Parallel Flute Reamers on Morse Taper Shank - How do I work out the size?
Steve Withnell04/10/2016 18:03:11
858 forum posts
215 photos
I was offered 5 of these reamers brand new in box. Although all the labelling was intact, there was no obvious sizing info. The only marking that I thought might be size related, on the box and the reamer was '3A-352'. Roughly 8mm on a MT2 shank.
The manufacturer appears to be 'Bridge'.
Any clues?
Steve
Michael Gilligan04/10/2016 18:37:15
23121 forum posts
1360 photos
Steve,
You could try asking these guys: **LINK**
http://www.taylorandjones.co.uk/wp-content/uploads/2014/03/13.pdf
Steve Withnell05/10/2016 20:12:52
858 forum posts
215 photos
Thanks MIchael.
Steve
Tony Pratt 105/10/2016 20:42:50
2319 forum posts
13 photos
Am I missing something, can't you measure them?
Tony
Ken Price 112/11/2016 14:35:07
7 forum posts
Usually with reamers, their size is stamped at the base of the reamer just above the end of the taper. However I have had reamers with no specific markings and these I found to made for the aircraft industry where very specific sizes are required not being standard metric or imperial sizes. I have undertaken subcontract work for this industry and frequently had to use such items.
Ken Price
Neil Wyatt12/11/2016 15:07:14
19226 forum posts
749 photos
86 articles
Posted by Tony Pratt 1 on 05/10/2016 20:42:50:
Tony
Not if they have an odd number of flutes, and they often have 7 or 5, I think it reduces chatter if they are an odd number and not perfectly evenly spaced.
NIALL HORN12/11/2016 15:47:34
49 forum posts
18 photos
Ideally, you need to find someone with a v-anvil micrometer. The angle of the V needs to be correct for the number of flutes - 60 degrees for 3 flutes, 108 degrees for 5 flutes and 128 degrees 34 minutes for 7 flutes. They are not cheap! An ordinary mike will not give a correct diameter.
V-angle mics are also used to detect lobing on centreles-ground spindles.
mark smith 2012/11/2016 16:03:09
682 forum posts
337 photos
why dont you just drill a slightly undersized hole in something like 1/2" aluminium, put the reamer through and measure the hole size???
Or 352/1000" =8.94mm (but may be totally wrong)
Edited By mark smith 20 on 12/11/2016 16:06:43
Michael Gilligan12/11/2016 16:11:15
23121 forum posts
1360 photos
Posted by Steve Withnell on 04/10/2016 18:03:11:
Mark,
I suspect that the reason for not adopting your very practical approach is evident from Steve's introductory comment.
