SINO SDS2L DRO Problem?
No Zero showing
Martin King 225/03/2016 15:51:04
1129 forum posts
Hi All,
I am in the process of fitting a SINO SDS2l DRO to my ML7 and have so far installed the long scale and read head at the back where the taper attachemnt would go. I have clocked the installation and bracketry and all seems good.
When I connected the scale to the display and fired it up it went through its startup and seemed to work OK....
Until I pressed the X button to zero the scale when all I got was a decimal point.
No matter what I do I cannot get a row of zeros to come up.
I have swithced the axies and taken a couple of pics, first an arbitrary position then after hitting Z/Zo, just the decimal point.
Have tried all sorts of scrolling throught the ABS & INC modes but no go.
Any thoughts please or have I bought a pup?
MW25/03/2016 16:03:36
2052 forum posts
56 photos
I'm not an expert at this but i have had errors with my DRO before that were scale related rather than the readout itself (dirty contact/poor contact). To rule this out, could you try switching the leads for scales for each axis over just to make sure it's not an error with the scale?
P.s having re-read this i can see you've already tried that, It could well be a problem with the setup or maybe a duff lead?
Michael W
Edited By Michael Walters on 25/03/2016 16:06:40
Nick Hughes25/03/2016 16:18:11
307 forum posts
150 photos
Have you tried pressing the "ZERO" key on the top row?
Also try "0" then "ENTER"
Last resort Read the Intruction Manual?
P.S. Just did some digging and found "Select Axis then press CLS"
Nick.
Edited By Nick Hughes on 25/03/2016 16:47:11
Clive Foster25/03/2016 16:42:36
3630 forum posts
128 photos
I have the 3 axis, mill, version but zeroing should be the same.
Key sequence to zero is :- X ... 0 .... Ent. If you want to put an offset in same sequence but insert the offset number.
Martin King 225/03/2016 19:26:04
1129 forum posts
Yup! That did the trick, many thanks indeed.
Couple of other queries please,
Can you confirm that the Z axis is the left right of the carriage and the X axis is cross slide travel?
How do I use the radius/diameter control please?
Martin
Martin King 225/03/2016 19:27:06
1129 forum posts
Btw, I do not have a manual and cannot find one for this specific model
Ian P25/03/2016 19:47:44
2747 forum posts
123 photos
Posted by Martin King 2 on 25/03/2016 19:27:06:
Martin
I have the same DRO as you. Someone here kindly sent me a PDF version of the manual so if you PM me your email address I will forward it to you.
Ian P
Martin King 225/03/2016 19:58:45
1129 forum posts
Ian, PM sent, many thanks
Martin
mechman4826/03/2016 12:32:35
2947 forum posts
468 photos
... 'Can you confirm that the Z axis is the left right of the carriage and the X axis is cross slide travel?'
'X' axis is table travel left to right... 'Y' is front to back... 'Z' is up & down
George.
David Colwill26/03/2016 12:36:03
782 forum posts
40 photos
Posted by mechman48 on 26/03/2016 12:32:35:
George.
Hi that is for a milling machine. On a lathe the carriage is Z and the cross slide X.
The Z axis is always in line with the spindle. (OK there may be exceptions).
Regards.
David.
Martin King 226/03/2016 12:36:54
1129 forum posts
Hi George , I understand that to be the nomal convention, but this DRO for a lathe only has X & Z Axes and I have been told that X mustbe the cross slide in order for the Radius/Diamter button to work but I cannot confirm this in the manual?
Martin King 226/03/2016 12:37:48
1129 forum posts
Sorry David C , my post crossed with yours, thanks for the ereply.
Martin
Jon29/03/2016 23:24:34
1001 forum posts
49 photos
X has always been longitudinal whether mill, grinder or lathe.
Some drawings even refer to longitude being X and Y width.
Andy Holdaway30/03/2016 07:19:33
167 forum posts
15 photos
On my Sino DRO, X has to be for the cross slide for the radius / diameter to work. If you look at your first picture there is 'RAD' under the X display - a decimal point appears here when in radius mode. The taper calculation function also requires that X is the cross slide.
mechman4830/03/2016 19:03:25
2947 forum posts
468 photos
FWIW for clarification re axes...
George.
