Nick Taylor 2 | 10/03/2017 07:35:30 |
102 forum posts | Morning all, I have two older machines (a shaper and a pillar drill) that whilst mechanically very serviceable are being let down by loud and rough running old single phase motors. What makes old single phase motors so ruddy loud? They can't of been this bad when the left the factory! Now I know that the obvious answer if I want quiet running would be to fit three phase with inverter but I would like to keep them on single phase. Has anyone purchased a single phase (about 0.5hp) motor recently who can make a recommendation? |
David Colwill | 10/03/2017 07:57:19 |
782 forum posts 40 photos | Hi Nick, I've had my fair share of old rumbly motors. In many cases it is the bearings, not surprising really when you think about it. Replacing the bearings can often be the easiest and cheapest way to go as you don't have to redo any of the mechanical work. That said and bearings aside there are still some very loud motors about! David |
john carruthers | 10/03/2017 07:59:29 |
![]() 617 forum posts 180 photos | If a noisy motor fitted vertically quietens down when horizontal it's a good sign the bearings are on their way out. |
Johan van Zanten | 10/03/2017 10:51:02 |
![]() 52 forum posts 98 photos |
Hi Nick, Single phase motors make a humming noise, wich is different from bearing noise. This is caused by the way they work and is called cogging noise. That's why manufacturers like Brooks mount their motors in silent rubbers. Two phase motors ( with a running capacitor ) behave a little better at this point. 3 phase motors are quiet. But all motors can have bad bearings wich makes a rumbling sound. Best regards, Johan.
peak4 | 10/03/2017 11:51:08 |
![]() 2207 forum posts 210 photos | I've just bought a couple off ebay from This Seller , both 1/2 HP One single phase 2 pole and one 3 phase 4 pole to run my Dore Westbury of an inverter I already have in stock. I've only used the high speed one so far on my Clarkson T&C Grinder, but it seems fine. It is a bit noisier than I'd like, but I think that's probably due to the speed of the various bits whirring round than the motor itself, which was fairly quiet without the drive belt on. If Owen isn't listing what you're after, drop him an ebay message, as he has some other stock left from a previous business venture, and only lists a few at a time. No connection with the guy, other than as a satisfied customer. Regards Bill |
Ian S C | 11/03/2017 09:06:04 |
![]() 7468 forum posts 230 photos | A good, but noisy motor can sometimes be quietened by using rubber or similar isolation, so that the motor is physically isolated from from what it is mounted on. If the motor is mounted on a box like cabinet, maybe a lathe bench this can form a sounding board, and amplify the 50Hz buzz that can be present. Ian S C |
