phil burley | 15/09/2016 19:06:39 |
![]() 45 forum posts 1 photos | About 20 years ago , when a firm went under, I inherited some silver solder used to join 8 in band saws. Its made by Eutectic Co.Ltd , Its Eutecrod 1801 , says suitable for ferrous and non ferrous metals . My question is , is this suitable for soldering a small boiler ? regards Phil |
Roderick Jenkins | 15/09/2016 19:49:30 |
![]() 2376 forum posts 800 photos |
Unclear from this what the percentage of Silver is but looks like it might be too high a temp for easy soldering.
Edited By JasonB on 15/09/2016 20:36:54 |
not done it yet | 15/09/2016 19:57:48 |
7517 forum posts 20 photos | Do check its content. It may contain Cadmium, which is outlawed these days. It would not stop you using it, but be aware that Cd is particularly toxic. |
Brian H | 15/09/2016 20:34:32 |
![]() 2312 forum posts 112 photos | The temp range is given as (converted to C from F) 682 - 815 which is a very large range. I'd be tempted to steer clear. |
Roderick Jenkins | 15/09/2016 21:02:12 |
![]() 2376 forum posts 800 photos | This **LINK** (note no G on the end) suggests that it is a (low) Cadmium bearing alloy with a high Silver content and a working temperature of 604C. If correct then very good for boiler making. I would be happy to use it out of doors. Rod |
Versaboss | 15/09/2016 22:40:15 |
512 forum posts 77 photos | Roderick is absolutely correct, Castolin/Eutectic 1801 is equivalent to the famous Easyflow. Luckily it is still available without problems here in Switzerland. Maybe you will get it back after Brexit? Regards, HansR
Keith Hale | 16/09/2016 07:19:24 |
![]() 334 forum posts 1 photos | Welcome to the confusing world of Castolin and what are you actually getting when buying their silver solders.. After 47 years in this business nothing has changed! It has not been uncommon for the same alloy to have different numbers dependent upon marketing conditions. One of the links tells me that 1801 is cadmium free with a melting range 660 - 743 C but little else, This is more closely aligned to a 38% silver cadmium free alloy The other tells me that it is 51% silver, 5% cadmium, 22% copper, 1% tin and 21% zinc which incidentally is nothing like the composition of easyflo 2. Is it any good for boiler making ? Possibly. If all the joints are being made on a small boiler using the same alloy - fine. Use it but in well ventilated areas because of the uncertainty about cadmium. If you want to use two different alloys, ie step braze, then it falls between two stools. It is too high a temperature for the low temperature joints and too low a temperature for the high temperature joints! If you have enough, I would suggest you scrap it and with the money buy alloy that you know and can trust. Contact John Betts Refiners Birmingham. Keith |
phil burley | 16/09/2016 08:05:27 |
![]() 45 forum posts 1 photos | hello , well that's confusing then ! I have been using this material for some time for odd jobs , melts with a propane burner . I have quite a lot of of it , must have cost a fortune !!!!!!! , I am having a go at a small traction engine , only a 2 inch dia boiler . I think I will have a test on a bit of the spare boiler tube , regards Phil |
Keith Hale | 16/09/2016 09:10:10 |
![]() 334 forum posts 1 photos | Hi Phil. Spot on! Castolln always supplied good products. It will do what it says on the tin without telling you what is in the tin! |
