Dougie Swan | 20/05/2017 09:25:17 |
269 forum posts 73 photos | Hi I have a small brass globe valve that was screwed to a steel spigot The steel part has snapped off inside the valve and all my attempts to remove it have failed Is there any chemical way of eroding the steel and leaving the brass intact ? I have used electrosis to remove rust in the past and was thinking of this method but I am unsure what it will do to the brass Any thoughts? Thanks Dougie Edited By Dougie Swan on 20/05/2017 09:25:54 |
JasonB | 20/05/2017 10:12:32 |
![]() 25215 forum posts 3105 photos 1 articles | Alum is sometimes used to disolve broken taps in non ferrous metal so that may work. |
Dougie Swan | 20/05/2017 12:54:23 |
269 forum posts 73 photos | Thanks Jason How is it used? Dougie |
Neil Wyatt | 20/05/2017 13:10:00 |
![]() 19226 forum posts 749 photos 86 articles | Just make up a solution and leave it in place for a week or so. The steel will corrode away until it becomes loose. |
JasonB | 20/05/2017 13:19:02 |
![]() 25215 forum posts 3105 photos 1 articles | Suppose to work better when hot so pinch the best saucepan and use that. If you have a google for something like "Alum tap removal" you should find some threads on its use |
John Reese | 20/05/2017 17:45:56 |
![]() 1071 forum posts | I have often used this method: Use a hacksaw blade to make 3 or 4 cuts inside the broken stub. Cut deep enough that the root of the threads are visible, but no deeper. Use a sharp pointed punch to collapse the broken stub. Position the punch near one of the cuts. Catch the top edge of the broken stub with the punch and drive it toward the center of the opening. Usually the stub will come free when just one segment is collapsed. If badly corroded you may have to knock out all the segments. |
Ian S C | 21/05/2017 11:03:53 |
![]() 7468 forum posts 230 photos | Best to use a non metalic container, if you are going to heat it, glass is best. Ian S C |
