Luke Blades | 24/07/2016 20:19:25 |
11 forum posts | Hello all, So i'm still looking for my ideal mini mill for CNC conversion. I expect to be able to drill / mill steel with an endmill and flycut aluminium. I noticed that Warco have an offer on their WM16 mill: http://www.warco.co.uk/milling-machines/32-wm-16-variable-speed-milling-machine.html I have a couple of questions about this. Firstly, I cant find any videos of this model in use. What is the noise level like? I'd like to be able to run this in my flat without disturbing the neighbours. I've seen brushless, belt driven machine of this size in use and they seem quiet. Is there potential for a belt drive conversion and is the brushed motor any louder that its brushless counterparts? If you were to compare the noise level to a household appliance, what would you say? Secondly, i'd like to hear of people's experiences both in general and in CNC conversions with this machine. I'd appreciate recommendations of other machines however my budget limit is £1000. I have no experience with CNC so if you think there's anything in particular that I might have overlooked with this machine or be unprepared for, please let me know! Really looking forward to hearing your thoughts, Many thanks, Luke Blades |
Martin Connelly | 24/07/2016 21:27:25 |
![]() 2549 forum posts 235 photos | Try searching G0758 cnc. This is a similar machine from Grizzly in the U.S Martin |
Luke Blades | 24/07/2016 22:54:37 |
11 forum posts | Thanks for the suggestion Martin but they wont ship an item that heavy to the UK (should have mentioned I live in the UK). Cheers, Luke |
dcosta | 24/07/2016 22:57:28 |
496 forum posts 207 photos | Hello Luke. |
Luke Blades | 24/07/2016 23:19:08 |
11 forum posts | Hi Dias, Thanks for the insight. Looks very similar indeed. I'm looking for products with similar power but quiet enough. Do you think that this noise is due to the gearbox or the motor itself? Could a belt drive mod bring the noise down to an acceptable level? Best, Luke |
Bazyle | 25/07/2016 00:19:16 |
![]() 6956 forum posts 229 photos | I don't think Martin was suggesting you ship a G0758 mill from the US but look at the owner's reports (some on Youtube) and CNC conversions. Or perhaps G0704. Edited By Bazyle on 25/07/2016 00:23:53 |
Paul Lousick | 25/07/2016 00:47:33 |
2276 forum posts 801 photos | The Sieg SX2 mill has a brushless DC motor with belt drive. Lots of videos on Youtube about conversion to CNC Edited By Paul Lousick on 25/07/2016 00:48:16 |
dcosta | 25/07/2016 01:07:58 |
496 forum posts 207 photos | Hi Luke, Regards
Paul Lousick | 25/07/2016 04:03:09 |
2276 forum posts 801 photos | My SX3 at full speed with no load is quieter than my food processor or washing machine. The total noise generated depends on what type of milling operation you are doing. Drilling a 10mm hole or light milling is no more noisy than my pistol drill. Paul. Edited By Paul Lousick on 25/07/2016 04:04:31 |
Dave Daniels | 25/07/2016 08:29:24 |
87 forum posts | I have a WM16 and it is somewhat noisy. Not the sort of machine to use in a multi occupancy building. The SX3 is much quieter but weighs in a fair bit above your £1k. This one also does but it may be quieter than a WM16: Looks similar in spec. to a belt drive WM16 on first glance and also may have R8 which would be an asset IMHO, but this option is OOS at the moment. D.
Edited By Dave Daniels on 25/07/2016 08:30:27 Edited By Dave Daniels on 25/07/2016 08:32:00 Edited By Dave Daniels on 25/07/2016 08:32:37 |
Thor 🇳🇴 | 25/07/2016 08:31:58 |
![]() 1766 forum posts 46 photos | Hi Luke, I have an old Sieg X2 with brushed motor and gears, it is noisier than my friends Sieg SX2 with brushless motor (and no gears). The SX2 also seems to have more torque than mine, especially at low speeds. Thor |
Rik Shaw | 25/07/2016 09:39:40 |
![]() 1494 forum posts 403 photos | Hello Luke - WM16 has quite a high pitched shrieking noise from the gear train especially at the higher speeds. I would think the neighbours would be banging on the walls in short order. If you go down the CNC road my advice would be to use the mill in manual mode for a period to get used to the "feel" of the machine. In particular, my WM16 has needed some fairly dramatic take up of the slack in the XYZ gibs over the last few years from new and only now that the gibs appear to have bedded down would I feel confident in fitting CNC which I will not be doing anyway. Some people like yoga or meditation - I just like winding handles. Rik |
John Stevenson | 25/07/2016 11:47:49 |
![]() 5068 forum posts 3 photos | I have converted about 5 or 6 of the WM series to CNC, some WM14's, some WM16's There are a couple of problems with these. Main one is mostly you need access to another milling machine to clear under the table to allow room for the ball screw, it is tight.
As regards noise, they are noisy, I replace the primary gear drive with timing belt which helped but the main gearbox is still noisy.
For operation in a flat I'd go for the SX2 if you wanted to keep to sub 1K |
Another JohnS | 25/07/2016 12:28:57 |
842 forum posts 56 photos | I did not like wearing hearing protectors when using my "King Canada KC20-VS" so I ordered a belt drive from benchtopprecision.com and (when it eventually arrived) made an incredible difference. It has two speeds, and alters the speed range "up" slightly. It was very well made, but took a while to arrive. Installation was easy - the only issue I had was that the guard cover screw needed to have a spacer turned up to move it "out' slightly - 20 seconds on the lathe with a bit of brass rod. I'm not sure I'm really happy with the mill itself, but time will tell whether it's a keeper or not. I'm not sure if it was my cutting the slot underneath for ball screw clearance, but my table ended up being warped, and when doing a cleaning cut over the top, discovered a hard spot on it. I should disassemble again and check how it's doing, but... (here's one pic, another one in my "misc" album. Not great shots, but you'll get the idea)
Enough! | 25/07/2016 16:42:57 |
1719 forum posts 1 photos | Posted by John Alexander Stewart on 25/07/2016 12:28:57:
Pretty nice looking installation manual available to download before purchase too, John. Might think about that myself before long. You just snuck in under the vent there eh? |
Another JohnS | 25/07/2016 18:15:03 |
842 forum posts 56 photos | Posted by Bandersnatch on 25/07/2016 16:42:57:
You just snuck in under the vent there eh? Good eyes. Yes - would rather have purchased a Tormach PCNC 770 with stand, but did not have the vertical height. Most of my workshop ceiling consists of duct work, and I have maybe 1 square metre where it is higher. I mention this only because it is easy to look down measure the footprint of possible new equipment (yes, this will fit through the door and sit HERE) but one must look at the height above, too! This is easily overlooked. I was able to assemble this mill shown elsewhere in my workshop, move it close to its final position, then put the Z stepper in place, then roll it back against the wall. John. |
Luke Blades | 25/07/2016 20:17:20 |
11 forum posts | Thanks to you all for your comments and pictures! The general tone is that the WM16 WOULD be too loud and that for the price, the SX2 would be a better buy. Considering I live in the UK, where is the best place to buy one of these machines currently? I notice Axminster do one with a 500W brushless motor and a belt drive for £820, not bad. Arc do an SX2P which i've been told is not ideal for CNC conversions due to the lack of space in the table and saddle for ballscrews, for 705 + delivery. Anyone else know of a good place to get hold of an SX2? Cheers, Luke |
John Stevenson | 25/07/2016 20:53:57 |
![]() 5068 forum posts 3 photos | Virtually no difference between the two except for the table and travels and spindle. Axminsters is MT3 only and Arc's is MT3 or R8 which is a better taper for a milling machine, less thumping about.
Axminsters table is 390 x 100mm with movement of 220 x 100mm
Arc's table is 400 x 145 with movement of 330 x 145mm
I know which one I'd chose given these specs. |
Luke Blades | 25/07/2016 23:25:38 |
11 forum posts | Hi John, Are you sure? Looking at the tables, they seem visibly different. I've been told that there's only enough space for a 10mm ballscrew. Would this be large enough for CNC on a machine of this size cutting steel? I'd prefer to go with the SX2P if i can be convinced that the CNC conversion is still viable. Cheers, Luke |
John Stevenson | 26/07/2016 00:08:13 |
![]() 5068 forum posts 3 photos | I have the base of an SX2P here somewhere, I'll have a look tomorrow and offer a couple of screws up and see how they will fit. |
