mick70 | 27/01/2017 07:29:32 |
524 forum posts 38 photos | planning on building fabrication bench using 1/2" x 8" steel slats drilled to take various jigs. to buy them cut to length is a no go due to cost. was wondering if could get metal cutting blade to fit my B&Q radial arm saw and use that by taking several light cuts each time? if so where is best place to get blade? |
JasonB | 27/01/2017 07:41:10 |
![]() 25215 forum posts 3105 photos 1 articles | They snatch enough in wood hate to think what one would be like in steel so I won't suggest what type of blade may work. |
Alan Waddington 2 | 27/01/2017 07:52:01 |
537 forum posts 88 photos |
Are you thinking of using an abrasive cut off disc, or a carbide saw blade ? Either way I reckon t's a non starter,a decent bandsaw or guillotine would whip through those in no time, better to get the steel stockholder to do it. My local steel place doesn't charge loads for cutting, not compared to the cost of the material anyhow. 200 x 12 flat, won't be cheap especially if you don't have an account. Edited By Alan Waddington 2 on 27/01/2017 07:52:28 |
John Haine | 27/01/2017 08:14:11 |
5563 forum posts 322 photos | What do you mean my radial arm as the b&q site doesn't list these as such? You say 1/2" x 8" but how thick? I've seen that b&q stock rage blades for their chop saws that are suppose to cut steel IIRC. |
JasonB | 27/01/2017 08:49:48 |
![]() 25215 forum posts 3105 photos 1 articles | 1/2" thick x 8" wide flat bar cut to length was how I read it |
Michael Gilligan | 27/01/2017 08:50:41 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 27/01/2017 08:14:11: ... You say 1/2" x 8" but how thick? . Interesting question, John ... I was about to ask differently: 1/2" x 8" but how long ? Significant variations on a theme !! MichaelG. . Jason beat me to it. Edited By Michael Gilligan on 27/01/2017 08:52:00 |
vintagengineer | 27/01/2017 09:20:31 |
![]() 469 forum posts 6 photos | Yes you can get a cold cutting blade for steel. But it depends on the speed of your saw as whether you can use you saw. |
John Rudd | 27/01/2017 09:43:16 |
1479 forum posts 1 photos | My Rage cut off saw with 14" blade runs at 1450 rpm, my Rage 10" sliding mitre saw runs at 2500 rpm and the little Rage circular saw with its 185mm blade runs at around 4000rpm..... I would not advocate using an 8 or 10" carbide blade for cutting steel in a mitre/chop saw not designed for that purpose.... |
Nicholas Farr | 27/01/2017 11:17:32 |
![]() 3988 forum posts 1799 photos | Hi, if I were to be faced with this scenario without a suitable metal cutting saw, I would use a 9" angle grinder and thin cutting disc. Regards Nick. |
David Colwill | 27/01/2017 11:53:59 |
782 forum posts 40 photos | Whereabouts are you? It would be a shame to struggle if you were near to someone with a suitable saw. I'm in Nottingham if that's any good David |
Alan Waddington 2 | 27/01/2017 12:46:20 |
537 forum posts 88 photos | I read it as wanting to cut 8" wide x 1/2" thick flat bar to lengths suitable to build a bench top, but who knows ? |
Brian Oldford | 27/01/2017 12:52:53 |
![]() 686 forum posts 18 photos | Posted by Alan Waddington 2 on 27/01/2017 12:46:20:
I read it as wanting to cut 8" wide x 1/2" thick flat bar to lengths suitable to build a bench top, but who knows ? Me too.
Using a Radial Saw. FWIW My advice. . . .don't do it. If it grabs (as they do tend to) something is bound to let go big-time. I wouldn't want to be within shrapnel distance. |
