Bought a Quorn, have som questions
Thomas Staubo25/01/2017 10:53:55
54 forum posts
Greetings!
I just bought a Quorn ready made, for what I think was a good price, about £200.
It looks well made, but needs painting and some finishing touches. It came with the book, but without any grinding wheels or spindles to mount them on. Otherwise looks complete to my eye. The grinding wheel spindles would be easy to make.
Here in Norway they don't come up often, so I think I was lucky
Two home made dividing heads also came with the quorn, one to mount on the rear of the myford lathe spindle. The other has a use not known to me, but is very well made and will be adapted to gear making probably.
I will add pictures within 24 hours.
The questions:
1. If I need a spiralling head, do I have to buy castings from USA or Australia? Or is it possible to still get castings from Model Engineering Services? Their website doesn't exist anymore.
2. Is 100mm grinding wheels a good size? I have a diamond grinding wheel laying unused, but can't remember what size it is.
I know of the Yahoo group, but isn't a member yet.
Emgee25/01/2017 11:19:51
2610 forum posts
312 photos
Hi Thomas
£200 is a very good price for you if the machine is accurately built, especially with the dividing head which can also be used on the lathe.
I look forward to seeing the pictures and can then answer more of your questions.
Emgee
Thomas Staubo25/01/2017 11:28:55
54 forum posts
Thank you! More questions likely to come when I start using it
Is the spiralling head for grinding endmill flutes and the like? I havent got the book home yet...
Martin Kyte25/01/2017 11:42:47
3445 forum posts
62 photos
Good old you.
I made mine about 20 years ago. Unless you actually want to make cutters you will not need the spiralling head but if you want to build it for the sake of completeness,personally I would fabricate it. I made one that has never been used. 100mm is a good size wheel for a quorn.
I made a stack of wheel arbors when I turned the taper in the spindle, if you do worry about matching the angles you make a load of blanks then set up the spindle as per the book (still readily available) and skim the taper and finish the blanks off with the same topslide setting. I have made additional arbors since just by angular setting without problems so take your pick. One thing I would have done differently had I realised is used split cotters (George Thomas style) instead of slitting the castings which went all ways once the stress came off them but as your is complete that is a moot point. I have an ER16 chuck with a parallel shank which is a useful fit to the tool head.
They are a little confusing to use at first with so many clamps but you will get used to it.
regards Martin
Martin Kyte25/01/2017 11:45:14
3445 forum posts
62 photos
PS endmill flutes are ground by self indexing with a finger (metal one not one of your digits).
Martin
Thomas Staubo25/01/2017 12:49:49
54 forum posts
Aha! Good advice, Martin! Probably not going to need it then.
I have the index finger.
Thomas Staubo25/01/2017 14:55:51
54 forum posts
It came with the recommended 1/6th hp motor, but I have a cute little 3-phase motor and a VFD that I concider using instead. It's very neat adjusting the speed on the fly, from 0 to 3000rpm or more
Ian S C26/01/2017 08:38:24
7468 forum posts
230 photos
Just watch that you don't over speed the grinder wheel, they all (should) have the max RPM marked on them.
Ian S C
Thomas Staubo26/01/2017 12:53:16
54 forum posts
Good point!
Thomas Staubo26/01/2017 14:05:13
54 forum posts
Picture time!
You can see all the pictures if you follow this link: http://imgur.com/a/ZlhQN (Click on each one to enlarge.)
I tried to post a few as links her, but it didn't work.
Edited By Thomas Staubo on 26/01/2017 14:08:44
Roderick Jenkins26/01/2017 14:22:47
2376 forum posts
800 photos
I seem to recall from my Quorn days that the spiralling head was designed to sharpen the flutes of throwaway cutters which were too small to use with an indexing finger. Chaddock had determined that the various sizes only used a few helix angles between them so made the spirals to suite. I never made one, with throwaway cutters the clue is in the name smiley
Rod
Edit:  I've just had a look at your pictures.  The dividing head is the major part of the George Thomas Versatile Dividing Head   .  The staking tool looks like part of the George Thomas Universal Pillar tool
Edited By Roderick Jenkins on 26/01/2017 14:35:19
Thomas Staubo26/01/2017 15:01:00
54 forum posts
Posted by Roderick Jenkins on 26/01/2017 14:22:47:
You are very observant, Roderick. Thank you!
I see that I can buy the basic kit Ref: HK 1501 for the VDH, and add my dividing head to it
Thomas Staubo26/01/2017 18:19:41
54 forum posts
Just figured out why I couldn't embed pictures.
But again, please follow this link if you want to see all of them in hi-res glory.
Quorn
Thomas Staubo27/01/2017 12:03:30
54 forum posts
I tried the second dividing head on my ML7 today, and it fit right on like this:
dividing head
It's not he most solid mount, as the belt cover is held on with just two bolts. But I think it will work...
If anyone has more information about this dividing head, please inform me.
dividing head
Martin Kyte27/01/2017 12:15:20
3445 forum posts
62 photos
Not the most stable arrangement as you say. Could you come up with an arragement that uses the change wheel studs as anchor points perhaps.?
Martin
Thomas Staubo27/01/2017 14:36:04
54 forum posts
I will look into it
Emgee27/01/2017 15:40:05
2610 forum posts
312 photos
Hi Thomas
You certainly had a good buy with all those parts, one thing I notice you may have a clash of locking handles with the rotate and tilt functions.
Emgee
Thomas Staubo01/02/2017 13:16:54
54 forum posts
You may be right, Emgee. I have just played with it a little so far.
It seems to be something not quite right, when tilting the work head. But I have to disassemble a lot of things, just to put a thicker/thinner washer under one of the lower ball handles.
I do noticed that I have to exert a bit more pressure than I like, when clamping the workhead base to the front bar. I have to press on that ball handle quite hard. It may be that the bore is a bit over 1" (25.4mm)? Could it be that the bore opened up a tad, when the casting was slit?
I know that axle collars often are partially slit on the opposite side of the bore, to achieve greater clamping pressure.
Like this:
Is that a possible solution on the Quorn, or will it weaken the cast iron too much?
I'm in the process of ordering two CBN grinding wheels for use on HSS. And if I can find it, I have a dished diamond grinding wheel for carbide, whic hmay fit.
But arbors for these have to be made, until then I can only admire it and try to figure out how to set it up for grinding. I also have to make a holder for square lathe and shaper tools.
Edited By Thomas Staubo on 01/02/2017 13:17:47
Emgee01/02/2017 16:02:03
2610 forum posts
312 photos
Thomas
After tightening by hand I have a short length of 1" brass rod which I use to lock off the important axis by a light tap with the rod, you certainly don't want any movement from the set position or the job will be ruined.
Emgee
John Haine01/02/2017 16:12:23
5563 forum posts
322 photos
Posted by Thomas Staubo on 01/02/2017 13:16:54:
You're not wrong! I find that too, it can be disconcerting. Also clamping the front bar so it doesn't rotate.
There was a series of articles in Home Shop Machinist (I think) on a "Very Much Improved" Quorn that's worth reading, some good ideas for improvements. My Quorn was made by my father, and used 3C collets, as he had a set for his Southbend lathe. Most of them went with the lathe so I only have a couple, so I have made a new chunkier workhead that takes R8 collets which I use on my mill. Also a couple of other changes which make it a bit easier to use. (Not that I do use it much as I find it underpowered for forming tools and too fiddly to set up, so have made an Acute sharpener for everyday.) I'll try to post some photos.
