Dave Smith the 16th | 29/06/2016 17:03:53 |
123 forum posts 33 photos | Must be something with me and tools, when I bought my lathe a pair of internal threading tools seemed like a useful addition. The tips were brazed directly to the shaft so in theory should thread fairly small internal diameters, when the items arrived they were nothing like the picture, the shaft was bent over 90 degrees and the tips brazed to that. Instead of approx 8 - 10mm your now looking at 20mm +. Ordered an involute gear cutter, pictures and specs show a keyway, when the item arrived there is no keyway. argghhhh Seller offered half my money back, but now i need to make an arbour without a keyway and make sure the gear cannot slip. How much pressure does an involute cutter take? Is a keyway essential? Thanks.
Edited By Dave Smith the 16th on 29/06/2016 17:07:04 |
Thor 🇳🇴 | 29/06/2016 17:16:42 |
![]() 1766 forum posts 46 photos | Hi Dave, I have involute cutters bought from a reputable shop and they have a keyway. I have also made my own gear cutters without keyway. I use both types on an arbor without a key, I feed a bit slow I guess and have never had any cutter slip. Thor |
JasonB | 29/06/2016 18:09:26 |
![]() 25215 forum posts 3105 photos 1 articles | I've never bothered to fit a keyway into my gear cutters when I have used them, seem to work fine. |
Brian Wood | 29/06/2016 18:17:25 |
2742 forum posts 39 photos | Hello Dave, You can cut a keyway in an involute cutter with a square diamond file. It is slow work on HSS, the alternative is to spark erode it instead Arc Euro sell sets of those files. I have no connection other than being very pleased to resolve just such a problem and open out a small half round keyway on a commercial cutter. Taking very light cuts without a keyway does not actually do the cutter any favours, they are intended to cut to full depth in one pass and will lose their edge if made to work in small bites. Regards Brian
Andrew Johnston | 29/06/2016 19:20:56 |
![]() 7061 forum posts 719 photos | Posted by Dave Smith the 16th on 29/06/2016 17:03:53:
Must be something with me and tools...................... You probably want to start buying from a proper tool supplier............... All my involute gear cutters have keyways, and I always use keys, even though you might get away without it for larger DP, ie, smaller teeth. But then again I drive my cutters fairly hard on rigid machines. Of course Brian is correct, there is no point in taking multiple cuts with involute cutters, it just wears them out and wastes time. Andrew |
Dave Smith the 16th | 29/06/2016 22:03:31 |
123 forum posts 33 photos | Proper supplier, mmm the internal threading tools i bought were from a company mentioned on here quite a bit. not sure if you class them as a proper tool supplier though. Or are they just a UK branch of a Chinese supermarket with ever changing stock that can vary from week to week? I need another trip to ARC or an online order for some digital scales i think Thanks.
not done it yet | 30/06/2016 09:53:09 |
7517 forum posts 20 photos | My one inch horizontal milling shaft does not have a key slot. Presumably this was deemed good enough for the full power of 1HP of the original motor.
Neither do my 250mm circular saw nor my angle grinder. Agreed, it may depend on the contact area and torque, but I doubt the average hobbyist really needs a key, in most situations, for gear cutting.
Select your tools carefully. Most rolson, silverline, black spur (and others) tools are avoided by me, unless they are for a one-off easy duty task. 'Buy cheap, buy twice' is a good maxim to follow.
Andrew Johnston | 30/06/2016 11:54:09 |
![]() 7061 forum posts 719 photos | Posted by not done it yet on 30/06/2016 09:53:09:
My one inch horizontal milling shaft does not have a key slot. Presumably this was deemed good enough for the full power of 1HP of the original motor. Neither do my 250mm circular saw nor my angle grinder. Agreed, it may depend on the contact area and torque, but I doubt the average hobbyist really needs a key, in most situations, for gear cutting. Select your tools carefully. Most rolson, silverline, black spur (and others) tools are avoided by me, unless they are for a one-off easy duty task. 'Buy cheap, buy twice' is a good maxim to follow. It might just be an economy measure to make the arbors cheaper? All my arbors, for both vertical and horizontal mills, have keyways. But the horizontal mill is 5hp with a gear box, so high torque when running a typical involute cutter at around 100rpm. I'd agree wholeheartedly with the maxim about not buying cheap tools; they're a complete waste of money. Andrew |
Brian Wood | 30/06/2016 14:19:54 |
2742 forum posts 39 photos | I think the biggest risk to tooling caused by operating without a driving keyway and relying on the grip from spacer collars alone is to slender cutters, like slitting saws. If the saw stalls in the cut, but feed continues to be applied, even by hand, the result may well be enough to shatter the cutter from buckling, something it cannot tolerate. Brian |
Howard Lewis | 04/07/2016 16:38:56 |
7227 forum posts 21 photos | Apprentices at R - R were taught NEVER to key a Slitting Saw. I narrowly escaped injury when a fellow Apprentice ignored the advice and the Saw shattered! If it jams, the saw just stops rotating. Have NEVER had a Slitting Saw shatter because of a jam up. I use my Involute Gear Cutters without keys and always cut full depth (d+f) have never had a jam up Better to slip than buy a replacement for a broken cutter. Howard
colin hawes | 04/07/2016 18:11:55 |
570 forum posts 18 photos | I don't use keys for any of my 1" and 1.25" bore cutters and I've never had a problem but then I don't expect industrial production rates. However, I could forsee a problem if the cutter was fitted in a dirty state and then tightened itself altering the position when gear cutting. Colin |
mark costello 1 | 05/07/2016 14:41:46 |
![]() 800 forum posts 16 photos | I slot 303 Stainless Steel, .051" wide ( sorry no Metric |
not done it yet | 07/07/2016 08:30:32 |
It might just be an economy measure to make the arbors cheaper? Andrew, It may not be the original arbor, but is likely. Doubt it was a cheap economy measure, if original, as it is a Centec.
