Quorn
norman valentine14/07/2016 16:14:13
280 forum posts
40 photos
I have a bought a partly built Quorn. I also bought the book to help me with the construction. The casting for the rotating base was missing so I decided to make it from mild steel. I am near to completing it and have just noticed at the beginning of the book there is a note to say that the design of the base had been changed because of the difficulty some people were finding in machining the casting. Were these changes detailed in ME? If so can anybody tell me which in issue it is featured or can anybody give me the details of the changes?
Thanks, Norman
Edited By norman valentine on 14/07/2016 16:15:07
John Haine14/07/2016 18:07:06
5563 forum posts
322 photos
If you built it from the book it presumably incorporates the changes...
norman valentine14/07/2016 18:38:15
280 forum posts
40 photos
That's the point. They are not in the book.
Why would I be asking if it was there?
Edited By norman valentine on 14/07/2016 18:40:37
JasonB14/07/2016 19:12:07
Might try 3813 as that says its about alternative machining methods
Edited By JasonB on 14/07/2016 19:17:06
John Purdy14/07/2016 19:15:57
431 forum posts
252 photos
Norman
Try 5 Sep 86 (3784) page 272 , and 20 Nov 87 (3813) page 610, for alternate ways of making the rotating base.
John Purdy
Edited By John Purdy on 14/07/2016 19:19:39
Edited By John Purdy on 14/07/2016 19:22:23
norman valentine14/07/2016 20:01:44
280 forum posts
40 photos
Thank you Jason and John P, that is exactly what I was looking for.
Edited By norman valentine on 14/07/2016 20:03:14
Neil Wyatt14/07/2016 20:04:38
19226 forum posts
749 photos
86 articles
Some people have made the base in two halves, top and bottom, it makes machining the circular t-groove into something mere mortals can achieve.
ian j14/07/2016 20:49:55
337 forum posts
371 photos
This is how the rotaing base is fabricated for the Bonelle T & C grinder
Ian
norman valentine14/07/2016 21:55:41
280 forum posts
40 photos
Funnily enough I found that cutting the tee slot was relatively simple. I just followed the instructions and ensured that the tools were set up precisely. Making the cutters was complicated by the fact that I don't have a tool and cutter grinder! I just used my angle grinder very carefully.
Martin Kyte15/07/2016 09:29:44
3445 forum posts
62 photos
When I made mine (From the Book) I did it in two parts similar to that shown by Ian J. I have not had chance to refer to the book before writing this but could it be that the design in the book is the modified version. The only other change I can remember is the variation on the stops around the perimeter where instead of T slots there are a series of tapped holes. The stops themselves are made with adjustment slots to cover the range between the tapped holes.
regards Martin
