Bench top mill
sean logie03/07/2017 07:35:59
608 forum posts
7 photos
The title should read bench top mill?. I've decided I need to get myself a mill . Space is tight so a decent bench top would have to be my choice ,budget is tight absolute max of ?750 what would you recommend guys . The heaviest usage would be to make some extra QC tool holders .Been looking at a used Sieg x3 with loads of tooling.
Sean
Edited By sean logie on 03/07/2017 07:40:24
Edited By sean logie on 03/07/2017 07:40:54
Edited By sean logie on 03/07/2017 07:42:03
not done it yet03/07/2017 08:52:15
7517 forum posts
20 photos
Weelll, I would say a good Centec. But I would - as I like mine.
Both horizontal and vertical options in one package. Mind you it will need to be a robust bench.
Riser blocks are available on occasion, power feed is an option - good but expensive - and no silly DC motor and electronic motor control boards to go wrong.
sean logie03/07/2017 10:05:17
608 forum posts
7 photos
I've been keeping an eye on a centec mill but it's only in horizontal configuration so that would mean I'd have to source a vertical head for it which would prove costly . Building a stout bench not a problem .
Sean
not done it yet03/07/2017 11:22:13
7517 forum posts
20 photos
Vertical heads on epay often go well over 300 squid and have made over 600 - rather more than the rest of the machine!
2 and 2A are cheaper and would definitly benefit from a riser block. 2B versions are more popular and fewer on offer.
JasonB03/07/2017 11:31:14
If the X3 has been looked after and there is a lot of tooling it does not sound a bad buy.
My X3 is going strong after just over 10years use, no electrical issues with the DC motor just a couple of £5 belts in that time and it gets used a lot and also for quite large items as they have a bigger work envelope than a Centec. X3 is also plug and play, no Inverter to eat into the overall budget to get the 3-phase machine to work
Edited By JasonB on 03/07/2017 11:44:03
sean logie03/07/2017 13:01:03
608 forum posts
7 photos
Hi Jason , the x3 has a lot of tooling . There are some going for 600 and no tooling.
Sean
Robbo03/07/2017 13:40:57
1504 forum posts
142 photos
Sean
I have only had one of the smaller Sieg mills, but it was good. If offered an X3 with tooling I would grab it, even though the X3 is now superceded I am sure spares will be available in the event they are needed.
Edited By Robbo on 03/07/2017 13:42:51
Stephen Benson03/07/2017 15:14:01
203 forum posts
69 photos
Space is so limited in my tiny indoor workshop that my bench has to be clear, have a lathe or a mill on it paid about £700 for the mill but will not lose much if I wanted to sell it
Neil Wyatt03/07/2017 16:53:12
19226 forum posts
749 photos
86 articles
I would be happy with an X3 in good condition and lots of tooling if you have the space. You can do a lot on a lathe with a decent chuck, a tailstock chuck and a few HSS tools. With a mill you need different gadgets for every job!
sean logie03/07/2017 20:47:00
608 forum posts
7 photos
Mills been sold dam!!!!!
Anyone have any ideas on the best place to search for a good used mill .
Sean
sean logie04/07/2017 19:18:08
608 forum posts
7 photos
Anyone use Apex auctions?. They have this up for auction https://www.apexauctions.co.uk/auction/search?query=Bridgeport%20Milling%20machine&tree=
Was toying with the idea of sticking a bid on it ?
Sean
Edited By sean logie on 04/07/2017 19:18:31
Robbo04/07/2017 23:29:38
1504 forum posts
142 photos
Posted by sean logie on 04/07/2017 19:18:08:
Sean
Thought you said space was limited and you wanted a bench top machine?
Don't forget auctioneer's fees and VAT and cost of transport = load of dosh.
sean logie05/07/2017 07:34:14
608 forum posts
7 photos
Struggling to find a decent benchtop mill . For the budget I've set .
Sean
sean logie05/07/2017 13:13:34
608 forum posts
7 photos
Anyone know of a warehouse or shop that sells the like of what I'm looking in Scotland or the north of England . Prepared to travel for the right machine .
Sean
Robbo05/07/2017 14:02:35
1504 forum posts
142 photos
You could try Barry at Bede tools and Machinery in Newcastle upon Tyne - [email protected]  tel 01914286575
Edited By Robbo on 05/07/2017 14:05:09
Robbo06/07/2017 08:57:26
1504 forum posts
142 photos
Another approach is to put a Wanted ad on here :- **LINK**
Henry Artist06/07/2017 09:23:31
121 forum posts
46 photos
I have a Sieg SX1LP which I purchased from ArcEuroTrade. It is sufficient for my modest needs as I only build small steam engine models as a hobby.
sean logie07/07/2017 13:11:55
608 forum posts
7 photos
Thanks everyone for the input... going to see the centec2 this afternoon and make an offer .it's been sitting outside since the turn of the year so I reckon it'll bee goosed.
Sean
Edited By sean logie on 07/07/2017 13:12:13
sean logie07/07/2017 22:54:28
608 forum posts
7 photos
Well.. I'm now the proud owner of a Centec2 horizontal mill . Mill is already stripped down bar the arbour (haven't figured out how that comes apart . The mill has had very little use I can still see the original grind marks on the ways ,all the leadscrews are like new . The spindle bearings feel good but I'm going to replace them anyways . It needs a motor if anyone knows of one let me know please. All in all I'm delighted ,it took nearly 9months 😁 so well worth the waiting and a bargain to boot 😉.
Sean
sean logie08/07/2017 07:34:14
608 forum posts
7 photos
Have now added a couple of photos in my albums .
Sean
