm positive drive. There is also a slot towards the small end into which a tapered tool can be driven to remove a stuck tapered tool.
Hope this helps
Tim
Bazyle15/07/2017 20:57:20
6956 forum posts
229 photos
We may be able to help identify the mill from a photo. There are a few manufacturers that deliberately made non standard sizes to lock the customer to them for parts. It can be quite difficult to accurately identify a Morse taper that has been made longer or shorter than standard as just measuring the diameter doesn't tell the whole story. This can also apply to lathes.
Andy Carruthers15/07/2017 21:11:33
317 forum posts
23 photos
Thanks all, I'll upload a photo in the morning
Andy Carruthers16/07/2017 07:16:46
317 forum posts
23 photos
@Vic - yes, I did intend to buy the slitting saw version - I bought the blades at the same time
Here's the puppy - looks like there is an MT2 already fitted? which begs the question of how to remove it please - and yes, an idiots guide is recommended The good news is that I am a quick learner so it's not forever though it may feel like it for a while
Edited By Andy Carruthers on 16/07/2017 07:20:37
JasonB16/07/2017 08:04:05
On the top of the mill head is a black cylinder about the size of an old 35mm film container with a red/yellow sticker on it
Pull that off and it will reveal teh hexagonal end of teh brawbar.
Hold the collet chuck that is in the spindle with one hand and use a spanner to loosen the drawbar about 1/2 a turn, may need a spanner on the collet flats if it is tight
Take a copper hammer or put something ontop of teh drawbar nut and give it a blow with the hammer which will break the grip of the taper.
You can now fully undo the drawbar while holding the collet so it won't drop and out it will come.
To fit new arbor push it up into teh spindle so it just grips and then screw in the drawbar and tighten.
Edited By JasonB on 16/07/2017 08:05:43
Bazyle16/07/2017 08:59:34
6956 forum posts
229 photos
Looks like you got a 'free' collet chuck with it which is an essential tool too. When you get it off take a couple of photos of the collet that is in it if there is one placed on a rule or graph paper for dimensions and we can try to identify the collet size you need.
Frances IoM16/07/2017 09:00:46
1395 forum posts
30 photos
looks like a Sieg SX1L as supplied by Arc Euro (tho they state the long table SX1L is exclusive to them - their 'house' colour is red) but later fitted with the stepper motors to drive the head and table using what looks like ball races (rather expensive mod which if fitted to the table requires John Stevenson style 'butchery' -as described in a thread on this forum some time ago - may be it got a repaint at the same time
Edited By Frances IoM on 16/07/2017 09:01:41
Edited By Frances IoM on 16/07/2017 09:05:32
Michael Horner16/07/2017 09:26:10
229 forum posts
63 photos
Hi Andy
Don't overtighten the draw bar, I have heard of tales of woe when some MT's won't release.
I think it is finger tight plus 1/4 of a turn. I use R8 on my mill so not over familiar with the exact torque.
Cheers Michael.
John C16/07/2017 09:42:15
273 forum posts
95 photos
Andy,
Check your message box - envelope icon and 'INBOX' on the very top line of the page.
Rgds,
Vic16/07/2017 10:33:48
3453 forum posts
23 photos
Just a thought but don't some of these small mills have a self extracting drawbar? If so hitting it with a hammer may be a bad idea.
Frances IoM16/07/2017 11:26:56
1395 forum posts
30 photos
the Sieg SX1 needs a light hammer blow (or moderate if you entered the arbour when warm and the machine has subsequently cooled down - don't leave machine set up over night if you wish to change tooling in morning) - make a copper headed small mallet to deliver blow
check the thread as both 10mm + 3/8 whit draw bars exist (my machine came with both) use of the wrong one can wreck an arbour - have also come across a home made UNC threaded arbour not sure if this means that there are commercial UNC arbours available
Edited By Frances IoM on 16/07/2017 11:31:20
Hopper16/07/2017 13:05:51
7881 forum posts
397 photos
Sooooo...... if you haven't yet managed to take the original collet chuck out of the mill spindle, how do you know the new slitting saw arbor will not fit???
DMR16/07/2017 16:06:18
136 forum posts
14 photos
Andy,
Its a fairly generic pattern of its day but the colour says its a Chester UK badged machine they called a Cobra Mill from about 10-12 years ago. I've probably got a spec somewhere. The stepper motors are extras and it seems to have a few standard bits missing or detached.
It is MT2 and it will be an all metric machine in its fittings. The height scale says its an all metric machine on its slideways too.
Edited By DMR on 16/07/2017 16:11:35
Frances IoM16/07/2017 17:00:08
1395 forum posts
30 photos
it looks very heavily modified - the quill control seems to have gone with I assume fine control available via the ball race controlling the head - some extra head room seems to have been added by riser blocks - the quill lock screw has been replaced by a more convenient handle made possible by loss of the quill arm - suspect makes drilling more of a tedious affair tho.
using a ER25 collet avoids some of the time wasting head movements but a collection of stub drills will be found very useful!
The early drives had a somewhat of a reputation for burn out if overloaded - possibly a later design of control board is used - the high-low speed control is also somewhat of a kludge there is a Graham Meek mod that seems to correct this (tho not sure where this is now published) - tramming the head is somewhat of a bind so avoid angling the head unless totally necessary
Edited By Frances IoM on 16/07/2017 17:02:14
