12tpi x 1.1/2"
OuBallie | 20/10/2016 16:36:22 |
![]() 1181 forum posts 669 photos | It's been a while since I last posted, BUT I've achieved a landmark in using the lathe. Chuck back plates Ideas on a replacement waisted spring pin design please. To I panicked a little, as expected following on from my first episode, and instead of pulling the clutch lever to disengage motor, I made a grab for the Feed Shaft lever to disengage the Feed Rod. With the Carport at 27°C & 80% humidity during September, it just wasn't conducive to working on the Austin Seven, so Workshop time. I wasn't in the mood to remove the Apron once again, to look inside, so settled on finish machining the backplates in 'manual' mode. This meant doing some screwcutting in the lathe for the first time believe it or not, as I've been able to get away with using taps and dies till now, and quite frankly funking the very thought to boot.
OuBallie | 20/10/2016 16:48:04 |
![]() 1181 forum posts 669 photos | continue/ Fun and games ensued checking the diagrams printed on the side cover of the lathe as to what change wheels where needed and where, then finding that NONE where marked with number of teeth, so had to count and stamp each one.
Found the toolbit I used to trepan the thick plastic from 'Oompa Lumpa' to make holders for Angle Eye lamps I made to fit round the spindles of the the Mitco and Marlow, and soon had both done. Chuck mounting holes drilled and tapped. Chucks mounted on the Vertex.
The Marlow spindle speed has subsequently been increased Geoff - Hopefully back working on the Austin tomorrow.
Neil Wyatt | 20/10/2016 21:26:35 |
![]() 19226 forum posts 749 photos 86 articles | Blimey Geoff, back with a bumper crop! |
Harry Wilkes | 20/10/2016 21:56:34 |
![]() 1613 forum posts 72 photos | All good stuff well done !
H |
Nick_G | 20/10/2016 22:02:36 |
![]() 1808 forum posts 744 photos | . Good man.
Nick |
mechman48 | 20/10/2016 22:18:16 |
![]() 2947 forum posts 468 photos | Good job Geoff, nice pics. George. |
OuBallie | 21/10/2016 10:53:44 |
![]() 1181 forum posts 669 photos | Thanks for the kind comments. Remembered how to do YouTube links, surprising myself to boot. Trepanning using the Dividing head: Geoff - Carport here I come. Edited By OuBallie on 21/10/2016 10:55:20 |
Michael Cox 1 | 21/10/2016 11:20:58 |
555 forum posts 27 photos | Hi Geoff, Brilliant stuff. Mike |
