Here is a list of all the postings PaulR has made in our forums. Click on a thread name to jump to the thread.
Thread: Couple of things at Lidl |
23/04/2017 17:49:09 |
Posted by Matthew Reed on 23/04/2017 16:36:44:
you'd have to stand three feet away! That made me laugh out loud. He'd also need a yard-long stick of solder. I would pay money to see that :D |
Thread: Bronze, Phosphor Bronze, Cast Iron or Graphite for LTD Stirling bearing |
11/04/2017 07:34:18 |
Right, I'm giving graphite a wide berth and going for the easy solution - brass. |
10/04/2017 21:36:07 |
Following on from my other question.... The plans call for bronze or graphite for the displacer rod bearing. Looking at various suppliers 'bronze' seems to cover regular bronze (the coppery coloured stuff that I'd call bronze), phosphor bronze and gunmetal (can't believe how pricey this stuff is these days, maybe I should take up woodwork!) As the part is going to be glued in place I thought cast iron, brass or even aluminium might do the job until I came across this interesting page: which, as the rod through the bearing is steel, shows that graphite is miles out in front in the slipperiness department! Trouble is I can't see it for sale anywhere and have no idea how to machine it (some web forum I read said it was very dusty). Does it usually go under a trade name or something? Will it be possible to make an accurate 2mm hole through it with a D bit? Should I just use brass (which according to that page has a lower coefficient of friction than cast iron when put with steel)? TIA Paul |
Thread: Aluminium for LTD Stirling |
08/04/2017 12:55:42 |
Thanks to all for the tips. The shellac idea looks neat, I suppose I could make a little stubby 'faceplate' to stick it to rather than play a flame over the real one. Looks like a really nice finish on that bit of brass in the video. Ian, that's monstrous (in a good way)! I don't hold out much hope of randomly finding a frying pan in a skip although I think we have some Trangias and mess tins lying around from when the kids did their DofEs but I bet they are nowhere near thick enough.
07/04/2017 20:32:57 |
Posted by JasonB on 07/04/2017 20:19:04:
Fix it to a faceplate by the corners to do the groove before you cut them off. Good idea! At the risk of going way off topic... Any tips for turning the outside diameter? I've used super-glue and/or a wood pad and a live centre in the past. I'm sure I once saw someone turning a disk held with wax somewhere on the net... |
07/04/2017 20:15:52 |
Posted by SillyOldDuffer on 07/04/2017 19:57:01:
Another interesting link Michael. It's given me a new word: apparently "Shate" is defined as the "overlap between sheet and plate."
Sounds like the Geordie pronunciation for you know what! @Michael Thanks for the link - added to my stash @Jason Doh, why didn't I think of eBay?! Plenty of suitable bits on there, cheers. Just need to figure how I'm going to turn/groove the bottom plate that has no central hole - super-glue and cross everything I suppose...
07/04/2017 19:17:02 |
Despite two previous Stirling failures (made 'by eye' without any plans) and one moderate success I'm going to attempt a simple LTD/Ringbom type engine. It calls for two circles of aluminium plate, one 8mm thick, the other 5mm thick and both about 4.5" diameter.
These sizes seem too thick for plate and too large a diameter for bar - can anyone suggest a source (preferably one that won't break the bank (I've never machined aluminium before and expect to make one of two mistakes :D ) Cheers Paul
Thread: Milling - What am I doing wrong |
03/03/2017 18:17:32 |
Mill table and head not perpendicular seems the obvious one to me - does it happen on everything? What if you turn the work-piece through 90 degrees? |
Thread: Simple fix for pillar drill wobbles |
03/03/2017 11:06:50 |
Finally took apart the 'Clarke' drill today to see what if anything could be done about the wobble in the quill. Turns out the bearings are nothing more than a pair of holes in the casting, each having around 1/4" bearing surface and being maybe 2.5" apart - the chuck/arbor seems rock solid (surprisingly). I didn't fancy sawing through the casting and inserting a cross-wise screw to tighten the bearings (as some websites suggest) but inserting a 3" ribbon of 2 thou shim steel before returning the freshly greased quill has made an enormous difference; there's no play in it at all and the shim seems happy enough to stay in situ as the drill is used (I've left a good length sticking out the front just in case it does start to sneak inside during use!). I've only ever used shim for packing up lathe tools etc, it never occurred to me it would work in this way - maybe the tip will help someone else with cheapo-drill-wobbles! Paul |
Thread: Tin openers |
27/02/2017 16:07:42 |
Posted by Clive Haynes on 27/02/2017 15:17:36:
You can mount the can in a 3 jaw and part the lid off or an angle grinder works well. Power hacksaw and lick up the dribbled contents might be less messy than parting off - you might get extra iron in your diet too! |
27/02/2017 12:49:14 |
Posted by Cornish Jack on 27/02/2017 11:55:34:
Possibly the prime example of the late Sam Goldwyn's mangled edict - "Simplicate and add lightness" rgds Bill I like that but never heard it before, so had to look it up: https://en.wikipedia.org/wiki/William_Bushnell_Stout |
27/02/2017 11:43:17 |
Posted by Bob Stevenson on 27/02/2017 11:19:22:
we are basically a bunch of wealthy fat morons LOL, I don't qualify on any of those counts but I still buy the cheapies and chuck 'em; experience tells me that spending more on a 'better' one is not likely to be worthwhile. That said, there are enough posters in this thread who are obviously delighted with their openers. I suppose the moral is, just because you pay top dollar doesn't mean you're getting the best product. What sort of steel to use for the business end of a P38-style opener? |
26/02/2017 20:02:54 |
Posted by Anthony Knights on 26/02/2017 15:32:53:
You can't beat one of these. Made with good steel, at least 20 years old and will probably outlast me unless the wooden handle fails. My wife won't have one of those in the house since she sliced her thumb open on one 25 years ago! Must confess I always found that type difficult to use anyway. |
26/02/2017 11:48:51 |
Posted by daveb on 26/02/2017 11:25:51:
Three Men In A Boat by J K Jerome. Trying to open a tin of corned beef without a tin opener. Very funny indeed! Dave Almost as funny as the pre-trip packing and the fish at the inn - probably my most read book and no doubt will read it again. EDIT Never read the follow up, must do that too one day. EDIT Er, maybe I've read 'Red For Danger' as many times. Edited By PaulR on 26/02/2017 11:50:01 Edited By PaulR on 26/02/2017 11:51:17 |
26/02/2017 10:57:04 |
Posted by Clive Foster on 26/02/2017 10:43:45:
Been using a cheap side cutting one from WL Housewares for many, many more years than I care to admit. Apparently this :- **LINK** is the reincarnated version.
We've had two like that in recent years - one cost a few quid and the other was about a tenner; both kicked the can (rather than opened it) in no time at all. |
26/02/2017 10:27:36 |
Handy links: http://www.georgia-outfitters.com/images/p38plans.jpg http://patentpending.blogs.com/photos/uncategorized/p38_p51_can_opener_2.jpg Edited By PaulR on 26/02/2017 10:29:58 Edited By PaulR on 26/02/2017 10:31:19 |
26/02/2017 10:24:30 |
Posted by Danny M2Z on 26/02/2017 09:45:36:
When I was a digger the Australian Army gave me plenty of these **LINK** although my versions have a small spoon on the flat end. I have one in all of my fishing/hunting kits for when the 'ring-pull' rips away from the can without removing the lid. Another way to remove the lid of a tin of baked beans is to sit the can on the exhaust manifold of a Series 2a Landrover and drive about 50 km until the bang and the smell of baked beans reminds one that dinner is ready. Scrape it off the inside of the bonnet! This actually happened to me many years ago. * Danny M * LOL. I guess you could lick the underside then switch back to the top of the bonnet for your fried egg! I'd forgotten all about those US Army can openers, even easier to make I'd guess. |
26/02/2017 09:28:01 |
There's always this method I suppose, but I can't see it being very popular with the other half... |
26/02/2017 08:21:42 |
I've bought fancy ones in the past but always end up buying the cheapo ones and throwing them away as none of them seem to last five minutes. The 'engineering' of these cheap ones is very simple (no, 'crude' is the word) and it seems to me I could make one at least as bad. But how to make the toothed wheel and what material to use? Paul PS I've only just noticed that even these cheap ones are 'handed' - being a southpaw you get so used to the discomfort of all sorts of tools and utensils that you never think to question it. Remember the 60's and 70's wall-mounted and motorised versions - ah, the future never looked so good!
Thread: MEW 252 |
16/02/2017 13:10:00 |
Will you be putting something in #254 to cover the hole in #253? |
