Steel for making tool holders
Matt Harrington18/01/2017 20:58:57
212 forum posts
16 photos
I'm about to make a few Tripan tool holders for a toolpost I have. What would be the suggestion for the type of steel to use for these or does it not really matter. I was thinking of ground stock to the correct overall size but not sure what grades to go for.
Matt
pgk pgk18/01/2017 21:13:26
2661 forum posts
294 photos
I made a bunch of these a while back.. ordinary cold rolled bar. they seem to work fine.
Thor 🇳🇴19/01/2017 05:29:51
1766 forum posts
46 photos
I used ordinary black mild steel to make my toolholders. They might not last as long as hardened toolholders, but when they afre worn I can just make some new ones.
Thor
Chris Evans 619/01/2017 09:30:08
2156 forum posts
You won't wear them out if you use black rolled bar. Avoid "O1" ground stock it is not easy to machine and expensive for no real gain.
John Haine19/01/2017 09:46:48
5563 forum posts
322 photos
IIRC ground stock is either flat plate of square bar, so might not be available in the size you want anyway. As Chris says, it's tough to machine for no significant benefit. Better to use black rolled bar and if you are really keen you could always case harden. But what's going to wear anyway?
Matt Harrington19/01/2017 10:15:48
212 forum posts
16 photos
Thanks guys, you have answered my question and now I shall source some mild steel @ 30mm x 50mm - this being the section of the Tripan holders I want to make.
Matt
Tony Pratt 119/01/2017 19:41:10
2319 forum posts
13 photos
Matt,
I too would go with black rolled bar, I also suggest you 'rough out' all the main features on each tool holder to relieve any stresses in the material then finish M/C each block for the best results.
Tony
Ian S C20/01/2017 10:05:34
7468 forum posts
230 photos
With hot rolled bar you won't find much in the way of residual stress.
Ian S C
John Reese21/01/2017 01:10:18
1071 forum posts
You might find this video series useful.
https://www.youtube.com/watch?v=FoAVtGHV7dA
https://www.youtube.com/watch?v=VXgYJuNS1fg
https://www.youtube.com/watch?v=dEmlL1ZJIMk
thaiguzzi21/01/2017 02:38:45
704 forum posts
131 photos
Any old steel to hand will do. I've even got 5 in aluminium (ran out of steel stock)...
Matt Harrington22/01/2017 23:14:49
212 forum posts
16 photos
Posted by John Reese on 21/01/2017 01:10:18:
Thanks John - a tutorial for the holders I am after!! Couldnt be better. I see he uses plain carbon steel ground stock.
Matt
