Andy Sproule | 22/02/2016 14:12:28 |
122 forum posts 35 photos | Hi,I have just got a Startrite 352 SB band saw which I have converted from three phase to single phase.Three of the ceramic guides on the lower part of the saw are missing.These ceramic guides are 5x5x25mm and are slipped into an aluminium housing.I contacted a few suppliers about replacements and they said I had to purchase the two housings along with the four ceramic guides which would cost £100.Does anyone know if and where the ceramic could be bought on its own.Has anyone encountered this and found a cheaper solution?Any help would be greatly appreciated |
ian j | 22/02/2016 15:19:18 |
![]() 337 forum posts 371 photos | Andy. I believe they used to use lignum vitae wood as guides on bandsaws. Very hard & self lubricating.
Here is a source :-http://www.turners-retreat.co.uk/timber/pen-blanks/5-8-blanks/lignum-vitae-5-8-x-5-8-x-5
Or crown green bowls are a good source as well, but you will need a bandsaw to cut it Ian Edited By ian j on 22/02/2016 15:26:24 |
Bob Rodgerson | 22/02/2016 16:45:33 |
612 forum posts 174 photos | Best ask the Bowler first though |
Kevin Bennett | 22/02/2016 17:42:27 |
![]() 193 forum posts 56 photos | at our works we used old turning tips also for the back blade stop |
Peter Hall | 22/02/2016 18:03:05 |
115 forum posts 1 photos | I once had a small startrite bandsaw. I used to use square section brass for the blade guides. Not quite the same arrangement as yours and probably wears quicker than ceramic, but should be OK unless you are using it all day every day.
Pete |
Bazyle | 22/02/2016 19:01:10 |
![]() 6956 forum posts 229 photos | On my Startrite that takes a round back stop (and cast iron side guides) I just use HSS. It came with mild steel rod as the carbide button had been knocked off. |
Sam Longley 1 | 22/02/2016 19:43:43 |
965 forum posts 34 photos | Speak to plastics direct & buy a small piece of R1000 plastic or say tufnol whale.You could cut loads from a small piece - say 250*250 * 6mm th. These are excellent for bearing material & should do the job just as well |
Vic | 22/02/2016 20:35:12 |
3453 forum posts 23 photos | One of my old bandsaws had 1/4" section bronze bearings. You could also convert your bandsaw to use bearing races, there are a few suppliers. |
Bazyle | 22/02/2016 21:06:34 |
![]() 6956 forum posts 229 photos | ball bearing guides may be an option see review No2 in this |
Andy Sproule | 22/02/2016 21:51:35 |
122 forum posts 35 photos | Thanks great ideas there will try them out. |
