sean logie | 07/12/2016 20:52:43 |
![]() 608 forum posts 7 photos | I tried aliminium for cutting my first thread but it was too gummy . So I thought I'd try stainless . Started of slow and easy and for the last two scratch passes I speeded up the lathe and it worked a treat . I took the chuck off tonight to check what tpi thread it was ,I'm a bit confused because there are two kind of half threads at either side of the full threads and I'm not sure which to count . The thread measured .50" across and I counted 4 full threads . Am I right in saying the chuck thread is an 8tpi ? Sean |
daveb | 07/12/2016 21:30:00 |
631 forum posts 14 photos | Buy yourself a thread pitch gauge, combined Metric/Imperial, not expensive and takes away the guesswork. A set of Zeus tables is very useful, lot of info about threads, they last well too, I paid 50p for mine but it was over 40 years ago Dave. |
Emgee | 07/12/2016 22:08:03 |
2610 forum posts 312 photos | Hi Sean, as suggested a pitch gauge would confirm the thread TPI but I would agree with you the 8TPI. Emgee |
Hopper | 08/12/2016 01:54:59 |
![]() 7881 forum posts 397 photos | If you tell us what lathe you have, someone here will doubtless be able to quote you chapter and verse of the thread specs involved. |
sean logie | 08/12/2016 06:22:19 |
![]() 608 forum posts 7 photos | This is not a thread to size,this is pick a setting and run with it . Lathe is Fortis/clausing E/801 /B Sean |
Ian S C | 09/12/2016 13:40:42 |
![]() 7468 forum posts 230 photos | Use your 6" steel rule, and if in 1/2" you count 4 threads, that would be 8 TPI. Ian S C |
Michael Gilligan | 09/12/2016 14:23:00 |
![]() 23121 forum posts 1360 photos | Posted by Ian S C on 09/12/2016 13:40:42:
Use your 6" steel rule, and if in 1/2" you count 4 threads, that would be 8 TPI. . But do remember that when counting the crests, or the troughs, you are starting at zero ... It's a bit like counting 'fence panels' MichaelG. |
