Todays quiz question
John Fielding | 15/03/2016 14:35:12 |
235 forum posts 15 photos | In an old engineering text book I came across some names of things I hadn't seen before and I wondered how many readers know what they refer to: Half Imperial Imperial Double Elephant Antiquarian They all relate to the same type of object - What is it?
Jeff Dayman | 15/03/2016 14:39:49 |
2356 forum posts 47 photos | Paper sizes, old ones. JD |
Andrew Johnston | 15/03/2016 14:40:41 |
![]() 7061 forum posts 719 photos | Posted by Jeff Dayman on 15/03/2016 14:39:49:
Paper sizes, old ones. JD Yep, everyone kno that, even Molesworth! Andrew |
Bubble | 15/03/2016 14:47:51 |
75 forum posts 6 photos | Hello In my day on the Railway they referred to drawing board sizes Jim |
John Fielding | 15/03/2016 14:56:10 |
235 forum posts 15 photos | Yes, you are correct. This book was published in 1908. I had never heard of them, but I wasn't around in 1908 BTW Who is Molesworth? Edited By John Fielding on 15/03/2016 14:56:59 |
Lambton | 15/03/2016 15:13:29 |
![]() 694 forum posts 2 photos | Molesworth ah! I have a copy of his pocket book. |
Neil Wyatt | 15/03/2016 15:35:16 |
![]() 19226 forum posts 749 photos 86 articles | To late in the day to catch us on that one Anyone know why foolscap is called that - without cheating? Neil |
John Fielding | 15/03/2016 15:41:23 |
235 forum posts 15 photos | Aaaah Neil, You will be asking us what a "Sagger Makers Bottom Knocker" Also found another reference to paper types: Whatman's NHP |
Michael Gilligan | 15/03/2016 15:42:56 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 15/03/2016 15:35:16:
Anyone know why foolscap is called that - without cheating? . Yes ... It's proportions are the Golden Section, the same as a Fool's Cap MichaelG. |
Ajohnw | 15/03/2016 15:50:26 |
3631 forum posts 160 photos | I needed to check but as I thought the name probably comes from watermarks that were used. Things have been A4 etc for as long as I had been in work. Even detail drafting - an A0 sheet a day keeps the doctor away - no space wasted. A GA might take a bit longer. Makes me laugh when I see people using cad but that sort of speed does take a while to acquire. Getting black lines too with a pencil. John - Edited By Ajohnw on 15/03/2016 15:51:13 |
John Fielding | 15/03/2016 16:17:52 |
235 forum posts 15 photos | Hi Ajohnw,
Almost, NHP stands for "Not Hot Pressed" there was a Whatman's HP paper as well (Hot Pressed) and apparently in those days all paper had a watermark. The things you learn in book ....Eish |
Andrew Johnston | 15/03/2016 16:46:30 |
![]() 7061 forum posts 719 photos | Posted by John Fielding on 15/03/2016 14:56:10:
BTW Who is Molesworth? The scourge of St Custard's; see this link: Andrew |
Neil Wyatt | 15/03/2016 22:39:01 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Michael Gilligan on 15/03/2016 15:42:56:
Anyone know why foolscap is called that - without cheating? . Yes ... It's proportions are the Golden Section, the same as a Fool's Cap I hope that's a jest > Things have been A4 etc for as long as I had been in work. It was defined as a standard in 1975. Neil |
charadam | 15/03/2016 23:06:51 |
185 forum posts 6 photos | Having worn one a time or two, I think foolscap (13.5x8,5 inches) is just the right size to form a Dunces' cap. Edited By charadam on 15/03/2016 23:07:21 Edited By charadam on 15/03/2016 23:09:04 |
Bazyle | 16/03/2016 07:31:00 |
![]() 6956 forum posts 229 photos | Also found in old book. Anyone got an odontograph? An original not a copy. I saw one in a museum but I just can't remember which one. usual rules - no googling though there is only one dictionary that recognises it and clearly doesn't know what it is. Edited By Bazyle on 16/03/2016 07:34:23 |
Andrew Johnston | 16/03/2016 08:45:44 |
![]() 7061 forum posts 719 photos | Posted by Bazyle on 16/03/2016 07:31:00:
Also found in old book. Anyone got an odontograph? An original not a copy. I saw one in a museum but I just can't remember which one. No, only a reprint in a book on gear design. Andrew |
pgk pgk | 16/03/2016 09:04:46 |
2661 forum posts 294 photos | Posted by John Fielding on 15/03/2016 14:35:12:
Some impressive knowledge here. I though these were portions of chips.. 2/6d worth 5 Bobs worth An American portion A special order for secondhand bookshop owners.
And an odontograph is a tool for calibrating overbite in brace design...
Ian S C | 16/03/2016 10:36:08 |
![]() 7468 forum posts 230 photos | Bazyle, was it Collins English Dictionary? Odontograph: An aid to marking out gear teeth in which a circular curve is substituted for the true involute curve |
Bazyle | 16/03/2016 18:44:29 |
![]() 6956 forum posts 229 photos | Posted by Ian S C on 16/03/2016 10:36:08:
Bazyle, was it Collins English Dictionary? Odontograph: An aid to marking out gear teeth in which a circular curve is substituted for the true involute curve Yes, that really tells you a lot doesn't it |
Neil Wyatt | 16/03/2016 20:04:28 |
![]() 19226 forum posts 749 photos 86 articles | The dunce's cap is an urban myth, anyone who remembers foolscap will know that it makes a hat suitable only for a toddler! The real reason is that it used to bear a watermark of a jester's (fool's) cap. Some excellent examples HERE Neil |
