Rik Shaw | 24/02/2017 17:32:47 |
![]() 1494 forum posts 403 photos | As a beginner re: 45mm/G gauge I could do with a pointer or two. Can some one recommend supplier/s of small brass pipe fittings for my loco boiler - unions, cones etc. I will be using 1/8" diameter copper pipe. EPK have some of the stuff I need but not all. I'll also need a water sight glass approx 40mm between centres - is such a thing available or are you expected to buy the glass and make your own? Any advice much appreciated. Rik |
mechman48 | 24/02/2017 17:42:18 |
![]() 2947 forum posts 468 photos | Rik. |
Paul Kemp | 24/02/2017 18:06:35 |
798 forum posts 27 photos | Rik, Be aware that theoretically brass is not a good material for boiler fittings due to zinc being leached out leaving a spongy copper matrix that is weak and prone to failure! You should use gunmetal or bronze. However practically I think most of the commercial suppliers seem to use brass, certainly those that I have purchased in the past seem to be brass. They should be fine as long as you inspect them regularly and replace any that are going an orange colour. Paul. |
mechman48 | 24/02/2017 18:52:24 |
Edited By mechman48 on 24/02/2017 18:54:37 |
alan-lloyd | 24/02/2017 19:40:56 |
![]() 183 forum posts | Stuart models do 1/8 pipe and fittings |
julian atkins | 24/02/2017 21:53:29 |
![]() 1285 forum posts 353 photos | Hi Rik, I have used the K&S range of copper thinwall pipe for many years, available at most model shops in the UK. I make all my own fittings plus cones and union nuts etc. As a result, I can tailor make everything to much finer 'scale' sizes and far more 'scale' than off the shelf commercial fittings, and also at a fraction of the cost. I would encourage anyone to 'have a go' at making their own. The results should look far better than commercial fittings. Cheers, Julian |
Rik Shaw | 25/02/2017 14:24:50 |
![]() 1494 forum posts 403 photos | Thanks for your tips chaps. I can get most of what I want from your recommended vendors and what I can't buy I will make myself. Rik |
