Ian Parkin | 19/10/2016 10:14:07 |
![]() 1174 forum posts 303 photos | My daughter and her husband recently bought a new house to them a pretty ordinary 1930's 3 bed detached in a suburb of Sheffield I was amazed to see that they had 3 phase to the meter area and yes they are live How many others have 3 phase at home? |
Emgee | 19/10/2016 10:23:44 |
2610 forum posts 312 photos | Ian, not so unusual as the supply companies used to install 3 phase supplies to properties with off peak heating loads that could not be supplied by a single phase 60A supply, not so common these days with less people using such systems. Emgee Edited By Emgee on 19/10/2016 10:24:16 |
Ian Parkin | 19/10/2016 10:30:49 |
![]() 1174 forum posts 303 photos | I did wonder if that's what it may be for but there's 3 100 amps here. |
Ajohnw | 19/10/2016 10:41:28 |
3631 forum posts 160 photos | Houses are generally powered from 3 phase but only one phase for each. I've been told that in older houses in B'ham that the 3 phase supply is very often taken to the house but the wires may not be clearly visible. Our house was owned by 2 spinsters who wanted separate bills so one floor is powered on one phase and rest on another phase. Annoying as we have to pay 2 standing charges. Same with gas. If I looked closely I might find that the 3rd phase is there as well as the house was fitted with economy seven. Fitted by cegb. Did they use the usual 13 amp cable for wiring it - no, 'cause a lighter cable is cheaper. Personal beef as I could have used it for 13 amp spurs then. It's an interesting area - houses have been built for a long time now that couldn't feasibly be heated and powered from a single phase. We import a lot of gas for heating. Maybe all 3 phases are near the meters but some how I doubt it as the builders will have wanted to save on cabling. People with older houses that also need more heating might not have a problem - if electricity ever gets costs effective. If 3 phase isn't easily available there will be a hell of a problem one day. John - |
Brian H | 19/10/2016 10:46:20 |
![]() 2312 forum posts 112 photos | The last house I moved to had 3 phase built in as I found when I opened the meter cupboard and saw three 400 amp fuses. I 'phoned the electricity company to confirm and was told that every third house has 3 phase but they didn't know why. I got an electrician to run a supply out to the workshop/garage and sold my 1 to 3 phase converter. The houses were built in 1946. |
Neil Wyatt | 19/10/2016 10:54:21 |
![]() 19226 forum posts 749 photos 86 articles | We have two 80A fuses, both on the same phase, one for the house, one for heating. 1937 but a more modern installation. Neil |
SillyOldDuffer | 19/10/2016 11:14:53 |
10668 forum posts 2415 photos | I have a single 100A for both house and heating (1971). The single phase is tapped off one of the 3-phases on a pole 10 metres away. I think it would be cheap and easy for me to get 3-phase, but - Sod's Law - I 'm unlikely to ever want it. My previous house would have been costly to upgrade to 3-phase. All the cables were buried and came from a substation at the end of the road. Does anyone know if adjacent houses are on the same phase or not? Could be 'interesting' if my neighbour and I both ran extension cables to a shared job! Dave
Ajohnw | 19/10/2016 11:34:03 |
3631 forum posts 160 photos | Must admit I don't know what they are doing with the supply to new houses now. My comments were based on lots built from the mid 50's and if I recollect correctly 60 amp fuses. I dom't know what cable ratings they used to the house. The reason we ditched economy 7 is that the house has to be heated all day. To do that with the storage heaters they fitted we had a boost mid day at the same price. The gas bill was a hell of a lot cheaper after it was installed. That was done sensibly though. The boiler needs changing now. Currently it has a small heat store for hot water. Big enough to fill a bath and the water will cool after that but be back up to temperature 4 mins later. Usable well before that. These days they would have me fit a massive heat store. If that cools it will take a long time to heat up. John - |
Brian Wood | 19/10/2016 11:37:12 |
2742 forum posts 39 photos | Hello Dave, The local farmers bullocks brought down the overhead power pole crossing the field which tore the neutral cable in half, leaving these wretched beasts to chase a sparking snake about in the field. We suffered serious collateral damage in the incident, all the lighting went pop, electronic equipment actually in use fried and fridge motors ran at insane speeds before burning out We of course had been acting as the return path to the full load of her cooker and with the inter phase voltage of ~380 volts running through everything we had switched on.
Nick_G | 19/10/2016 11:37:52 |
![]() 1808 forum posts 744 photos | . It was very common at one time to bring 3 phase into all the houses in a street. The 'cut out' as they are know to the supply authorities (the block that holds the main fuses) would have a single phase then tapped off to the meter. The next house would be on a different phase and the next house again would be on the third phase ........... And so on down the street. - This would in theory keep the supply cable phases 'reasonably' balanced in load. Nick |
Emgee | 19/10/2016 11:48:27 |
2610 forum posts 312 photos | Dave, adjacent properties were normally connected on different phases to assist with a balanced load across phases. Neil, does your supply have 3 lines coming in ? if you are in a rural location could be 2 lives and a neutral, same phase but 480volts between the 2 live conductors. Emgee Nick beat me to it !!
Edited By Emgee on 19/10/2016 11:49:33 |
Roger Hulett | 19/10/2016 11:55:47 |
131 forum posts 9 photos | Many years ago I lived in Scotland. There was a 3phase supply to one of each pair of semis,with one phase going to the adjoining house. Unfortunately I didn't know that,and whilst trying to establish why I had so many wires in the box managed to "blow" the whole street's power supply ! |
Ajohnw | 19/10/2016 12:00:07 |
3631 forum posts 160 photos | I made another change to the heating that seems to have cut costs. I fitted a wireless thermostat in the lounge. No thermostat in the room that has the small uncontrolled radiator in it for boiler over run. Both rads in the lounge do have thermostatic valves fitted. It's cut down the "heat bounce" in the system so the boiler shuts down sooner. It seemed worth trying to me as that is where we need more precise temperature control. The bathroom with the over run rad does get a bit warm but not uncomfortably. It's possible to get boilers now that can have thermostatic valves fitted to all rads. John - |
Muzzer | 19/10/2016 13:42:23 |
![]() 2904 forum posts 448 photos | Almost certainly the presence of a 3-phase incomer indicates that the house used to have electric heating. There's not much else that would require such a large power capability, short of an industrial annexe. My parents' house in Harrogate had 3-phase when we acquired it in the mid seventies when it was about 10 years old. There was underfloor electric heating in all rooms (it's a large bungalow) and 3 meters in the garage. Resistance wires were simply run in steel conduits in a concrete slab sitting on polystyrene insulation. Obviously we ripped all of this out and replaced it with GCH. The 2 additional meters were removed not long afterwards. I expect you pay extra for the additional 3 phases, both installation of the meters and their rental, so even though the connections are there, making use of them might be a bit extravagant for hobby use. |
Andrew Johnston | 19/10/2016 14:08:31 |
![]() 7061 forum posts 719 photos | As far as I'm aware I don't pay extra standing charges, or more per kWh, for my 3-phase supply than I would for single phase. After all the house, which is the main consumer, runs off a single phase. It's just that the tapping is in my garage rather than the street. Andrew |
J Hancock | 19/10/2016 18:08:54 |
869 forum posts | I well remember the days in the 1960's when Pembroke+ others were using heavy fuel oil to 'make' electricity. We had a student in the class, who worked for the EEB, selling storage and underfloor electric heating to all the new housing developments in the area. I wiil bet they have all changed to gas heating now !! |
Neil Wyatt | 19/10/2016 18:14:21 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Ajohnw on 19/10/2016 11:34:03: These days they would have me fit a massive heat store. If that cools it will take a long time to heat up. - More usual to have a combi boiler with a tiny heat store these days, it can fill a washing up bowl or wash your hands without going into overdrive, but when you need a bath or shower it just runs flat out. We've got one and it works. N. |
SillyOldDuffer | 19/10/2016 19:56:16 |
10668 forum posts 2415 photos | Posted by Neil Wyatt on 19/10/2016 18:14:21:
Posted by Ajohnw on 19/10/2016 11:34:03: ... More usual to have a combi boiler with a tiny heat store these days, it can fill a washing up bowl or wash your hands without going into overdrive, but when you need a bath or shower it just runs flat out. We've got one and it works. N. Ah the good old days! Remember when being last in the queue meant a cold bath#. And those semi-exploding Gas Geysers in freezing Bathrooms. I expect Duncan will pop up to explain that such things were luxury when he were a lad in't Yorkshire... # For readers not used to UK hygiene: we Brits like to start the week by sitting in a few inches of dirty water whether we need it or not. |
Ajohnw | 19/10/2016 20:03:05 |
3631 forum posts 160 photos | Posted by Neil Wyatt on 19/10/2016 18:14:21:
Posted by Ajohnw on 19/10/2016 11:34:03: These days they would have me fit a massive heat store. If that cools it will take a long time to heat up. - More usual to have a combi boiler with a tiny heat store these days, it can fill a washing up bowl or wash your hands without going into overdrive, but when you need a bath or shower it just runs flat out. We've got one and it works. N. If you fitted our new boiler Neil I'd throw you out. Combi's are often thought of not being a good idea if there is more than one bathroom. The heatloss from the heat store is negligible. In my view the man that started up Worcester heating was a bright cookie as far a running costs are concerned. The boiler scarcely ever turns on unless hot water is run. The only catch with them is that people have to accept that the water will run cool eventually when filling a bath. This is why it's such a small heat store as it's never too cool for many things. In some ways it's similar to having a combi with a separate tank that's kept hot all of the time. There is no direct replacement now so I am left with the question how big a heat store. The current one holds Some friends of ours used a rayburn for heating and the heat exchanger went. Similar problems to us. The guy that got the job said no combi for a number of reasons. John - |
Max Tolerance | 19/10/2016 20:05:44 |
62 forum posts | I have a three phase supply fitted for "free" by the old NWEB. My house was built around the turn of the century (1901). In those days electricity was a new thing for houses and if a new house wanted to be connected to the mains as it was called then, they used the tram supply generated by the local authority. The only problem was that this was usually D.C. When the national grid was set up later then of course the supply changed to A.C. and voltages where standardised. In my street when the national grid was connected they decided to use the original two core D.C. supply cables so one phase went down one side of the street and a different phase went down the other. Later a three phase cable was laid to supply the street lights, however they left the houses as they were. Around twenty years ago the supply cable to my house failed (after all it was approaching 100 years old) it was a lead and paper insulated cable and very light by modern standards. The electric board were very busy at the time so In exchange for me digging the trench across my front lawn they kindly agreed to fit three phase power for "free". Happy days! I only pay one standing charge and standard tariff, the only down side is finding a supply company who will accept three meter readings instead of one since most of them unbelievably can't cope with it for domestic customers. But if you want to fill your cellar with machinery you can't beat it. |
