DRO with magnetic scales
Mike Crossfield30/08/2016 12:12:08
286 forum posts
36 photos
I'm looking for a 2 axis DRO for my small Dore Westbury milling machine. Since space is very limited I've decided to go for magnetic scales. Machine DRO offer a kit for £360 which seems to fit the bill, but they are the only supplier I can find who offer low cost magnetic systems. It would be nice to have someone else for comparison . Does anyone know of another supplier?
Mike Poole30/08/2016 12:26:43
3676 forum posts
82 photos
At the Bristol Show I saw this firm www.ems-i.co.uk I have no connection with the firm just reporting their presence at the show.
Michael Topping30/08/2016 12:37:01
74 forum posts
5 photos
You beat me to it Michael. I had a long chat with one of the guys on the stand at Bristol. He was very knowledgeable, been in the DRO business for many years. Their prices seem comparable to others.
Michael
Michael Briggs30/08/2016 13:39:51
221 forum posts
12 photos
Hello Mike,
I have the Machine DRO magnetic scales and display fitted to my lathe and mill. I am very pleased with the results, the magnetic scale is easy to cut to length and is very compact. The readout is a rebadged Sino that has been around for some time. After installing the stainless steel strip that protects the magnetic strip, I applied sealant so the ends of the encoder assembly are sealed. The £360 kit looks good value considering the encoders alone would cost £334 for the pair, if you bought today you can factor in another 10% discount. I wish the kit bundle and discount had been available when I bought mine. Regards, Michael.
Mike Crossfield30/08/2016 16:19:10
286 forum posts
36 photos
Thanks all.
After checking with ems and machine DRO it seems the current deal at mDRO is hard to beat.
Ordered a complete 2 axis milling package with 5 micron magnetic scales for £330 including carriage.
fishy-steve30/08/2016 17:37:38
122 forum posts
30 photos
I purchased a 3 axis system from Machine DRO at the Bristol show on the Friday for £475. I've installed it on my Tom Senior mill. Very compact and easy to fit.
I was a bit miffed that they released the 10% discount on their website only a few days later though.
Steve.
Senior Yates30/08/2016 21:36:34
34 forum posts
Hi Steve, have you got any photo's as I want to fit a DRO to my Tom Senior?
Many thanks
fishy-steve30/08/2016 22:08:15
122 forum posts
30 photos
Hi Senior Yates,
I've just added the only picture I have to an album. I will happily take more pictures for you.
Steve.
Senior Yates31/08/2016 12:15:48
34 forum posts
Hi Steve
Thank you for that. I have just completed making and fitting a 4" riser block for my TS. I will upload some photo's when I get a chance.
Skarven31/08/2016 20:05:44
93 forum posts
11 photos
Machine DRO have a Real English manual for the Sino DRO that is worth quite a lot! If you have seen the original Sino manual with its very pronounced Chinglis language, you will know what I mean.
I have several magnetic scales from Machine DRO, and they are a lot easier to fit and take up less space than the glass scales. They are also much less sensitive to oil etc.
Kai
fishy-steve31/08/2016 21:01:25
122 forum posts
30 photos
Hi Kai,
My system came with 4 separate manuals. Basic Function and Console set up, Milling function, Lathe function and the Encoder install guide.
Although they are in English there are a few errors. For instance the first two manuals contradict each other concerning the axis + and - convention. Very confusing for anybody who isn't familiar with it.
Also my console was supplied with the X axis +/- programmed the wrong way round. Luckily the console manual covers how to change the settings.
Steve
John Stevenson01/09/2016 07:03:37
5068 forum posts
There is no right and wrong way. It depends on scales, what it's being fitted to, mounting front or rear etc.
That is why the direction is changeable
fishy-steve01/09/2016 09:30:58
122 forum posts
30 photos
Hi John,
I was always taught tool to the right, tool to the back and knee up are all + on the mill. It gets very confusing in a machine shop that's running 24/7 if your co- workers are not all running the machine the same way.
I don't suppose it would matter in a model engineering workshop or a one man band workshop but it's what I have got used to.
Steve.
Hope this works.
http://concepttocad.blogspot.com/2013_09_01_archive.html
Edited By fishy-steve on 01/09/2016 09:46:25
Michael Briggs01/09/2016 10:27:03
221 forum posts
12 photos
For a horizontal axis, if the read head is mounted with the cable exit towards the left of the strip the count direction will be opposite to that if it were mounted with the cable exit towards the right of the strip. The supplier probably sets up a kit package for milling use (or lathe) and the encoder type. I would expect the direction settings to be left at factory defaults. Regards, Michael.
fishy-steve01/09/2016 10:35:40
122 forum posts
30 photos
Hi Michael
That would explain my X axis issue.
After re-reading John's reply above it finally soaked in!
Thanks,
Steve.
Edited By fishy-steve on 01/09/2016 10:42:44
mark smith 2001/09/2016 11:12:02
682 forum posts
337 photos
Would someone explain to me when looking at the Machine DRO site what the supposed difference is between Hobby and Industrial ,i see no price difference at all and they look the same. And what is pro supposed to be , as i would assume industrial users would use a professional system ????
JasonB01/09/2016 11:54:34
A quick 30sec glance and I can see they list longer length and higher resolution encoders in the industrial section, probably more diffrences too.
J
