HasBean | 26/02/2016 15:23:38 |
141 forum posts 32 photos | Following on slightly from the rusty wire thread, is it possible to use MIG wire for TIG welding? As it was costing me well over £100 a year just to rent the gas bottle and then realising I hadn't used it for 4 years back the bottle went to BOC (my only choice as far as I'm aware). Now having the urge to try TIG and having 5 Kg reels of 0.8mm MIG wire lying around is it of any use for TIG, or anything else for that matter? (Before I start coughing up £120 a year for argon!)
Paul |
Ian Parkin | 26/02/2016 15:32:04 |
![]() 1174 forum posts 303 photos | A few years ago i took a bottle to exchange to BOC and the chap said the last one I had was 11 years before So I looked around and got a bottle from a local welding supplier £100 for the bottle for life and £30 a refill I now have 2 one for MIG and one for TIG |
michael darby | 26/02/2016 15:45:07 |
48 forum posts | Hi, yes you can use your mig wire.however its quite thin and it will be difficult to control the weld pool temperature,by using the wire. |
Roger Vane | 26/02/2016 16:06:13 |
108 forum posts 18 photos | Hi Paul I had the same problem with gas supplies - rental was becoming very expensive from Air Products for my occasional usage. If you're in the south-east you might like to try Adams Gas based in Margate - **LINK** or one of their local stockists. Welding gases at around £36 per fill (for 9 litres) and a £55 deposit (you get it back when you return the bottle). No annual rental charges or handling fees. Very good value for low or occasional usage. If you're not in the south-east then I believe they have a network of stockists covering other parts of the country, and if not suitable then I'm sure that there are other suppliers around with a similar service. Good luck
Spurry | 26/02/2016 16:07:23 |
227 forum posts 72 photos | If you get annoyed with the rental cost, as I did , I have found this outfit very useful. Pete |
HasBean | 26/02/2016 16:17:51 |
141 forum posts 32 photos | Thanks gents but as I'm in Jersey the options are BOC or err BOC! I know Air Products are available but only to business' it seems. |
Gray62 | 26/02/2016 16:22:34 |
1058 forum posts 16 photos | I just bought bottles for my MIG and TIG sets from Gas UK, very reasonable prices and unlike AdamsGas, they will supply a 20 Litre bottle to non trade customers. I've tried using MIG wire for tig and, unless you are doing micro welding, the 0.8 wire is just too thin to allow good control. Minimum I normally use is 1.6mm |
blowlamp | 26/02/2016 16:52:56 |
![]() 1885 forum posts 111 photos | Cut off several lengths and twist them together in an electric drill to form the equivalent of a thicker rod.
Martin. |
