Martin King 2 | 28/07/2016 17:34:59 |
![]() 1129 forum posts 1 photos |
Hi all, Just started going through a large auction lot of tools that I bought recently that has some very nice tooling in it and found these 2 nice wooden cased item which have me completely stupmed as to what they are for: The first appears to be user made, not sure about the other one, any info would be most helpful pleasre. Regards, Martin |
Peter Krogh | 28/07/2016 19:15:28 |
![]() 228 forum posts 20 photos | I believe the first one is used, with a dial indicator that is not shown, for adjusting the cutting tool in a boring bar. The thumb screw with the ball end is used to push the back of the tool bit while the movement is measured by the indicator mounted in the opposite hole. Pete
John Reese | 28/07/2016 21:36:58 |
![]() 1071 forum posts | +1 on Peter Krogh's response. |
duncan webster | 29/07/2016 00:14:15 |
5307 forum posts 83 photos | And there's me thinking it's an adjuster for the thrupplenuts on a wimwam nurdler |
John Stevenson | 29/07/2016 00:22:04 |
![]() 5068 forum posts 3 photos | Second one could be something to find the centre of a bar before machining ? |
Hopper | 29/07/2016 00:43:29 |
![]() 7881 forum posts 397 photos | Posted by duncan webster on 29/07/2016 00:14:15:
And there's me thinking it's an adjuster for the thrupplenuts on a wimwam nurdler No, no, it doesn't have the requisite ostotigilator difrasials to be one of them. |
Neil Wyatt | 29/07/2016 08:12:23 |
![]() 19226 forum posts 749 photos 86 articles | I have something very like the larger coned adaptor in the bottom photo. It's for pouring whisky into my hip flask. Actually it looks like an over-engineered centring device where you put the whole end of the chuck/spindle into the cone. Neil |
Martin King 2 | 29/07/2016 09:49:12 |
![]() 1129 forum posts 1 photos | Thanks Guys, that seems a good use for the first one. JS, the small spring on the second one does not allow any marking access to the centre of the main vee so cannot see how it could be used like that but I bow to your expertise, so much greater than mine for sure. Any other thoughts? Martin |
Martin King 2 | 29/07/2016 09:50:53 |
![]() 1129 forum posts 1 photos | Neil, do you mean for cross drilling a bar or similar? Martin |
MW | 29/07/2016 09:55:37 |
![]() 2052 forum posts 56 photos | Can anyone tell what kind of steel has been used?
Michael W |
HasBean | 29/07/2016 10:03:17 |
141 forum posts 32 photos | The second item is for centring in the mill. There was an article in MEW some years ago, might have been by Peter Rawlinson but really can't remember.
Paul |
HasBean | 29/07/2016 10:08:33 |
141 forum posts 32 photos | MEW No.47 by Peter Rawlinson
Paul |
Martin King 2 | 29/07/2016 10:52:45 |
![]() 1129 forum posts 1 photos | My grateful thanks to all for help on these items, second item is listed on EBay with credit given to MEW forum. Regards, Martin |
Steven Vine | 29/07/2016 11:52:15 |
340 forum posts 30 photos | I see you have one of those new rulers, that redefines the inch. You'll be out by nearly 5mm using that to convert 12 inches. |
MW | 29/07/2016 14:33:51 |
![]() 2052 forum posts 56 photos | Posted by Steven Vine on 29/07/2016 11:52:15:
I see you have one of those new rulers, that redefines the inch. You'll be out by nearly 5mm using that to convert 12 inches. Yes, definitely not kosher to call an inch 25mm, even if you're at 2 inches you're closer to 51 than you are to 50. It was hardly worth bothering with the lettering. Michael W |
Martin King 2 | 29/07/2016 17:08:24 |
![]() 1129 forum posts 1 photos | I have made a decision to give myself a fighting chance with my Stuart 10v and not use this ruler.... Thanks again for the help wioth these items. Martin |
