Another Mystery Tool
Old Crock29/03/2017 22:01:29
31 forum posts
18 photos
This tool came in a collection from a workshop clearance. Can anyone identify it and explain its use please?
The straight arbor is 2 1/8" long x 1" diameter with a 5/16" bore.
The head is 2 1/4" diameter with a 1/2" bore 1 1/2" deep.
The 3/16" HSS has an angled end but no side or top clearance.
Fine adjustment of the two rollers and HSS is by releasing the clamping nust and using the knurled screws for fine movement.
There may be a makers mark, or it may be an owners stamp, which you can just make out in the second picture but it is not clear enough to make any sense.
Michael Gilligan29/03/2017 22:06:11
23121 forum posts
1360 photos
I think it's effectively a combined 'Steady' and cutting tool ... for rapidly reducing the diameter of [Brass] rod.
i.e. A variation on the theme of this one:
https://books.google.co.uk/books?id=MiEDAAAAMBAJ&pg=PA186&lpg=PA186&dq=lathe+diameter+reducing+tool,+steady&source=bl&ots=3vMsqkp90k&sig=R7IpiFD0qWUvPdkKOv7N8qGD_rI&hl=en&sa=X&ved=0ahUKEwiW_8f_z_zSAhXpBcAKHUi7DDMQ6AEIXjAI#v=onepage&q=lathe%20diameter%20reducing%20tool%2C%20steady&f=false
Edited By Michael Gilligan on 29/03/2017 22:13:09
Neil Wyatt29/03/2017 22:07:26
19226 forum posts
749 photos
86 articles
It looks like a box tool, used for running down repeat jobs from the tailstock.
The rollers are a steady.
Jonathan Garside29/03/2017 22:07:33
52 forum posts
Looks like a turret roller turning box probably to fit a smaller capstan lathe
Jonathan
Chris Gunn29/03/2017 22:09:29
459 forum posts
28 photos
Sounds like a roller box, often used on Capstan lathes. Used as described by MIchael, with a suitable tool bit can be used for any material.
Chris Gunn
Michael Gilligan29/03/2017 22:15:13
23121 forum posts
1360 photos
 idea
Box ... That's the word I was struggling to recall. blush
P.S. ... I only mentioned Brass because of the stated lack of rake
['though that might be just a tool-blank that's installed]
Edited By Michael Gilligan on 29/03/2017 22:26:44
David George 129/03/2017 22:31:45
2110 forum posts
565 photos
It's a roller box from capstan lathe it's the same as I used on a Herbert 2D. It turns a plain diameter and supports the rod turned and gives a slight burnished finnish as it cuts with the end of an angled carbide brased cutter.
David
Old Crock29/03/2017 22:50:34
31 forum posts
18 photos
You can always rely on the folks on here so thank you all for your help.
A search on Turret Roller Turning Box brought up quite a few images of similar tools so thanks again for your help.
Phil Whitley30/03/2017 22:00:32
1533 forum posts
147 photos
,My very good friend and time served precision engineer once said to me, I have just what you need!!, I said, whats that then? and he said" It's a chip stream roller box" and I said WTF is a chipstream roller box" and he said "Just what you need" The last laugh was on him as it sold on Ebay for £180.00!! It is for reducing the end of a round bar , usually to threading diameter , on a capstan lathe, and in truth, I had no use for it whatsoever, but he wanted rid of it!
