A new arrival to my workshop family.
Russ B16/03/2016 10:44:13
635 forum posts
34 photos
Thats right, a new arrival to my workshop family. I delivered her naturally myself around 19:00, I'm happy to report she's 5ft long and weights a healthy 860lbs. Her name is Myford 280
cheeky
I now have a serious amount of tidying to do as I had to empty the cupboard of my old Super 7 stand all over the bench when I sold it at the weekend and now need to fabricate a cupboard under the new stand (easy enough, the steel mid section is just a 1mm thick sheet screwed to some angle brackets that are tacked on - basically it's a nice blank canvass for me to fabricate something. I'm going have a cupboard ontop with a very heavy duty drawer underneath at floor level (set back to leave room for toes!)
John Hinkley16/03/2016 11:26:44
1545 forum posts
484 photos
Congratulations, Russ, I am sure she will bring you many hours of happiness. I assume that you have identified the new arrival as a "she" because it has no tail(stock)!
Steven Vine16/03/2016 12:01:21
340 forum posts
30 photos
And now you have to keep her for the rest of her life. She'll need care and constant attention, and will call to you morning noon and night, She'll cost you a fortune, She'll want new things all the time. She won't clean up after herself (they never do). When she grows up and gets older, she will cost you even more. What have you done!
Kids eh, who'll have em.
That does look great.
Steve
Edited By Steven Vine on 16/03/2016 12:02:36
Nigel Bennett16/03/2016 12:46:30
500 forum posts
31 photos
Was that the one on eBay from South Wales? I rather fancied it, too, and if it had been nearer home I'd have bought it. As luck would have it, a Boxford 280 came my way instead. Not run it yet but it smells rather of new paint...lot of wiring-up to do as well. And as Steven Vine has said, it's costing me a fortune...
Russ B16/03/2016 13:50:57
635 forum posts
34 photos
John, don't worry, its all safely tucked away, I was adding and removing things as required to tip the balance to get it in and out the van safely!
Steve, she's already demanding a host of new accessories, an 8 inch D1-3 4 jaw Pratt Burnerd landed on my desk today, she made me do it. She also demands a fixed steady but I think I'll have make one as sadly I've even seen a picture of one - so the chances of actually finding one are probably slim to none!
Nigel, Yes that's the one. It has a few bits that need tidying up but it's all there and its all in excellent condition, it was in a school or college but having seen the state of most training lathes this one has clearly avoided the students (ie no chuck marks in the cross slide, no marks on the vee ways, all the gears work (and there were LOTS to check!) - I'm pleased as punch really
mechman4816/03/2016 15:50:56
2947 forum posts
468 photos
Well done Russ nice looking bit of kit; I always get green eyes when I see what others have bought
George.
Nick_G16/03/2016 16:49:38
1808 forum posts
744 photos
Looks a very, very nice piece of kit. yes
Nick
John Stevenson16/03/2016 20:35:06
5068 forum posts
Russ,
Check your hotmail account
Neil Wyatt16/03/2016 21:03:40
19226 forum posts
749 photos
86 articles
Nice machine, Russ.
Always surprised we don't see more of the 'light industrial' Myfords in comparison to Colchesters etc.
Russ B16/03/2016 23:15:50
635 forum posts
34 photos
George, Nick, thank you for the nice comments yes
John, thank you very much!
Neil, I've spent most of this evening sorting issues out in the headstock - nothings damaged, I suspect its purely bad design (I have an early version, these issues would be easily resolved)- maybe this is why they didn't take off initially - I wonder if they picked up a bit of bad reputation?? I was certainly surprised, and studied over the litrature and sectional drawings, all the parts are present and correct, its all in the right order, no washers, spacers, etc etc have been assembled in the wrong order - its all there, its just not very good sadly.
The main issue has been on the first 2 pairs of gears which can be selected, the sliding pair are fine, but the static pair are keyed and press fitted onto a hub which transmits power to the shaft it is sat on. In the photo (the in focus gears) I have gently tapped the right gear back upto the shoulder, it had slid off just as far as the one on the left which is almost touching the casting, it should be right up to that shoulder. There are no securing screws, no circlips, no grub screws in the end of the shaft. What happens is, when moving the sliding gears, if they don't mesh as they slide towards the left/right, they lightly "tap" and naturally, you rock the spindle a little by hand - unfortunately just that little tap, is enough to knock the gear off its hub!
So, I'm not wildly impressed with that design. but it does look easily resolved (IF, and this is HUGE if, I can get the gears, and that hub, out of the box, without taking the spindle out which looks very, very unlikely) - so, I'm surprised it even made production, I can only assume my gears are not quite tight enough on the shaft, of someone forgot to apply so sort of adhesive (can you even bond a gear to shaft in an oil bath?)
The near end of this shaft is supported by a roller bearing with an oil seal etc -.no problems there. The far end is supported by an oilite bush which acts as a thrust against (again) only the tapping created by gently shifting the sliding gears into it - again a miss match would create a gentle knock, and again, this is enough to just gently tap the bush out of position I can easily resolve this without stripping the gearbox by tapping the bore through the casting (or fitting a threaded plate to save damaging the bore if the shaft needs to come out that way) and then fitting a threaded thingimajig to just sit against the bush and hold it in place.
Fixing the pressed gears is a bit more difficult. The only access is the large cover over the spindle, and the spindle blocks it in as the shaft those troublesome gears are sitting on are behind it.I could possibly try to extract the shaft far enough for those gears to become free, but getting fingers back in to reasseble, or even remove that lot...... unlikely....
Apart from the dooooooooom and gloom, I'm really pleased with it. It's all there, none of it is damaged and bar that one pair of gears and the bush, it is very, very well made.
Edited By Russ B on 16/03/2016 23:19:23
