John Munroe | 16/03/2016 11:33:57 |
50 forum posts | Hi all I'm hoping to mount a metal U-bracket on a 5mm steel rod so that the bracket can freely rotate on that rod. The rod should protrude about a few millimetres into the bracket. Does anyone know of a good way to mount the bracket on the rod so that it won't slide along along the rod? Would some kind of a stopper be needed? Any help appreciated.
Thanks John |
Ed Duffner | 16/03/2016 11:57:10 |
863 forum posts 104 photos | Hi John, How about a collar with a set screw? Ed. |
John Munroe | 16/03/2016 13:06:16 |
50 forum posts | Hi Ed, Do you mean a collar on each end or just on the back? Will a set screw apply enough pressure since the surface of the rod is round? Thanks John |
Ian P | 16/03/2016 13:20:28 |
![]() 2747 forum posts 123 photos | Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P |
Jeff Dayman | 16/03/2016 13:33:05 |
2356 forum posts 47 photos | As Ian says the design of the retainer will depend on how much load the bracket will see in use, and from what direction. If collars are used one could be silver soldered on, the other setscrewed or split and cross drilled / tapped to make a clamping collar. If setscrewed a flat could be cut on the rod to a) assist holding/prevent slipping b) prevent a divot being raised on shaft that could make disassy a problem. Cross drilling 0.5 mm in two places and use of two washers and small cotter pins a set each side of bracket may suffice if loads are very light. About 50 ways and combinations of ways to do it. Tell us more. JD |
Michael Gilligan | 16/03/2016 13:33:10 |
![]() 23121 forum posts 1360 photos | Posted by Ian Phillips on 16/03/2016 13:20:28:
Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P . Subject to Ian's caveats These may be even simpler MichaelG. |
John Munroe | 16/03/2016 14:47:22 |
50 forum posts | Posted by Ian Phillips on 16/03/2016 13:20:28: Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P Hi Ian, Actually, my original plan was to use two e clips. Do circlips and e clips serve different applications? The bracket is rotated and the torque is around 0.3N-cm. My current idea is something like this (bracket end) E clip, washer, teflon washer | teflon bushing | teflon washer, washer, E clip (rod end) where | xxxx | denotes the bore in the bracket. I wonder if a washer is needed between E clip and teflon washer? The clip is held fixed by the groove, so it wouldn't exert much pressure on the teflon washer, right? Edited By John Munroe on 16/03/2016 14:47:52 |
John Munroe | 16/03/2016 14:50:54 |
50 forum posts | Posted by Michael Gilligan on 16/03/2016 13:33:10:
Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P . Subject to Ian's caveats These may be even simpler MichaelG. Hi Michael, Do you know how these fasteners are different to circlips/e clips? Thanks John |
John Munroe | 16/03/2016 14:54:35 |
50 forum posts | Posted by Jeff Dayman on 16/03/2016 13:33:05:
As Ian says the design of the retainer will depend on how much load the bracket will see in use, and from what direction. If collars are used one could be silver soldered on, the other setscrewed or split and cross drilled / tapped to make a clamping collar. If setscrewed a flat could be cut on the rod to a) assist holding/prevent slipping b) prevent a divot being raised on shaft that could make disassy a problem. Cross drilling 0.5 mm in two places and use of two washers and small cotter pins a set each side of bracket may suffice if loads are very light. About 50 ways and combinations of ways to do it. Tell us more. JD Hi Jeff, The bracket is turned with a torque of roughly 0.3N-cm. The speed is around 20RPM. With the cotter pin idea, should the washers be standard ones or teflon ones? Also, wouldn't a bushing be needed to avoid the bracket from wearing out? Thanks John |
Michael Gilligan | 16/03/2016 14:59:08 |
![]() 23121 forum posts 1360 photos | Posted by John Munroe on 16/03/2016 14:50:54:
Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P . Subject to Ian's caveats These may be even simpler MichaelG. Hi Michael, Do you know how these fasteners are different to circlips/e clips? Thanks John . Yes . . They don't use a groove ... They push on, and lock by friction MichaelG. |
JasonB | 16/03/2016 15:07:59 |
![]() 25215 forum posts 3105 photos 1 articles | Michael's will be easiest as no groove is needed provided you can get to the other end of the rod to slide the inner one on. If not stick with your idea of E-clips, large flat washers and then teflon washers if you make one washer a "top hat" one with a spigot then that will bush the hole in the bracket too. Edited By JasonB on 16/03/2016 15:08:38 |
Ian P | 16/03/2016 15:08:05 |
![]() 2747 forum posts 123 photos | Posted by John Munroe on 16/03/2016 14:47:22:
Posted by Ian Phillips on 16/03/2016 13:20:28: Without knowing the purpose/loading of your application its hard to be specific. The simplest method would be two circlips in grooves close to the end of your rod. Ian P Hi Ian, Actually, my original plan was to use two e clips. Do circlips and e clips serve different applications? The bracket is rotated and the torque is around 0.3N-cm. My current idea is something like this (bracket end) E clip, washer, teflon washer | teflon bushing | teflon washer, washer, E clip (rod end) where | xxxx | denotes the bore in the bracket. I wonder if a washer is needed between E clip and teflon washer? The clip is held fixed by the groove, so it wouldn't exert much pressure on the teflon washer, right? Edited By John Munroe on 16/03/2016 14:47:52 I used the term circlip in a generic sense. Since you know the operating speed, loading and presumably other details, what you end up using is going to depend on what materials are involved, what engineering facilities you have and also how much you want to spend! Mainly though its the end use or purpose that will determine what is the best approach. How much play/looseness can you tolerate in the joint, does it matter if it a rattling fit, there might even be a rattle (noise) that detracts from the final product's acceptability, Slightly preloading the already mentioned PTFE washers would prevent noise. Ian P |
jason udall | 16/03/2016 15:36:07 |
2032 forum posts 41 photos | Minimal Turn shoulder On rod using smaller hole in bracket Pien end Or if a elegant Counter sink bracket Shoulder rod. Drill/tap rod axillary Screw into end of rod with thread lock. How to get there requires knowledge of where you are |
John Munroe | 16/03/2016 17:48:37 |
50 forum posts |
Posted by JasonB on 16/03/2016 15:07:59: Michael's will be easiest as no groove is needed provided you can get to the other end of the rod to slide the inner one on. If not stick with your idea of E-clips, large flat washers and then teflon washers if you make one washer a "top hat" one with a spigot then that will bush the hole in the bracket too. Edited By JasonB on 16/03/2016 15:08:38 Hi Jason, Right. How come flat washers are needed to sit in between of e clips and teflon washers? Can the e clips not push against the teflon washers directly? The grooves should stop the e clips from moving - right? |
JasonB | 16/03/2016 18:24:36 |
![]() 25215 forum posts 3105 photos 1 articles | Well you obviously thought they were needed as you thought of it first! My current idea is something like this (bracket end) E clip, washer, teflon washer | teflon bushing | teflon washer, washer, E clip (rod end) My thoughts are that E-clips are quite small dia so could start to cut into the teflon washer. What was your reason for suggesting washers? |
John Munroe | 17/03/2016 11:20:04 |
50 forum posts | Hi Jason, Well, there really wasn't a clear rationale, but I thought it might be better for a piece of irregularly shaped metal to press on a metal washer rather than plastic (teflon). I haven't used teflon washers before, so I'm not sure how durable they are. |
Jeff Dayman | 17/03/2016 12:31:32 |
2356 forum posts 47 photos | How many rotations does it have to do in its' life? Can it be lubricated with grease? Is there much dust present where this device will operate? These questions will help answer whether using PTFE (teflon) washers is practical or useful or not. You have had some excellent responses with many good ideas for construction. Now will you tell us what this is for? JD |
Neil Wyatt | 17/03/2016 19:01:33 |
![]() 19226 forum posts 749 photos 86 articles | Changing fuel rods in a nuclear reactor. EDF have decided they need to make a few savings on the design costs for Hinckley C. Neil |
Hopper | 18/03/2016 02:57:19 |
![]() 7881 forum posts 397 photos | So, what us this mechanism going to do? What is it? Or what is it part of? If it is going to be doing 20rpm for extended periods you probably need some kind of bearing or at least bronze bushing in place if you don't want it to wear and flop about all over the place. |
Speedy Builder5 | 18/03/2016 07:01:32 |
2878 forum posts 248 photos | I think it may be a homework question for a mechanical engineer ?? |
