Rust Removal
Not sure if it's any use to anyone
Martin Faulkner17/04/2017 20:54:03
85 forum posts
32 photos
Made a start on cleaning my lathe up and all the bits to go with. Here is a sample by the way of electrolysis. For those of you that have not tried it and want to see results. Here you arecollage 2017-04-17 17_46_04.jpg
oldvelo17/04/2017 22:15:04
297 forum posts
56 photos
Hi Martin
Having used this technique for a number of years on various restoration projects can I point other readers to
http://antique-engines.com/electrol.asp
Wire brush of Blackened oxides under running water and remove excess water the spray with WD 40 Or CRC Water Repellent.
A Blackening process to finish off.
Eric
Martin Faulkner17/04/2017 22:18:40
85 forum posts
32 photos
Great followup. Was not sure if it was of interest to anyone. I am new to this forum so don't really know the lay of the land sort of speak.
Can I also add, get a small wire brush, for small parts, I think I have lost half of the skin on my hands today using a normal one.
Vic17/04/2017 23:33:33
3453 forum posts
23 photos
I've used Electrolysis for cleaning rusty stuff quite a few times now. It works great and doesn't etch the surface like citric or other acids do.
Andrew Tinsley18/04/2017 09:56:01
1817 forum posts
I use hot diluted phosphoric acid and that works well too.
Andrew.
Neil Wyatt18/04/2017 10:51:47
19226 forum posts
749 photos
86 articles
Get some oil onto them ASAP as soon as they are out of the water.
Martin Faulkner18/04/2017 21:23:59
85 forum posts
32 photos
Posted by Andrew Tinsley on 18/04/2017 09:56:01:
Andrew.
Not heard of that one, does it require scrubbing after the hot acid process and does it react or eat away at the good steel?
Martin Faulkner18/04/2017 22:46:37
85 forum posts
32 photos
Andrew.
Andrew Tinsley25/04/2017 14:43:11
1817 forum posts
Hi Martin,
I am sure it does attack the steel, but only if you leave it in too long. It seems to go for the rust first. I did put in a large reamer with some rust on it. I left it in too long and the bright steel went a satin colour, but the rust was long gone.
I purchased 5 lts of conc stuff on Ebay. I dilute this down approx. 10 to 1 with very hot water and dump stuff in. It seems that hot is the key. Once it has cooled down a bit, then you can fish stuff out by hand and the acid doesn't affect my skin!
Andrew.
Andrew Tinsley25/04/2017 14:44:42
1817 forum posts
Hello again,
I think the recent post on rust removal using a non acid chelating agent is the best bet, but I can't find the thread!
Andrew.
Nick_G25/04/2017 15:00:56
1808 forum posts
744 photos
Posted by Andrew Tinsley on 25/04/2017 14:44:42:
Andrew.
Do you mean **LINK** this one.?
Nick
MW25/04/2017 15:38:57
2052 forum posts
56 photos
I'm probably more of a brute than a chemist which is why i mainly use a wire brush at high speed to clean up steel. Does a wonderful job on most stuff.
Michael W
Edited By Michael-w on 25/04/2017 15:39:58
Neil Fazakerley03/05/2017 17:43:43
5 forum posts
Posted by Martin Faulkner on 18/04/2017 22:46:37:
Andrew.
I believe phosphoric acid is actually one of the ingredients of Coke. Maybe you could soak parts in hot Coke?smiley
Just don't drink it afterwards.smile p
Neil Fazakerley03/05/2017 17:56:47
5 forum posts
Posted by Vic on 17/04/2017 23:33:33:
Apparently tea makes a good electrolyte for rust removal. Takes a long time though.
Same advice as my post abovesmile p
Neil Wyatt05/05/2017 10:59:38
19226 forum posts
749 photos
86 articles
Posted by Neil Fazakerley on 03/05/2017 17:43:43:
Andrew.
I tried using cheap'n'cheerful sugar free 'cola'. It worked fine (left in the garden) but took a few days.
It turned the cola into Irn Bru.
Edited By Neil Wyatt on 05/05/2017 11:00:08
