Anyone know what these are for?
Measurement/Set-up pieces from tyoolmaker?
Enough!13/05/2016 00:55:11
1719 forum posts
I recently purchased the contents of an ex-toolmaker's toolbox .... whole stack of external mics, depth mics, internal mics, calipers etc and a load of misc stuff. There's one set of bits that I can't identify (see pic). Does anyone know what they are?
They are solid cylinders, same height as diameter and are in sets of four. I have 1", 3/4" and 1/2" sets (the 3/4 set is missing one piece). They have a polished finish similar to slip gauges and I suspect are accurately sized.
Mike Poole13/05/2016 01:27:23
3676 forum posts
82 photos
They are Hoffman rollers and are very accurately sized both diameter and length. It would seem they are for use as standard sizes, I suppose for setting or checking other equipment.
Edited By Michael Poole on 13/05/2016 01:34:31
John McNamara13/05/2016 07:02:08
1377 forum posts
133 photos
Like measuring dovetails
Enough!13/05/2016 14:45:15
1719 forum posts
Michael .... thanks for that. It certainly narrows it down and at least I know what I'm looking for.
John .... Are you saying that measuring dovetails is their intended use or was it just a suggestion? I'm sure they could be used for that but, if it is their prime intended use, it seems odd that the sets come with (apparently) only one of each size. And why have the height accurately the same as the diameter? Plus gauge-pins seem to be the tool of choice for dovetail measurement.
Andrew Johnston13/05/2016 14:58:45
7061 forum posts
719 photos
I used one of mine for accurately gauging the curved slot in an expansion link during the final draw filing, after CNC milling, which was programmed to leave the slot approximately 2 thou undersize:
Hopper13/05/2016 15:33:19
7881 forum posts
397 photos
They are just bearing rollers out of rather largish bearings. Not intended originally for any specific use in the toolroom. But often used in place of precision parallels when clamping stuff in position. Very handy for putting behind items being clamped to the lathe face plate, or under items in milling vice etc. Will fit in odd shaped jobs where parallels migh t not. Could be used for measuring dovetails too. Or a thousand other uses for spacing or measuring.
John McNamara13/05/2016 15:42:09
1377 forum posts
133 photos
Maybe I was a bit brief when I said "Like measuring dovetails", cylinders are often used in measurement. this was just one example,
in a word they are handy.
John Fielding13/05/2016 15:57:22
235 forum posts
15 photos
Also used with a Sine Bar for setting angles accurately.
Mike13/05/2016 18:28:52
713 forum posts
6 photos
I used to have one given to me by a retired engineer for checking the accuracy of micrometers. Dodgy memory seems to suggest he said the one he gave me was part of the measurement system on a Newall jig borer. Can anyone confirm that?
Enough!13/05/2016 21:30:37
1719 forum posts
I've seen another reference to their use in checking mic accuracy ... particularly prior to using the mic for over-wire checking of threads.
Perhaps the reason for the accurate height as well as diameter is for use on mics with different anvils?
Dusty14/05/2016 09:50:03
498 forum posts
9 photos
Mike I can confirm that Newall Jig Borers did use a system of rollers for setting co-ordinates on the machine. I am afraid that all this is in the dim and distant past and I cannot recall exactly how the system operated. We ordinary toolmakers were not allowed into the Jig Borer cage other that to collect a component that had been bored. The Jig borer himself treated the rollers as if they were made of gold, cleaning them and putting them back into their storage unit after use.
Mike14/05/2016 10:25:42
713 forum posts
6 photos
Thanks, Dusty. My memory, at 75, is not as bad as I had feared!
mechman4814/05/2016 10:57:30
2947 forum posts
468 photos
+1 for Hoppers comment... rollers out of bearings, I have a couple kicking ( not literally face 20 ) about in my garage/workshop parallel storage drawer.
George.
Mark C14/05/2016 13:52:00
707 forum posts
I am not convinced they are just bearing rollers. Often big rollers in bearings do not have the end face ground as those in the picture. They often have a depressed end with just the outer 25% or so finished to size. I would be inclined toward the Hoffman roller suggestion but who knows just by looking!
Mark
Hopper14/05/2016 14:51:23
7881 forum posts
397 photos
Might be just a matter of terminology. Hoffman made plenty of roller bearings. Not sure if they had dimpled ends back n the days of yore, or plain. Certainly the boxed sets seem to have the plain ends, perhaps suitable for wringing together like Jo blocks? (in which case we probably wouldn't want to be using them for packers or parallels!)
Edited By Hopper on 14/05/2016 14:52:00
Michael Gilligan14/05/2016 15:15:48
23121 forum posts
1360 photos
Following Hopper's excellent lead ... Here is a set with a little more information.
However: Going back to the original question, it looks like some lucky toolmaker had sets of four [perhaps they were hand-me-downs from the Metrology Lab.]
Edit: Look at the Calibration values on the second picture in my link.
Edited By Michael Gilligan on 14/05/2016 15:18:34
Ed Duffner14/05/2016 18:37:31
863 forum posts
104 photos
Made some proper angular knurls using the straight knurls I made a while back and have been turning and knurling more brass knobs.
Also sorted out, for the most part, a parting off issue. Cleaned a load of splashed oil from the belts and pulleys in the change gear area of the lathe. I think this contributed to the poor parting and having the lathe on the higher belt (gear) setting. Whilst parting off it would suddenly grab and blow a fuse in the back of the control panel (good job I bought a box of 100 fuses!).
Had an idea to make a splash guard for the change-gear quadrant.
Completed the PCB for the Steve Ward indexer I'm building with a proper PCB, not my own etched effort. Temporarily powered by a 9v battery and It's Alive!
Ed.
Mike Poole14/05/2016 18:48:21
3676 forum posts
82 photos
Here is some info from the NPL on Hoffman rollers.
Ed Duffner14/05/2016 20:23:18
863 forum posts
104 photos
Sorry folks, I posted what I did today in the wrong thread. blush
Ed.
Chris Denton14/05/2016 22:16:34
275 forum posts
Strange, I bought an old toolbox at a car boot sale with loads of lathe and milling tools and it had some of these in.
