John Haine | 13/04/2017 14:01:57 |
5563 forum posts 322 photos | Does anyone know if there is a supplier for ER40 collets to take square material please? |
Jon Gibbs | 13/04/2017 14:10:45 |
750 forum posts | I've never seen square ER collets but this might help - although admittedly it requires a lot more work... **LINK** HTH Jon |
JasonB | 13/04/2017 15:28:19 |
![]() 25215 forum posts 3105 photos 1 articles | If you are lucky square stock can be held in a standard ER collet, I have done it a few times with no provlem, just holds the work by the corners so no heavy cuts. |
David Standing 1 | 13/04/2017 16:37:33 |
1297 forum posts 50 photos | What shank is your ER40 collet holder? |
John Haine | 13/04/2017 17:14:50 |
5563 forum posts 322 photos | Jason, thanks for that! Wanted to face off and drill the end of some 16mm brass square, corners fitted nicely into the slots of a 22mm collet, job done! David, not sure why it's interesting, but it isn't a shank it just fits on the Super 7 spindle nose. |
Vic | 13/04/2017 17:53:53 |
3453 forum posts 23 photos | Interesting point. I've used square stock in my ER32 chuck but which is best, locate the corners of the stock in the slots of the collet or between the slots? Edited By Vic on 13/04/2017 17:54:47 |
Michael Gilligan | 13/04/2017 18:02:06 |
![]() 23121 forum posts 1360 photos | Posted by Vic on 13/04/2017 17:53:53:
Interesting point. I've used square stock in my ER32 chuck but which is best, locate the corners of the stock in the slots of the collet or between the slots? . Given that ER collets are slotted 'out of phase' at each end ... I suspect that whichever way you try to do it, it will end up 'half & half' [so the choice is really whether the front or back end is better in the slots]. MichaelG. |
JasonB | 13/04/2017 19:38:41 |
![]() 25215 forum posts 3105 photos 1 articles | Also depends on how many slots the collet has, some have 6 each end, some have 8 each end./ If you set the corners about 1/4 of the space from the front slots they won't touch the back slots either on an 8 slotter, easier to do on larger sizes than small. |
John Haine | 13/04/2017 19:39:33 |
5563 forum posts 322 photos | Whatever, it worked very well. |
MW | 13/04/2017 19:44:55 |
![]() 2052 forum posts 56 photos | I would've thought that with the square collets you aren't able to use or assume that you'll get the same big size range as an ER40 collet would give you with round stock. |
JasonB | 13/04/2017 19:51:44 |
![]() 25215 forum posts 3105 photos 1 articles | Same with all collets such as 5C square ones you will always be limited to the across corners dimension so ER40 would only go upto about 18mm square which is 26mm across corners |
Nick Hulme | 13/04/2017 20:18:46 |
750 forum posts 37 photos | ER collets also work very nicely on shallow angle tapers :D |
Neil Lickfold | 13/04/2017 20:24:06 |
1025 forum posts 204 photos | Not sure if they were made by some one or a purchased item, but we used to have a segmented piece held by 2 wire clips. The segments allowed you to hold a square bar in a collet and went up to 3/4" square. The smallest was like 3/16 or so. They were all imperial. it was just 4 cord segments retained with a wire clip at each end and used in the collet chuck. Neil |
David Standing 1 | 13/04/2017 23:59:16 |
1297 forum posts 50 photos | Posted by John Haine on 13/04/2017 17:14:50:
I asked because you can get a square section holding 5c collet plus a cnc collet holding bushing with a parallel shank, but unfortunately the bushing is too big to go in an ER32 collet. |
mechman48 | 15/04/2017 11:39:29 |
![]() 2947 forum posts 468 photos | I have just used my ER25 collet set to hold a piece of 1/4" square brass to machine the fork end for the eccentric rod fitting for my S50 yesterday, it held it in the slots quite securely & didn't need any centering, the 7BA tapping hole was bang on centre, so I would have any hesitation in using this method again ( Have used the 16 mm collet in the same manner for a large 5/8 " hexagonal bar ). |
mick | 15/04/2017 14:45:02 |
421 forum posts 49 photos | A self centring four jaw would be a better option, there are some decent and inexpensive ones out there, mines a Tos which I've had for about six years and use all the time, in fact the only time I use a three jaw these days is to hold hexagonal stock. |
Howard Lewis | 15/04/2017 17:37:12 |
7227 forum posts 21 photos | AS far as I know, ER collets are only produced to hold round workpieces. Unless I am mistaken, was'n there an article some time ago on making a set of parts to hold square material in a round ER collet? ER40 should be large enough to accomodate "adaptors" of various sizes. Howard |
Flying Fifer | 15/04/2017 21:13:16 |
180 forum posts | Howard, You are correct, there was an article in MEW a few yearsago. I made 4 sets to suit differing sizes of square bar and found them very handy on numerous occassions. I`ll see if I can find the source reference as I should have it somewhere. Alan |
JasonB | 16/04/2017 08:48:57 |
![]() 25215 forum posts 3105 photos 1 articles | See the link in the second post, most likely the article was by Harold. |
