Opinions on low cost scopes
Speedy Builder5 | 30/10/2016 18:04:23 |
2878 forum posts 248 photos | I am thinking of getting an oscilloscope to help me debug the analogue and digital inputs for a BBC Microbit (Similar to Raspberry PI). The following bit of kit seems fit the bill, using a Pc as the display device, but what do the team think ?
Martin Connelly | 30/10/2016 18:15:16 |
![]() 2549 forum posts 235 photos | Velleman EDU09 is a USB oscilloscope kit that may meet your needs at a low cost. Martin |
Mike Clarke | 30/10/2016 18:31:39 |
![]() 95 forum posts 2 photos | Hi. I am a fan of Picoscope USB scopes. The software is very good and continually improved across the entire range. Quite expensive to buy normally but they often have flash sales via their eBay store......so if you're interested save a search on eBay and keep your eyes peeled. I had a Velleman at uni and it was great, but the Picoscope offers so much. The print feature alone is worth the £££ for me. Cheers, Mike |
Neil Wyatt | 30/10/2016 18:50:47 |
![]() 19226 forum posts 749 photos 86 articles | Ideally at least two channels and make sure it can sample significantly faster than the signals you want to measure. Other than that even the most basic scope can be incredibly useful. |
SillyOldDuffer | 30/10/2016 19:13:47 |
10668 forum posts 2415 photos | Not tried it myself but the negative reviews on Amazon are a concern, for example: "This is a super affordable (and hence basic) DSO. Despite pocket change price it's not a toy but a rather functional device. Probably 10 years ago you would need to shell out at least a grand for a similar device. Heck, my fist oscilloscope was analog, weighted about 25 pounds and had one channel with 1 MHz bandwidth. Sure, it had an external sync input which I used may be two times in 10 years or so and mains sync which I think I never used... Update 05/25/2013: apparently driver is signed but missing some things needed to work on Windows 8 64 bit: .cat file. http://stackoverflow.com/questions/10832499/workaround-to-skip-driver-signing-in-64bit-windows First, edit the INF file and add these lines to the [Version] section: DriverVer=05/25/2013 Then proceed with CAT file creation and signing as described in the link. Do not sign .sys files, they are already properly signed." That review is from 2013 and it's possible things have improved since then. Alternatively, this one (also from Amazon) gets less flak and is a bit cheaper. For £50 with a money back guarantee you can hardly go wrong. Even a basic scope is better than no scope at all. Dave |
Geoff Theasby | 30/10/2016 20:59:52 |
615 forum posts 21 photos | Martin, the EDU09 only goes to 150 khz. There are 1 MHz kits from China and Quasar Electronics for £20 to £50. Geoff |
Neil Wyatt | 30/10/2016 21:06:07 |
![]() 19226 forum posts 749 photos 86 articles | It's worth getting one with an opto-isolated connection to the computer (and its own power supply) you really don't want to stuff 240V down a USB cable into your 'puter. |
Russell Eberhardt | 30/10/2016 21:19:46 |
![]() 2785 forum posts 87 photos | You might like to have a look at the Bitscope Micro as an alternative. It will act as an 8 bit logic analyser as well as a dual channel scope. I have one to compliment my Siglent scope. Russell. Edited By Russell Eberhardt on 30/10/2016 21:20:54 |
Neil Wyatt | 30/10/2016 21:38:28 |
![]() 19226 forum posts 749 photos 86 articles | Lots of people say these are very good, and no computer needed... You can get CNC machined acrylic cases for about £5 |
Enough! | 31/10/2016 00:05:50 |
1719 forum posts 1 photos | Posted by Neil Wyatt on 30/10/2016 21:38:28:
You can also 3D print one (look on Thingiverse). |
Geoff Theasby | 31/10/2016 04:11:10 |
615 forum posts 21 photos | Yes, Neil, that's the sort of thing. Beware though, some of these kits are counterfeit. I gather (no guarantees!) that the authentic ones are by JYE Tech. They are not much more, see their website, or Google 'DSO138'. I'm told the real ones have 'JYE Tech' screen printed on the PCB. This one doesn't... Geoff |
Russell Eberhardt | 31/10/2016 09:44:15 |
![]() 2785 forum posts 87 photos | Note also that the bandwidth is only 200 kHz. Not much use for anything above audio frequencies. Russell. |
SillyOldDuffer | 31/10/2016 10:04:27 |
10668 forum posts 2415 photos | Posted by Geoff Theasby on 31/10/2016 04:11:10:
... I'm told the real ones have 'JYE Tech' screen printed on the PCB. This one doesn't... Geoff Did you spot that the Amazon oscilloscope review I quoted mentions "radio armature needs". I suppose a 'radio armature' must be one of those pirates. Perhaps using counterfeit equipment doubles the thrill obtained from unlicensed wireless naughtiness. 10-4 good buddy Dave |
Muzzer | 31/10/2016 10:56:40 |
![]() 2904 forum posts 448 photos | You can get a pretty decent "proper" 50-100MHz dual channel scope for £200-250. One of the boys on here recommended a Siglent model which I bought and have been very happy with. Pretty much a clone of a Tek TBS1052 at almost half the price. Horses for courses but you get a whole load of features for the money - check out the features. |
Ian Parkin | 31/10/2016 11:01:14 |
![]() 1174 forum posts 303 photos | I recently (3 months ago ) bought the pc based one you linked to in the OP it installed but it was a bit of a faff so I sent it back and bought the New Hantek DSO5102P USB Digital Storage Oscilloscope 2CH100MHz which is far superior as a stand alone unit. I also have the DSO 138 kit scope which i tend to use on site jobs for checking encoders etc great little thing for £16 ish |
Ajohnw | 31/10/2016 11:11:41 |
3631 forum posts 160 photos | You can get an idea of what the spec of truly decent ones should be from here The sample rate should be around 10 times the analogue bandwidth or more to be pretty sure you are actually seeing what is there. I have one of their 11bit units. The CGM101. It's a bargain price for that. Try Pico as an alternative. It works rather well too. That type is mostly aimed at audio stuff though. Last time I looked some of the Pico usb scopes were far more reasonably priced and do have sensible specs. I did have the Vellaman one once. It just packed up one day. You should know what frequency range you want to look at and personally I wouldn't touch a 20mHz scope with a sample rate of 48mb/sec which is probably only that when one channel is in use. For the sort of use you intend I would also make sure it has a roll mode. I'd suggest looking for the bandwidth you need and sensible sampling rates to match. The bandwidth does need to be higher than the signal if you want to make accurate measurements. They usually state the - 3db bandwidth so a factor of 2 on that isn't a bad idea. When I bought the syscomp unit they did use USPS for shipping but took some persuading. Worth mentioning if some one does buy from them as the cost difference over say FedEx is pretty dramatic. John - Edited By Ajohnw on 31/10/2016 11:17:07 |
Alan Wood 4 | 31/10/2016 11:27:43 |
257 forum posts 14 photos | Rigel products are excellent both scopes and spectrum analysers but again not as low cost as Pico. |
Neil Wyatt | 31/10/2016 12:26:03 |
![]() 19226 forum posts 749 photos 86 articles | My own scope is a Hameg, dual trace notionally 50 meg but being analogue you can always push it a bit Only used a few times a year but invaluable when used - definitely repaid it's £30 s/h many times over. I've shown my BBC Beeb Scope before (it uses a fast (for its time) A2D chip: Neil. |
Geoff Theasby | 31/10/2016 16:06:42 |
615 forum posts 21 photos | Just downloaded this last week. Not tried it yet. http://xoscope.sourceforge.net/ Geoff |
Ajohnw | 01/11/2016 13:00:03 |
3631 forum posts 160 photos | Posted by Neil Wyatt on 31/10/2016 12:26:03:
I used an ATTEN AT7025D before that. 25mhz 100 meg samples per sec. So 4 sample per period at 25mhz but 8 up to 12.5mhz. It's usable but doesn't have a roll mode which is a pain if looking for low frequency signal drop outs. Roll mode usually comes in at 100 msec / division and gives a continuous display. It is a real time scope. Some I believe aren't and work in a similar way to a sampling scope which need repetitive stable signals. The scope was/is in the classified on here. John - |
