How to put a 180 degree radius on the edge of a steel plate?
Andrew Tinsley03/02/2017 15:19:28
1817 forum posts
Hello,
I have been making a repair piece for a large Victorian church key, A slitting saw worked wonders for the tumbler slots. I now have to make a round profile to the edge of the key. I was going to take a file to do the job, when I started thinking ......... how would you do such a job using machine tools, either lathe or mill?
Is there a simpler way than using a milling cutter in the mill chuck and having the plate mounted vertically on a rotary table? It just seems to be a lot of kit to do what looks like a simple job!
My interest is theoretical and the file is about to be used!
Andrew.
mechman4803/02/2017 15:31:29
2947 forum posts
468 photos
Hi Andrew
​Use a bench grinder to take the meat off then draw file the rough edge with 2nd cut file ... & emery if you wish ...
George.
Jeff Dayman03/02/2017 15:44:36
2356 forum posts
47 photos
Try googling "corner rounding cutters" - these cutters will round your keys nicely (not cheap though). JD
KWIL03/02/2017 16:05:00
3681 forum posts
70 photos
If you really want to, mount plate (or key edge) vertically in machine vice, pass a radius milling cutter down each side. Job done. Radius does need to be = 1/2 plate thickness for your 180 degree requirement.
Andrew Tinsley03/02/2017 17:50:05
1817 forum posts
Hello Kwil,
I am afraid that I don't understand your description. Not too well up with engineering terminology. What is a radius milling cutter? I am only really familiar with ordinary milling cutters and specials for cutting say a woodruff key slot.
Come to think, is a radius cutter one that has a curved cutting edge at the bottom of the cutter?
A description of a radius milling cutter may help me out here!
Thanks,
Andrew.
P.S. Thanks George, I did in fact use my bench grinder to get the rough stuff off. A big help as my muscle wasting disease and heavy filing don't go together too well!
Neil Wyatt03/02/2017 17:51:29
19226 forum posts
749 photos
86 articles
You could cut a groove in some silver steel and make a form tool
Danny M2Z04/02/2017 04:41:33
963 forum posts
These work well - just remember, the curve is a RADIUS so us half the thickness of the key for a smooth curve. **LINK**
* Danny M *
mechman4804/02/2017 12:41:43
2947 forum posts
468 photos
I have a set of these with different cutter styles all carbide tipped...
http://www.toolstation.com/shop/Power+Tool+Accessories/d80/Router+Bits/sd2579/TCT+Router+Bit+Set/p37879
this set has a 'round over bit' that will do the job.
George
JasonB04/02/2017 13:19:33
If you have a blunt milling cutter just grind the cornes off that freehand on the bench grinder so they are concave, which gives a quick and cheap rounding over bit. Did the moulding around the base of this engine that way.
Andrew Tinsley04/02/2017 13:35:27
1817 forum posts
Thanks everyone,
As usual I was way behind on working out how to do this job. Lots of useful information and I now know what a radius milling cutter is. Now if I had been thinking router, then the penny would have tumbled!
Thanks again everyone.
Andrew.
