Electrical fault on X Feed PCB?
Martin King 2 | 20/11/2016 09:57:44 |
![]() 1129 forum posts 1 photos | Hi All, I realy should not be allowed near anything electrical! I have a power X axis feed on my Warco 18 Mill which I got in a clearance from Axminster a while ago, made the bracket etc and installed it. Worked just fine and tranformed the machine into something a pleasure to use. I did not need and did not fit the Limit Switch unit and just coiled it out of the way. After a while there was an intermittent fault where the feed would only work one way and not the other. This turned out to be a dry joint in the limit switch box which was fixed by giving it a 'wiggle'. Worked for ages after that. I removed the small switch buttons to stop them accidentally getting knocked. Yesterday I was using the mill all morning just fine, then dropped something and jarred the limit switch which brought the fault back so thought I would fix it once and for all and resolder the joint properly. STUPIDLY I did this wihile the mill was still connected to the mains! Small puff of smoke from the joint , fuse in unit blown, me VERY angry. Changed the fuse but now nothing works at all on the feed unit. Have tried the limit switches in all possible positions but no go. The board is marked SIEG MACHINE and does not appear to have any black or sooty spots on the front, have not looked at the back as noit easy to get to. HELP NEEDED please! I think the unit is now discontinued but I know SIEG is still around. Regards, Martin |
Les Jones 1 | 20/11/2016 10:34:47 |
2292 forum posts 159 photos | Hi Martin, Les. |
Clive Foster | 20/11/2016 11:14:09 |
3630 forum posts 128 photos | Looks to be a fairly basic DC motor variable speed drive board with integrated switch mode power supply. If worst comes to worst functional replacements can be found not too expensive although you may have to accept a separate power supply and do some case mods to fit. Just need the motor data to match board to motor. That said I'm surprised that being plugged in whilst you soldered popped a component. Normally limit switches and the other controls would be on the driver side downstream of the power supply and thus isolated from any mains connections. Good practice is to make anything involving limit switches robust and short circuit proof in case stuff gets in. UM, you did turn it off first didn't you? Clive. |
Russell Eberhardt | 20/11/2016 11:31:19 |
![]() 2785 forum posts 87 photos | The big resistor in the middle of the board looks rather cooked I would check that but the most vulnerable part is probably the little transistor next to the connector for the limit switches. Do you have the ability to check it? Russell |
John Rudd | 20/11/2016 11:39:29 |
1479 forum posts 1 photos | Les, looking at the components and the layout, I'd say the controller is probably based on the later XM series of speed controllers.....the clue I think is the small toroidal transformer adjacent to what I think are the thyristors....the big 6A diodes forming a full wave bridge with the scr's.....the design is based on the KB series of controllers Ah, just seen the label on the board, it is an XMT 2315..... @ Martin If there are no visible signs of blown components, then I'd be looking at blown copper track....weakest link and all that....then start cold testing
Any thoughts Les? Edited By John Rudd on 20/11/2016 11:41:36 |
John Rudd | 20/11/2016 11:44:28 |
1479 forum posts 1 photos | I've just looked on Arc's website and Ketan is listing spare boards for £88..... http://www.arceurotrade.co.uk/Catalogue/Machine-Spares/SX1-Spares/SX1-121B-Main-Control-Board-XMT2315230v |
maurice bennie | 20/11/2016 11:45:32 |
164 forum posts 1 photos | Hi Martin ,Have you checked the mains and plug fuses ? |
John Rudd | 20/11/2016 12:24:21 |
1479 forum posts 1 photos | Martin, I have a schematic for the KB boards, the component references will be different, but at least you wont be working totally blind.... Les has a schematic which he drew out,( again the Sieg boards used the orig KB desing) the later XM boards used on the X3 mill, again the schematic will help even if the component designations differ.....
Les Jones 1 | 20/11/2016 13:38:21 |
2292 forum posts 159 photos | Hi John, Les. |
John Rudd | 20/11/2016 14:13:04 |
1479 forum posts 1 photos | Posted by Clive Foster on 20/11/2016 11:14:09:
That said I'm surprised that being plugged in whilst you soldered popped a component. Normally limit switches and the other controls would be on the driver side downstream of the power supply and thus isolated from any mains connections. Good practice is to make anything involving limit switches robust and short circuit proof in case stuff gets in. UM, you did turn it off first didn't you? Clive. The two scr's and two of the the big diodes form a full wave bridge rectifier circuit.....The 0v rail on circuits like these are actually at half mains voltage wrt earth....so connecting an earthed soldering iron is likely to pop some thing..... I speak from experience.... |
Les Jones 1 | 20/11/2016 18:11:52 |
Martin King 2 | 20/11/2016 18:26:20 |
![]() 1129 forum posts 1 photos | Hi Les, "Martin does not seem to have respect for the dangers of mains electricity." Not lack of respect but shear forgetfullness and stupidity, in a hurry to get on etc, hence in thread title Mea Culpa. My location is South Dorset Mains plug fuse OK and replacement fuse all OK. Russell: I do not have the skill to check this sort of thing and clearly a little knowledge is dangerous. Way out of my depth here! Would anyone be interested in me sending them the board to look at and I would be happy to pay for any repairs and time and postage etc? Regards, Martin |
Martin King 2 | 20/11/2016 18:29:10 |
![]() 1129 forum posts 1 photos | I will remove the board tomorrow and post pic of the back side |
John Rudd | 20/11/2016 18:36:17 |
1479 forum posts 1 photos | Martin, check your pm box |
Martin W | 20/11/2016 19:00:19 |
940 forum posts 30 photos | Martin When you tried the unit after replacing the fuse did any of the lamps on the front panel light. While it is not really helpful Aussee Machine tools have a spare board priced at about $146. Martin |
Martin King 2 | 20/11/2016 19:47:08 |
![]() 1129 forum posts 1 photos | John R, PM sent
Les Jones 1 | 21/11/2016 08:56:04 |
2292 forum posts 159 photos | Hi Martin, Les. Edited By Les Jones 1 on 21/11/2016 09:21:26 |
Martin King 2 | 21/11/2016 16:55:22 |
![]() 1129 forum posts 1 photos | Marti W - no lights at ll when powered up. Have taken some more pics as requested, many thanks to all for helping me out here, Paul L in Australia has kindly sent me some manuals and wiring diagrams, looks like Finnish to me These show the small labels, I have turned them round the best I can. Wider shot as requested, tried to move some of the wires to make it clearer. ditto back of board, no damage that I can see? Martin |
I.M. OUTAHERE | 21/11/2016 17:06:09 |
1468 forum posts 3 photos | R35 appears to be missing ( bottom photo , bottom left edge - 5th component from left ) although it may have not been used in the circuit you need to look at the the schematic to find out . |
Les Jones 1 | 22/11/2016 09:18:50 |
2292 forum posts 159 photos | Another forum member has kindly provided martin with a PDF of the Grizzly H8178 table feed which looks to be the same unit as Martin's. (This is a link to this manual) If Martin's unit wired in the same way as the diagram on page 21 of the Grizzly manual then the power light should be on no matter what the fault is on the controller board. (Is should be on even if the fuse has blown.) We need to get Martin to check the wiring from the 13 Amp plug to the unit to investigate this first. The bad news from this diagram is that the limit switches are not connected between the reversing switch and the motor as I had suspected. (If this had been the case then two diodes and two SCR may have been damaged that would be easy to replace.) It is connected (via a set of changeover contacts on the reversing switch) to the control input on the board that would be connected to the interlock switches when the board is used in a lathe. Looking at the last of Martins pictures posted at 16:55 on Nov. 21 it looks similar to the speed controller used on the X3 mill. Both use a dual and a quad op amp and both use phase angle control with an SCR half bridge. You can compare the pictures of Martins board with the pictures on my website of the board from my X3. This page includes the schematic I traced out of the X3 board. I think it is a reasonable assumption that Martin's board will be very similar. If so connecting mains earth (Which will be at almost the same potential as mains neutral.) will have injected - 300 volt pulses into the low power electronics every half cycle when live was positive with respect to neutral. I think this is likely to have destroyed a reasonable number of components which may make repair of the board uneconomic. If it is the same as the X3 board which is coated in a thick varnish it will make it difficult to replace SMD components. It would probably also be necessary to trace out the schematic of the board first to aid logical fault finding. Les |
