DEREK SPEDDING 1 | 10/11/2016 21:01:03 |
8 forum posts | I have a Hobbymat milling machine that i obtained about 20 years ago. Done loads of mods on it and it works fine for what I need it for. The only thing that has hacked me off is that the Y axis motion is in the opposite direction to what I would say is normal. I have not used a miller since I was an apprentice almost 50 years ago. Can I ask what is the norm for them. On the Hobbymat turning the feed handle clockwise moves the table outwards toward the operator which is opposite to normal lathe convention. Things came to a head the other day when I scrapped an casting so I ordered a Y axis leadscrew that fit a Sieg mill.intending to doctor it to fit the hobbymat thinking it would be a left hand thread. It arrived today and that is also a right hand thread. I am beging to think I am loosing it. So can anyone tell me what direction the table moves when turning the handle clockwise. Thanks Derek |
RobCox | 11/11/2016 08:38:56 |
82 forum posts 44 photos | I think my SX2 has a left hand thread on the Y axis. The DRO is set up so that the tool moving away from the operator relative to the workpiece, ie workpiece moving towards the operator, is a movement in the positive direction. To achieve this the handle is rotated counterclockwise - that I think makes it a left handed feed screw. The littlemachineshop website indicates that x axis nuts are RH and y axis LH for the X2, so that seems to confirm this. Your Hobbymat would appear to have a RH feedscrew - opposite to the Sieg. Rob |
Peter Krogh | 11/11/2016 08:46:13 |
![]() 228 forum posts 20 photos | I have never seen a mill, or lathe, where turning the handle clockwise moves the table towards the operator. Pete
Michael Gilligan | 11/11/2016 09:12:51 |
![]() 23121 forum posts 1360 photos | It depends how the nut and screw are configured
A diagram or photo of the Hobbymat slide would be useful. MichaelG. |
colin hawes | 11/11/2016 14:01:39 |
570 forum posts 18 photos | It is normal to have a left hand thread on machine tool's X and Y axes so that clockwise rotation moves the table away from you. Colin |
Neil Wyatt | 11/11/2016 14:10:24 |
![]() 19226 forum posts 749 photos 86 articles | The hand of the leadscrew depends on whether the nut or the handle is fixed to the moving part. For example on the X2 the Y handle is fixed to the base, the X handle is attached to the table. Neil |
DEREK SPEDDING 1 | 11/11/2016 14:16:47 |
8 forum posts | Thanks Chaps. Its all clear now why the new leadscrew I bought is no use. My table is configured with the nut riding on the screw and the screw is in bearings at each end. I had expected to be supplied with a LH screw. The Hobbymat has been built with a RH thread for some reason. I should have dealt with this years ago as going from turning something on the lathe and then using the mill I had to think twice which direction i turned the handle. Been looking without success now for a LH screw 2mm pitch 12 or 14 mm Dia. Its looking like I am going to have to make one myself.
Thanks Again. Derek
Manofkent | 11/11/2016 14:19:45 |
145 forum posts 29 photos |
All rather strange. I have a Hobbymat mill and have just checked. Turn the Y axis handle clockwise and it moves in towards the column. Mine is based on the BFE 65 head. John
Jon | 11/11/2016 15:00:02 |
1001 forum posts 49 photos | Seen it a few times on home made tools but never any commercial item. Derek just re arrange the leadscrew and nut/s
Michael Gilligan | 11/11/2016 15:04:42 |
![]() 23121 forum posts 1360 photos | Derek, Try looking at Marchant Dice : **LINK** http://www.worldofcnc.com/collections/trapezoidal They sell very reasonably priced Trapezoidal leadscrew 'by the 100mm' Link above is to the web-shop, but they also list on ebay. MichaelG. |
DEREK SPEDDING 1 | 11/11/2016 18:19:06 |
8 forum posts | I can only assume that the table was one of the first they built and corrected the problem on later ones. Tried to link to a video that I took just to prove Im not going crazy but was unable to create the link on here. However Jons idea sounds interesting, I will give it some thought. but will entail building out the travelling bed by about 6" . Humm. The other thing I had been toying with was to offset the handwheel and add 2 gears. This would automatically reverse the operation but would add more backlash and probably loose a bit of "feel". Will post back when I resolve it.
Derek |
DEREK SPEDDING 1 | 11/11/2016 18:50:52 |
8 forum posts | Thanks for that. . Helical gears are a good idea , an improvement on what I was thinking of. Can anyone point me at a good source? |
duncan webster | 11/11/2016 20:43:38 |
5307 forum posts 83 photos | If it has a large number of teeth I reckon straight gears would be OK, but remember that if you move the graduated dial it will be reading the wrong way (or perhaps it reads the wrong way now!) For suppliers look at HPC in Chestefield **LINK** or Reliance gears in Huddersfield **LINK** I've used both in the past an been well satisfied. Second hand change wheels would be cheaper |
Neil Lickfold | 11/11/2016 21:37:04 |
1025 forum posts 204 photos | It all depends on the Mill. Some have LH leadscrews and some have RH leads screws. Neither is wrong. I have seen geared cross slides on mills, where it is 1:1 and then 10:1 to get the precision. A lot of machines with Ballscrews with a clockwise handle turn brings the table to the operator, so the cutter is effectively in the plus direction from the operator. Similar on the LH end of the mill, a CW handle movement is the Cutter effectively in the positive direction. Neil |
DEREK SPEDDING 1 | 17/11/2016 22:36:56 |
8 forum posts | Thanks for all the advice. After carefull thought I took the path of least resistance and went for the gear option. I had some 40mm dia fine tooth gears from a big industrial stapler taken of a printing machine.. I built a gearbox using shafts running in ballraces.. Just finished it today and it works a treat. Should have done this years ago..
Derek |
