Westbury's Wombat
JasonB08/02/2016 17:28:31
Has anyone built this engine? Reason for asking is that looking through the old issues of ME (3351-55) that the design was covered in there are differences on the positions of the ports as the crankcase has them dimensioned differently to the liner drawing when they should be the same?
I've looked through following issues and can't see any erata mentioned
Thanks, J
Neil Wyatt09/02/2016 10:32:59
19226 forum posts
749 photos
86 articles
ETW didn't make errors. I'm sure that was just a way of increasing turbulence to improve fuel mixing
Circlip09/02/2016 11:32:49
1723 forum posts
An American builder has suggested that he gave up trying to make a Wombat due to a series of errors in the drawings.
Regards Ian.
Roderick Jenkins09/02/2016 11:38:07
2376 forum posts
800 photos
Posted by Circlip on 09/02/2016 11:32:49:
Or possibly Canadian? - the circle is complete smiley
Rod
JasonB09/02/2016 11:51:05
Yes Brian has given up his attempt to make a simplified version which is who I was asking on behalf of.
Neil, I now have it on good authority from one of the "Motor Boys" that Westbury did not get to make this engine as it was his last design he was in ill health at the time it was drawn up. The resulting errors could in Westbury's own words cause the crankcase to expload which would be quite turbulent!
JA09/02/2016 12:12:35
1605 forum posts
83 photos
Posted by Neil Wyatt on 09/02/2016 10:32:59:
Although he did get the conrod length on his Whippet wrong. And it did not increase the turbulence.
JA
Neil Wyatt09/02/2016 13:21:30
19226 forum posts
749 photos
86 articles
I jest of course.
Although I have a basket case Seal awaiting attention one day. The crankcase is all from the solid, and all the con rods have been carefully bushed in bronze at their big ends.
Unfortunately this means that the crank won't rotate in the crankcase with the rods fitted, no wonder the original builder gave up in disgust - but his fault not ETW's!
duncan webster09/02/2016 13:32:20
5307 forum posts
83 photos
Neil says "ETW didn't make errors." Are we to assume he didn't make anything then? His Jubilee Clock by all accounts wasn't a stunning success.
Edited By duncan webster on 09/02/2016 13:32:43
John Stevenson09/02/2016 14:22:47
5068 forum posts
That was only because it wasn't a Jubilee year . wink
JA09/02/2016 14:49:02
1605 forum posts
83 photos
I was told by an eminent present day model designer that ETW probably employed a model maker to make his models. I guess that communications were only one way.
Neil - do you or any of your staff check drawings that are submitted with articles? Or is it a case of user beware? I imagine it has to be the latter.
JA
Neil Wyatt09/02/2016 15:16:27
19226 forum posts
749 photos
86 articles
Posted by JA on 09/02/2016 14:49:02:
Well we look at them and try and spot obvious errors, but unless you are an expert draughtsman you can only check all but the simplest drawings by building the thing (unless it's in a 3D package). Obviously not practical to do this.
There's a plan in the next MEW that has been done in a 3D package so everything SHOULD fit but I bet some SA will find an error.
Neil Wyatt09/02/2016 15:19:47
19226 forum posts
749 photos
86 articles
Some of ETW's writings (e.g. as Ned and Artificer) make it clear he had abundant practical experience, though its possible had used the services of others from time to time. Even LBSC didn't actually build all his designs though I doubt he would have accepted anyone else's work!
