Alloy welding rods on Ebay
vintagengineer12/06/2017 22:34:02
469 forum posts
6 photos
These are the instructions for using alloy welding rods for sale on ebay!
Process:Light the torch, (fire shall not be too small, to be able to easily burn pipe next to the heat sink). End of burn
(preferably vertical burning, the torch can be slightly higher, with blue flames), in the burning process on the electrode
heating and welding solder powder on powder put it on the stick. With solder powder and try paddling at the required
welding welding electrode, such as temperature, just like water into welding electrode. If take off the non-stick electrodes
continue to the end of heating. (Not deliberately used in the welding process the flame burned electrodes, or keep it
vertical burn status. Uploaded under the electrode will depend on melting temperature. Upon close you will find that the
electrode is first melted under). Which is why cold electrodes can be causes of welding very thin aluminum parts. Wash
after welding to weld solder powder, finished.
peak412/06/2017 23:04:05
2207 forum posts
210 photos
Google a brilliant at many things, but Google Translate could do with improving a bit.
It's often said that you should translate into your native language, rather than from it; I think this is a prime example..
Michael Gilligan12/06/2017 23:31:15
23121 forum posts
1360 photos
Courtesy of google translate:
Here is the first sentence, translated into traditional Chinese
Does that help ?
devil MichaelG.
Jeff Dayman13/06/2017 03:08:19
2356 forum posts
47 photos
pls stop using translate
Edited By Jeff Dayman on 13/06/2017 03:13:32
mark costello 113/06/2017 15:37:36
800 forum posts
16 photos
2nd one on the right bottom row clearly shows 2 torches playing about on a work piece, can't be much easier to figure out.
Nick Hulme13/06/2017 17:12:17
750 forum posts
37 photos
Posted by Michael Gilligan on 12/06/2017 23:31:15:
Does that help ?
devil MichaelG.
Funnily enough it does, at least more than anything else so far
Ian P13/06/2017 17:47:35
2747 forum posts
123 photos
Seems that Google cannot deal with the punctuation marks Michael which makes the translation very confusing.
Ian P
John Stevenson13/06/2017 18:03:32
5068 forum posts
Not to mention orphan apostrophes 😀
Neil Wyatt13/06/2017 18:38:04
19226 forum posts
749 photos
86 articles
A nice but simpler example of some sort of literal auto-translate being used by (evidently) a non-English speaker are some ABS filament I have here. The label has a couple of Chinese characters and "The colour blue".
Edited By Neil Wyatt on 13/06/2017 18:38:43
