Ajohnw | 03/02/2016 12:16:06 |
3631 forum posts 160 photos | This is the sort of sale I feel people should look for when buying a lathe. A little down this page Boxford VSL. Be interesting to see how long it takes to sell. Often if there is a lot of kit people are inclined to think the price is a too high. Much depends on wear. I would want to know some of it's history and try it but other than I have to have a bench lathe I would be in for a long drive. John - |
David Colwill | 03/02/2016 14:33:43 |
782 forum posts 40 photos | Whilst I can see some people saying it's a bit expensive, it does look like a very nice machine. Provided that it isn't too badly worn it will make someone very happy. You would be struggling to get that spec with a new Far Eastern machine for the same money. Perhaps we will hear from its new owner shortly. Regards. David. |
Ajohnw | 03/02/2016 16:11:38 |
3631 forum posts 160 photos | It's the last version of the VSL. Big bore and a neat variable speed. Some have hardened beds.
Nothing to do with me by the way. Just noticed in passing. John - |
here again | 03/02/2016 18:28:58 |
70 forum posts | My old Drummond has its stand with slots in for a belt drive from underneath..Never seen HomeWorkshop before when theie security certifacate is sorted I ll put it on there |
Sandgrounder | 03/02/2016 19:18:23 |
256 forum posts 6 photos | Posted by Ajohnw on 03/02/2016 12:16:06:
This is the sort of sale I feel people should look for when buying a lathe. A little down this page Is it just me as I can't see anything on the "LINK" except ? Issues with our serverWe will be backWe have had a few issues with the server that the site runs on and are atempting to fix them as quickly as possible."
John Stevenson | 03/02/2016 19:38:17 |
![]() 5068 forum posts 3 photos | Hit Control F5, you are looking at an old page. |
mgnbuk | 03/02/2016 20:02:29 |
1394 forum posts 103 photos | Some have hardened beds. Some Boxfords do indeed have hardened beds - but not the VSL / L00 (or any of the Southbend-type 3 vee bed lathes). I spent the last year of my apprenticeship at Boxfords & was involved with the installation and commisioning of the Snow grinder & Radyne induction hardening plant installed for hardening & grinding the Industrial 10-20 and 11-30 geared head lathe beds. Prior to this installation (around March 1981) there was no bed grinder, as the "original" Boxford beds were gang milled (all vees, flats & vertical faces produced in one pass) on a very substantial Russian Duplex horizontal milling machine. I seem to recall asking if the "original" beds would be hardened after installation of the new plant but, IIRC was told that they could not be hardened as they would distort. (There were initially issues with distortion during hardening with the later beds, but a "fix" for this was worked out during comissioning). After milling(one "heavy" pass & a lighter "finish" pass IIRC) the only treatment the bed top faces received was a light pass over with very fine abrasive paper by the fitter prior to bedding on the saddle. At the time Boxford offered a bed re-machining service - old beds would collect near the Duplex miller & when there were several waiting they would be run through as a Friday afternoon "overtime" job - each one had to be individually set up, so it was a slower job than normal production. I asked whether this service was still available some years ago when I was refurbishing my late father's CUD & was told it wasn't - I suspect that production of the "original" machines ceased not very long after I left (September 1981) & there was probably not enough demand to warrant keeping the cutter gangs set up. I was seconded back to Boxfords during 1982 to wire the last Hayes copy mill & also to wire the first development CNC Boxford based on the Industrial 11-30 & recall a large batch (50 or more) of ME10s in Reseda Green (not the usual for the time beige/brown), which were apparently a "special order" for the US distributor. (At the time Boxford was part of the Brooke Tool Group, which also included Hayes milling machines from Leeds and Broadbent Machine Tools from Mytholmroyd - I had been seconded to Hayes for a few weeks at one point while at Boxfords & went to work at Broadbents when I was out of my time. The Hayes factory closed & remaining machines and spares were moved into the Boxford works & I was seconded from Broadbents to wire the last machine). At the time the grinder was installed, there were only induction electrodes (for want of a better word) for the later type bed & the grinding wheel profile dresser was only capable of dressing one profile on the wheel. In practice the bed was gang-milled like the "original" bed using a different cutter gang, then the bed was mounted in a fixture on the grinder table. The hardening equipment was mounted at the LHS if the machine & the bed was passed slowly under the "electrode" - the area underneath glowed bright red & was immediately quenched with coolant as the bed passed through. Then the table moved under the grinding wheel, which form ground the entire top surface using a wide profiled wheel. At the RH end of the table was the diamond dresser, which was used to clean up the wheel after each bed had been ground. I can be pretty certain of the dates, as I got an SLR camera for my 21st birthday & put the first film through wandering around the works -including some of the bed hardening process "in action" - that would be early April 1981.
Nigel B. |
Hollowpoint | 03/02/2016 20:21:41 |
550 forum posts 77 photos | I have an AUD which I love |
Ajohnw | 03/02/2016 20:37:54 |
3631 forum posts 160 photos | There has been some debate about Boxfords and bed hardening on the yahoo group. One VSL owner seems sure his was. I vaguely remember an ME10 add in one of the model engineering mags that I think mentioned it in a sort of look at all of this compared with Myford. Must admit I am not sure. Could it be that flame hardening was used at some point? In the distance past I have seen a video of one of the makers doing it like that. Not sure which one and it was years ago, many of them. John _ |
thaiguzzi | 04/02/2016 04:51:29 |
![]() 704 forum posts 131 photos | Nigel B., thank for posting. Very interesting write up. From a Boxford fan. (mk II VSL and 8" shaper owner) |
Sandgrounder | 04/02/2016 07:14:50 |
256 forum posts 6 photos | Posted by John Stevenson on 03/02/2016 19:38:17:
Hit Control F5, you are looking at an old page. Thanks John. John |
Robbo | 05/02/2016 18:53:32 |
1504 forum posts 142 photos | "Be interesting to see how long it takes to sell"
Well it's gone, that didn't take long. |
Ajohnw | 05/02/2016 23:29:40 |
3631 forum posts 160 photos | Posted by Robbo on 05/02/2016 18:53:32:
Well it's gone, that didn't take long. I'm not surprised. Sales like that can be a bit strange though. My ME10 was on ebay came equipped much like that one, more so really John - |
