JasonB | 03/12/2016 08:01:23 |
![]() 25215 forum posts 3105 photos 1 articles | Could one of the forum electrical wizz kids please tell me where the loose yellow wire bottom left is meant to go?
A few more interesting installations for your enjoyment in this article |
Andrew Johnston | 03/12/2016 08:18:17 |
![]() 7061 forum posts 719 photos | Well there's a turn up for the books - I didn't have you down as a Daily Mail reader. Is Fred Bassett still going? Andrew PS: It's not for me to tell people where to stick the wire, at least not on a public forum. |
Clive Hartland | 03/12/2016 08:51:19 |
![]() 2929 forum posts 41 photos | That did not just blow, it looks as if they launched a rocket in there. That is all just so wrong! Clive |
Howi | 03/12/2016 09:11:37 |
![]() 442 forum posts 19 photos | Loose yellow wire meant to go? Stick it anywhere, the previous 'sparky' obviously did with the rest of the wiring. |
Martin King 2 | 03/12/2016 09:15:11 |
![]() 1129 forum posts 1 photos | Looks OK to me! Which is probably a good reason I passed my Mill PCB problem to a higher authority! Martin |
Rick Kirkland 1 | 03/12/2016 09:38:40 |
![]() 175 forum posts | That is a total threat to life. Whoever put it together needs executing by electrocution from that very wiring. I do not often post in this forum these days but THAT really has got my blood boiling. Whoever did it for you is obviously trying to kill you, someone else, or burn something down. As an electrician I'll say that if it's a joke then my warped sense of humour allows me to laugh out loud. If it's not a joke my advice as an electrician is BIN IT NOW BEFORE SOME ONE DIES OR THE PLACE CATCHES FIRE. If the supply company or the local building regs department got wind of that, well, , I've seen some bodging in my time but that REALLY tops it. IT IS A KILLER. |
Frances IoM | 03/12/2016 09:45:18 |
1395 forum posts 30 photos | there is a regular page full of this type of installation in the trade freebie Professional Electrician & Installer - vermin in switch boxes also a mention ! tho usually they are well cooked |
Speedy Builder5 | 03/12/2016 09:49:55 |
2878 forum posts 248 photos | This installation passed the home buyers survey here in France. |
Speedy Builder5 | 03/12/2016 10:00:14 |
2878 forum posts 248 photos | In the first picture (Jason's), I like the rusty nail to the left of the meter to stop it falling off the board ? And is it (was it) a 3 phase supply. Looking on the net, these are used in India ? |
JasonB | 03/12/2016 10:18:49 |
![]() 25215 forum posts 3105 photos 1 articles | Rick, don't worry it is not the back of my far eastern lathe, just a pic from the article I linked to. Speedy, article says its from an office in Madras, not sure if that rusty nail is to stop the meter falling off or if it is the "terminal" for the yellow wire |
Brian Wood | 03/12/2016 10:34:05 |
2742 forum posts 39 photos | When we bought our present house 17 years ago, after finding live earths on a clutch of power sockets, the subsequent exposure of a whole raft of other faults from years of amateur additions were child's play compared to these awful examples. |
John Haine | 03/12/2016 10:56:29 |
5563 forum posts 322 photos | Recently had a new consumer unit with MCBOs for each circuit "professionally" fitted. Interesting issue with the lighting circuits tripped every morning - no sign of leakage or any problem when tested during the day or in the evening. Discovered the immersion heater, fed from Economy 7, connected to the lighting circuit!
Neil Wyatt | 03/12/2016 11:59:18 |
![]() 19226 forum posts 749 photos 86 articles | In Spain for Christmas many years ago, the mains fairylights outside the Town Hall were strung together using chocolate blocks and draped across the palm trees. |
Steven Vine | 03/12/2016 12:14:58 |
340 forum posts 30 photos | In that first picture, the meter and fuse carriers not being straight is a bit of a let down. I had to change the consumer unit a few of years ago. After 20+ years of use, one night the main switch fizzed and buzzed for about 10 minutes, flashing the lights on and off, and eventually welded itself open. As I was prepping up the wires for the new consumer unit, I was puzzled by the two lighting cables going into one mcb. I discovered that one cable was only a meter long, and the other end of it was just stuffed into the cavity, between the inside and outside walls, without so much as a piece of insulation tape on the end of it! The house was wired in 1990. Steve
Nicholas Farr | 03/12/2016 12:31:47 |
![]() 3988 forum posts 1799 photos | Hi, I reckon the loose wire is from someone who hasn't paid their share of the electric bill, so have been cut off. Regards Nick. |
Raymond Anderson | 03/12/2016 12:50:43 |
![]() 785 forum posts 152 photos | A few Burn marks in Jason's pic but none in Speedy Builder5's pic. So that must mean the the French sparkie got it spot on Rats nest springs to mind in both of them. Reminds me of the time when the Dike of Edinburgh opened a new factory a few years back, he was shown a big fuse box and remarked "my god , you would think it was an Indian the wired that up " And lo and behold it WAS !!... a Sikh Nothing unusual in the Duke putting his foot in it. |
Ajohnw | 03/12/2016 13:17:14 |
3631 forum posts 160 photos | Looks like the reason I always have a neon test screwdriver around - even in the uk. Also check inside plugs on used items - the other end too at times. Apparently the biggest single cause of fires is electrics. Hence the recent rules on the subject and it seems the need to pass an exam where you can take your books in with you. Suppose it indicates some literary skill and the ability to do some simple sums.
John - |
JasonB | 03/12/2016 13:24:07 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Neil Wyatt on 03/12/2016 11:59:18:
In Spain for Christmas many years ago, the mains fairylights outside the Town Hall were strung together using chocolate blocks and draped across the palm trees. That is bad practice, everyone should know that the heat in spain melts the chocolate |
An Other | 03/12/2016 14:06:39 |
327 forum posts 1 photos | That picture looks familiar. We have similar installation here in Romania. Normally here there is no earth system just L/N. Neutral is supposed to be at earth potential, but usually isn't. Since most 3-core cable also comes with the standard green/yellow conductor, that gets used by the 'Electrician' for anything he likes, so it may be live. The colour codes are irrelevant - any electrical system is wired up using whatever colour cable the guy has - often all one colour. No ELTs, although we do have 'overload' trip switches, which usually don't. We paid for a new mains connection to our newly built house (thats another story!), and the computer (E**L) fitted the latest hi-tech LCD display meter in a sealed box on a pole at the end of our drive (about 150 metres from the house). This box also contained a trip switch of some kind. After everything was connected up, I spent days trying to find out why this switch tripped out repeatedly. I could reset it, and by the time I had walked back to the house, it would have tripped again. Very worried, because the builder had buried some of the internal house cables under a concrete floor. Eventually I asked E**L to take a look - they told me it was fitted with the latest type of 'Brown-out' switch - if the voltage surged or dropped, then this switch would drop out. This is Romania - voltage can be anywhere between 200 and 260 volts AC, so eventually I persuaded them (bribed them) to remove the switch. Since then, all has been OK (relatively). It is also not uncommon to find open bare wires connected to live mains - I have a second house on my property, and the incoming power arrives on bare aluminium wire to two plastic terminals (L/N) on the outside wall of the house. They are wrapped around the terminals, then simply buried in the plaster wall down to the meter (which once again, is a relatively hi-tech digital effort. I asked them to remove the meter (house not used), so they simply cut one of the wires out of the meter to a distribution box. Then I noticed the meter was still reading consumption of electriciy - about 10 kwH in two months. Now fed up, so I climbed up the wall wearing rubber boots and rubber gloves, and put an axe through the incoming cables. - I know, don't tell me, but desperation plays a major part in any dealing with companies in Romania, particularly a monopoly like E**L. Needless to say, I have no faith in so-called 'professionals!' |
