Alan Girvan | 21/08/2016 18:45:06 |
40 forum posts 3 photos | Adjusting the top slide of my myford 7R to cut 60 degree threads or 55 degree threads is very difficult to see the mark and the graduations. There only seems to be one mark on the top slide can I put an extra mark on where it is easily seen and where would the best place be to put it. Hope this makes sense and as always thanks in advance for any help and advice you can give. Alan
Michael Gilligan | 21/08/2016 19:06:26 |
![]() 23121 forum posts 1360 photos | Alan, My first thought was to put a single new radial line at 30° or at 27.5° rotation from the existing fiducial mark. Decisions ... Decisions !! Then I wondered: Might it be best to engrave a short arc, with one end identifying each angle? Does that make sense ? MichaelG. |
Brian Wood | 21/08/2016 19:15:12 |
2742 forum posts 39 photos | Hello Alan, There should be a 45 - 0 - 45 degree scale on that circular base which is referenced back to a fine fiducial mark on the centre line of the cross slide. Setting angles on the top slide is from that fine mark. Remove the top slide complete, fit a faceplate or the catch plate to the spindle nose and then a wide parallel can be butted up to the faceplate so that it is aligned along the mid point of the top slide, being sure it bisects the location hole for the top slide. Now scratch a mark which reaches beyond the point where the base of the top slide will have left a faint circular witness mark on the flat top of the cross slide. That scratch will be your new fiducial mark I hope that helps you Regards Brian. |
KWIL | 21/08/2016 20:04:30 |
3681 forum posts 70 photos | Whilst you are at it, make sure the new mark is mirrored to the tailstock side of the cross slide as well, useful when cutting LH threads! |
Tim Stevens | 22/08/2016 09:37:37 |
![]() 1779 forum posts 1 photos | I wonder if the top slide assembly has been fitted back-top-front? The marks are only on one side but I think the base is otherwise symmetrical. In any case, the important detail is to get the tool itself exactly at right angles to the spindle axis (assuming that it has been ground 'square' ) If the offset angle is not enough the 'back' edge of the tool will take a tiny shaving, and if too much then one face of the thread will have ridges. So, a bit less than the 'correct' angle is much better than a bit too much. I think Cheers, Tim Edited By Tim Stevens on 22/08/2016 09:38:13 to remove a silly face! Edited By Tim Stevens on 22/08/2016 09:39:04 Edited By Tim Stevens on 22/08/2016 09:39:39 |
Brian Wood | 22/08/2016 09:49:06 |
2742 forum posts 39 photos | Hello Tim, That had occurred to me as well, but the feed screw nut would then be on the wrong side, ie chuck side, and probably beyond the reach of the feed screw anyway.
Michael Gilligan | 22/08/2016 13:40:37 |
Posted by Alan Girvan on 21/08/2016 18:45:06: Adjusting the top slide of my myford 7R to cut 60 degree threads or 55 degree threads is very difficult to see the mark and the graduations. There only seems to be one mark on the top slide can I put an extra mark on where it is easily seen and where would the best place be to put it. . I may be wrong [it has been known]; but I think the discussion is drifting away from Alan's stated problem: As I see it; he has a scale, and he has the standard fiducial line, located in the standard position ... It's just that [when angling the top slide for screw-cutting] he finds it difficult to see the reading. The question is two-stage:
Done as I suggested earlier, this provides alternative fiducial marks, with minimal modification. Am I 'barking up the wrong tree' ? ... or just 'barking mad' ? MichaelG. |
Mike Lightfoot | 22/08/2016 13:51:16 |
76 forum posts 24 photos | Hi, I have the same problem ( as will anyone with a similar Myford) my solution which is drifting is to use the protractor from a combination set against the chuck or face plate and the side of the top slide quick and easy cheers
Brian Wood | 22/08/2016 15:16:25 |
I accept that the graduation marks are fine, but my eyesight was severely compromised years ago by retinal repair and I can read them using ordinary reading glasses. Decent lighting helps and I still have the option of magnification to fall back on when I can no longer resolve them. Regards Brian |
Ian S C | 23/08/2016 12:18:36 |
![]() 7468 forum posts 230 photos | When I was making parts for agricultural machinery that we were building, I had a number of angle plates that I could fit between the face of the chuck and the top slide, just a few seconds to set the angle, and just requires some scrap sheet metal. Ian S C |
Alan Girvan | 26/08/2016 19:08:41 |
40 forum posts 3 photos | Thanks for all the different methods, I have found them very useful. Micahel thanks for putting everyone back on track again, Alan.
