Vee belt / Poly Vee belt maximum power
Rainbows10/10/2016 01:12:09
658 forum posts
236 photos
Does anyone have formulas or guide books to tell how much power different belts can transmit? Interested in finding how many belts over how large a pulley I would need to transmit 2HP.
Paul Lousick10/10/2016 01:43:03
2276 forum posts
801 photos
Design data for Fenner transmission belts can be found at:
Tim Stevens11/10/2016 15:45:13
1779 forum posts
The power delivered by a belt drive depends on the speed of rotation, as well as the tension the belt can stand, and the amount of friction between the belt and the pulleys. So, it might seem that the faster you go, the more power you can transmit, with the same set-up. True, but only up to a point. The tension in the belt is increased by centrifugal force as the speed rises, and so this places a limit on how fast for given pulley sizes. And of course, the pulleys are also under strain, and can explode if the rpm is too high. That's why a simple formula cannot be supplied. In the words of the prophet, it all depends ...
Cheers, Tim
Ajohnw11/10/2016 16:28:42
3631 forum posts
160 photos
If you google
calculate poly v belt transmission power
Lots of links come up. I'd do sums from more than one.
I'd guess from a space point of view Poly V will win out as it's more flexible than the usual V belts in all but very small sizes. This is why I suspect it's being widely used in washing machines lawn mowers and many other things. V belts need a certain size of pulley to transmit a given torque or more than one belt. As with V belts the belt lap angles should matter but I believe rollers can be used in the same sort of way as they are on toothed belts.
not done it yet11/10/2016 18:26:03
7517 forum posts
20 photos
2 HP? Easy. Only one belt in most situations. The pulley size or fitting of a jockey pulley might be a limiting factor. More important is axial bearing loading and/or slippage in most applications. Ask the belt supplier for pertinent details.
Only need one poly vee in any situation, I would think. I have a couple of poly vee belts that were originally used for transmitting around 150 HP each. Pulley diameter might also be a limit as any belt will have a minimum curvature limit. Easier to make a uniform poly vee than supplying matched V belts.
Piero Franchi11/10/2016 19:27:51
124 forum posts
60 photos
Not wanting to high jack this topic, But I to am interested in a Vbelt for my 2hp motored milling machine,
I have a Tom Senior Major (the major having a 2hp motor)
I have stripped the mill inc the main spindle, so I want to replace the V belt at the same time,
I am wanting to know, Are all V belts made equally ???
Were would I buy a quality V belt for the main spindle ?????
It came with a link type belt and I dont personly like them (dont wish to explain why, I just dont)
duncan webster11/10/2016 21:00:45
5307 forum posts
83 photos
Posted by Piero Franchi on 11/10/2016 19:27:51:
Simply Bearings, pleasure to do business with **LINK**
Gordon W12/10/2016 09:49:44
2011 forum posts
Lots of info. on V belts and polyV. For our sort of usage you can usually go well over for power ratings etc. As an example my rotavater has a standard small section V belt ( 3/8" )?. This can transmit from a 6hp petrol engine and has been for two years.
Chris Gunn12/10/2016 14:30:24
459 forum posts
28 photos
Piero, if you have a power transmission company locally pop in with the link belt, they can measure it and supply you with a Vee belt to do the job. I do not like link belts either, but they can get you out of trouble.
Chris Gunn
Roderick Jenkins12/10/2016 14:49:46
2376 forum posts
800 photos
I remember reading somewhere that a link belt gives a smoother drive on a Myford with a 1ph motor. That's not relevant to me but I've got a PowerTwist belt waiting in a drawer for my A profile V belt to give up the ghost- it's looking pretty tired. I really don't want to disturb the spindle if I don't have to.
Rod
Piero Franchi12/10/2016 15:30:11
124 forum posts
60 photos
I know the sizes I need as I am lucky enough to have two tom seniors,
ones a M1 and the other is a Major.
The M1 is running on all original belts
I am taking apart the tom senior major for a clean and freshen up etc etc
As I have the main spindle out of the coloum, I may as well go back to the original V belts from the link belt that some one has fitted
