Bearing journal finishing
John Rudd02/05/2017 21:42:29
1479 forum posts
What other methods do you use for finishing a bearing journal to size?
I need to finish a bearing journal to accept a bearing of 10mm bore....the finest feed rate on my lathe doesnt leave what I'd class as an acceptable finish plus there's the risk of taking too much off on a cut....
Grinding in situ is one way of finishing to size, but are there any alternatives to consider?
Roderick Jenkins02/05/2017 21:56:21
2376 forum posts
800 photos
Lapping is a sure and steady way to bring a round to size with a good finish. I did this when I made a new mandrel for my little Flexispeed lathe.
Rod
John Rudd02/05/2017 22:03:44
1479 forum posts
Rod,
Could you elaborate a little on the lapping method please?
I guess the lap would have an internal bore finished to size? But how is the fine finish achieved on that?
Lapping paste, what is used as the 'wearing' material? Silicon carbide paste or something else?
JasonB03/05/2017 07:31:26
Small block of MDF to support some fine Emery cloth will allow you to take those last few tenths off.
An external lap van be made by boring a hole off ctr through a bit of 1" thick brass say aboyt 1.5" dia. Slit the thick part and add a cross hole so you can close up the slot. Load with fine lapping paste and oil and run the lathe. There is one shown by Ramon in this post, worth reading the whole thread for all you need to know about lapping and honing model engines
Edited By JasonB on 03/05/2017 08:03:52
Roderick Jenkins03/05/2017 09:33:04
2376 forum posts
800 photos
I used a lump of ally drilled to the nominal journal diameter and then split:
The lathe carrier screw can compress the lap as necessary as you proceed (a technique devised by Duplex many years ago). s5.jpg
I used 400 and then 600 SiC grit, sourced from the internet, mixed with a little light oil.
HTH,
Rod
Neil Lickfold03/05/2017 10:42:53
1025 forum posts
204 photos
You could make a poor mans external hone , by making a small vee block, and then using thin double sided tape or glue the fine wet and dry to it , or quite fine stones to it. Then us another sitting almost vertical above and polish away. For the 10mm bearing, if you want a press fit size for size . If you want a light slide fit, it is about 9.992mm and about 9.996 is a very light fit. Hope this helps, Fine is 240 to 320 paper or stones.
Michael Gilligan03/05/2017 10:49:41
23121 forum posts
1360 photos
idea Combine Rod's [Duplex's] idea with Neil's and we could be on to a winner.
... The vee-block and opposing pad are almost there in the lathe carrier.
John Rudd03/05/2017 11:27:53
1479 forum posts
Some good ideas, thanks chaps....smiley
If the surface finish is not perfect, i.e it has tool marks on it, is the hone going to take them out or just polish the spots?
One more thing, if the lap is made from brass or aluminium, wont the grinding medium wear that rather than the work piece?
Edited By John Rudd on 03/05/2017 11:31:24
Roderick Jenkins03/05/2017 12:52:24
2376 forum posts
800 photos
A hone or lap will remove the machine marks and give you a fine smooth finish. You can start with a coarser grit if the surface is rough.
The idea of using a softish metal for the lap is that the grit will embed in the lap and grind the harder metal of the job. It works very well and is a technique used with success by makers of i.c. engines which need a good surface finish for cylinders and pistons.
Rod
Hopper03/05/2017 13:32:24
7881 forum posts
397 photos
Depends too on the application. What type/material bearing are you going to use? What rpm and load?
John Rudd03/05/2017 13:58:15
1479 forum posts
Well thanks for the clarification.....yes
The application is for a gearbox shaft for an electric drill I'm refurbishing. The shaft has a 6000 ball race supporting it on the outboard end ( chuck end) while the inboard end is running in a bushing....Obviously the bushing journal needs to be pretty good in terms of surface finish, else it will rip the bushing surface to shreds.....rpm wise I think about 3000 revs, loadwise......ermmm well its a drill, so anyone's guess...
Thor 🇳🇴03/05/2017 15:20:47
1766 forum posts
46 photos
Hi John,
I don't know if you have read this: Laps and Lapping by Duplex. It gives you a good introduction and practical advice.
Thor
Roderick Jenkins03/05/2017 16:16:52
2376 forum posts
800 photos
Glad I 'fessed up smiley
Rod
Neil Wyatt05/05/2017 11:01:27
19226 forum posts
749 photos
86 articles
Posted by Roderick Jenkins on 03/05/2017 09:33:04:
HTH,
Rod
Another fast-fingered poster misses out on a 'Tip of the Month' prize!
Muzzer05/05/2017 12:36:01
2904 forum posts
448 photos
If you want to see how the professional does it, Robin Renzetti did a video on the subject. I suspect he's a couple of leagues above me but there are always things you can pick up....
Murray
Neil Lickfold05/05/2017 22:37:57
1025 forum posts
204 photos
Thanks Muzzer,
He under states the importance of holding parts if true roundness is required. The more round you want it, the harder it becomes. Having compounds that cut with little resistance is also understated in his video. The other secret with laps is that they are softer than the material being cut. The sunnen approach for external honing just can't be beat for roundness and the control of the taper. Lapping can take away material in areas that you do not need material removed. A high polish finish on a surface can be easily achieved with balsa wood and fine abrasives. Flexure laps for inside lapping have been around for a very long time and do work very well.
Honing allows you to get to the near very bottom of a hole or upto a shoulder on a shaft. Lapping often does not lend it's self well to blind holes and shafts with shoulders.
Michael Gilligan05/05/2017 22:44:48
23121 forum posts
1360 photos
Posted by Neil Wyatt on 05/05/2017 11:01:27:
Rod
Really ?
Hopper05/05/2017 23:43:06
7881 forum posts
397 photos
Posted by John Rudd on 03/05/2017 13:58:15:
For this application I would probably turn it to about one thou oversize, using a fine feed and light finishing cut, and then finish to size with wet rub paper and oil with the lathe running at about 1,000rpm. Quick touch with some coarser paper such as 400 or 800 grit then finish with some 1200 should do it.
Use small bits of emery paper that will not get caught up in the chuck and hold them lightly with your fingertips so they pull free if they do get caught up. Cover the lathe ways with a damp cloth or newspaper to keep the grit out of the ways and slides.
