John Hinkley | 21/01/2016 09:27:13 |
![]() 1545 forum posts 484 photos | I originally buried this request in another thread and not surprisingly got no response, so I'm putting it here, as well. Work is progressing - slowly - on my automatic boring head, and I'm looking ahead to when I can start putting it together. However, I will need a small compression spring of specific dimensions. Although they are available from the likes of Lee Springs and Flexo, the cost of postage and packing/minimum order charge means I will have to pay in the region of £20 for 5 springs!. I was hoping that somebody can point me in the direction of a supplier who will send me one or two springs for the cost of a first class stamp and envelope. I've tried all the usual suspects but to no avail and an ebay search only throws up generic springs or boxes of assorted ones. The size I need is free length = 15 to 20mm, internal diameter = 4.1 to 4.5mm, solid length = 8.0mm, wire size 0.8 to 1.0mm. Flexo No. BM-1937-2M or Lee spring LC035C04S. Or, maybe you have something suitable in your workshop that I can have in exchange for some beer tokens? Thanks, John |
Brian H | 21/01/2016 09:36:29 |
![]() 2312 forum posts 112 photos | I've had similar problems in the past but a local spring manufacturer ,www.ashfield-springs.com have always been very helpful and supplied the odd spring as a free sample. Might be worth a try. |
Chris Evans 6 | 21/01/2016 09:57:44 |
![]() 2156 forum posts | I have had odd springs wound in Brum for the cost of a drink. I am 30 miles away so by the time I've travelled there and back not much saving but worth it to get the right spring. |
Clive Hartland | 21/01/2016 10:20:49 |
![]() 2929 forum posts 41 photos | I cannot find those springs in the Flexo cat. nor in the Lee cat. ? I was trying to check the full spec as I may have some. Both web sites say, not found. |
Circlip | 21/01/2016 11:13:43 |
1723 forum posts | Could always wind one 40mm long and cut it in half.
Regards Ian |
Bubble | 21/01/2016 11:15:21 |
75 forum posts 6 photos | Hello John Velocette clutch springs are 4.5 id, 1.1 wire diameter, 30 long can be shortened and will give your solid length as 8 turns are 20 mm free length Obtainable from Grove Classic Motorcycles (no connection) at 50p each plus postage Their reference is C12/4 (Venom,Viper, Mac etc) Jim |
peak4 | 21/01/2016 11:17:20 |
![]() 2207 forum posts 210 photos | Just been having a look through my boxes of springs, and didn't find anything suitable. However, I did spot a windscreen wiper arm tension spring about the correct size. How about a trip to your local car spares for one, and then stretch it suitably so make it a compression spring? |
Dave Daniels | 21/01/2016 11:49:18 |
87 forum posts | If you download the 'Polly' catalogue, there is a list of stainless spring stock in 12" lengths on P58 (?) Maybe something there suitable ? D.
Nigel Bennett | 21/01/2016 12:38:41 |
![]() 500 forum posts 31 photos | I'm typing this one-handed. The other one contains four springs, Lee LC-035C-04-S. If you will email me at Nigel at PK dot co (and another dot) uk, with your address, I'll put 'em in an envelope for you!
Nigel |
John Hinkley | 21/01/2016 13:14:54 |
![]() 1545 forum posts 484 photos | Thank you all for your replies and leads. I'll file them away for future reference. Nigel - you're a star! I'll email you with my address. Regards to all, John |
Tim Stevens | 21/01/2016 14:32:09 |
![]() 1779 forum posts 1 photos | Well done - so quickly that my offer to send him some wire to wind his own would be too late ... Regards, Tim |
