Then reality goes and spoils it...
Neil Wyatt31/12/2016 12:34:10
19226 forum posts
749 photos
86 articles
At first it's really exciting seeing neatly made track links come off a 3D printer.
Once you have glued on the strake (requiring clamping with three pegs) then later fitting it to the next by inserting a length of stainless wire and securing it with a drop of superglue and repeated the exercise 12 times the enormity of repeating the process 400 times starts to sink in...
PaulR31/12/2016 13:07:18
123 forum posts
21 photos
That's 2017 accounted for then.
Ajohnw31/12/2016 13:24:40
3631 forum posts
160 photos
angelI've no idea what you are making but suspect I would be thinking of a redesign that didn't need so many pieces.
JasonB31/12/2016 13:31:47
Don't know why you have not machined them from metal, couple of tracked models being made on MEM at the moment and both had the track links done and dusted in a couple of daysdevil
Ed Duffner31/12/2016 13:45:52
863 forum posts
104 photos
I join the 35th scale metal track links(Friul Model) on my tanks with a thin piece of wire and CA glue. Plant myself in front of the TV or Youtube and work away.
With a 3D printer I thought it was posible to print the whole thing in one go, including the joints?
Ed.
Carl Wilson 431/12/2016 14:49:48
670 forum posts
53 photos
Friend of mine is making a tracked vehicle. Making the track links by 3D printing with a FormLabs machine. Takes some little time to print all the links and the assembly takes a long time. In short the machine produces accurate results but it takes a long time to do it. That said, he hasn't any faster way to make such a complex part as a track link.
3D printers are good for one off prototyping but not production. I suspect the way to make his links in the real world would be injection moulding.
Carl Wilson 431/12/2016 14:54:11
670 forum posts
53 photos
IN THEORY it is possible to print mechanisms with moving parts in one go. When my friend got his printer he enthused about all the wonderful possibilities.
However, once you get into it you realise that it isn't quite as simple as all that. There are all kinds of little anomalies that crop up and although his attrition rate is now pretty low, there is still quite a lot of post processing required before the parts are fit for purpose, even on an accurate Form Labs machine.
I think the technology has a way to go yet before machines that are in the price range of the home user are capable of such amazing feats. It will come though.
Neil Wyatt31/12/2016 17:13:41
19226 forum posts
749 photos
86 articles
The point of this is a 'project' for taking the Dremel 3040 3D printer through its paces for review, so not just links but sprockets, suspension links and road wheels as well.
Posted by Ed Duffner on 31/12/2016 13:45:52:
Exactly what I'm doing. An all plastic joint might not be strong enough at 1:6 scale, and you can't print close joints.
An alternative would have been clip-together links, but a challenge to make these robust enough and what clips together can unclip....
The problem is that the links have no flat surfaces large enough to use as the base of a link. Taking off the 'tread' leaves a flat surface with plenty of adhesion and minimal overhangs. I could use them like this, but gluing on a gull-wing makes them pretty realistic. The problem is that the treads being only 1mm thick and tapered at the ends (to simulate a bit of road-wear) tend to curl a little and need to be held in place while the glue dries. Unworn treads would not have had this problem, but I've started so I'll finish...
I must admit, I have no idea why some people get one then can't think of anything to do with it. I.
Mark C31/12/2016 17:42:57
707 forum posts
I think I will wait 'till next year and buy a laser sintering printer from China, they should be selling them off cheap by then if Trump gets really protectionist! A nice 12 micron machine with a few free buckets of different media thrown in would be good...
Mark
Neil Wyatt01/01/2017 12:50:48
19226 forum posts
749 photos
86 articles
Prototype, you can just see the treads sticking out underneath. The teeth are hollow on the wrong side and other errors.
Nick Hulme11/04/2017 10:19:23
750 forum posts
37 photos
Posted by Neil Wyatt on 01/01/2017 12:50:48:
Still nice though Neil.
I wonder if I can see a future including custom printed Scalextric bodies?
MW11/04/2017 10:50:58
2052 forum posts
56 photos
Posted by Nick Hulme on 11/04/2017 10:19:23:
And why not I suppose, sounds very plausible.
Michael W
Muzzer11/04/2017 11:05:18
2904 forum posts
448 photos
Neil - dig the groovy link pins! Can I assume you are planning to have this finished for Xmas then? Which year?
Bazyle11/04/2017 11:09:57
6956 forum posts
229 photos
Centipede skeleton model for Science museum? Explains why Bernie Rubble invented WHEELS.
Neil Wyatt11/04/2017 11:16:14
19226 forum posts
749 photos
86 articles
It would be nice to be finished this year, by MEX 2018 at the latest!
Not much progress now until I make my Prusa!
KWIL11/04/2017 11:16:15
3681 forum posts
70 photos
Neil, Did I miss it? The price of chinese made Dremel 3040 3D printer?
JasonB11/04/2017 13:03:27
KWIL you mean to say you did not read Neil's review in MEW?
Neil Wyatt12/04/2017 21:10:28
19226 forum posts
749 photos
86 articles
Posted by KWIL on 11/04/2017 11:16:15:
About a grand, if you shop around.
