A small mistake.
Roger Provins 213/01/2016 16:22:33
344 forum posts
I made a small (75mm x 13mm) brass flywheel both faces to be identical but later noticed I had made a mistake. The rim on one side was 8mm wide but 7.95mm on the other. I was quite surprised that this small discrepancy was noticeable to me by eye considering you can't see both at once as they are on opposite faces of the wheel.
So how small difference can the human eye/brain discriminate?
Edited By Roger Provins 2 on 13/01/2016 16:51:39
Tim Stevens13/01/2016 16:41:00
1779 forum posts
It depends a lot on the circumstances, and it would be impossible to give a simple answer. We are generally very good at noticing pictures that are out of vertical, for example, but we are easily confused by 'optical illusions'. I like to think that I can distinguish a 1/4 Whit bolt head from a 7/16 UNC or M8, all of which differ by a few thou. But I expect I am also influenced by other clues at the same time.
The human finger-nail can detect a step of 0.0005 inches - is that a good start at an answer, I wonder?
Cheers, Tim
Brian Wood13/01/2016 16:42:03
2742 forum posts
39 photos
Hello Roger,
When I made my living industrially, part of my work was in viewing radiographic images of metallic structures for hidden faults and material defects.
It was always taken as a general case that two small inclusions, showing up as black on the X ray film, could be discriminated by the unaided eye satisfactorily when they were 0.010 inches [1/4 mm] apart. Magnifying aids helped a little but the definition and contrast then began to 'bleed' and deciding what constituted an edge became more difficult..
For the sort of difference you are talking about here with sharper edges, the eye is very good at spotting such differences and I would imagine as little as 0.005 inches might be detectable.
Neil Wyatt13/01/2016 19:02:24
19226 forum posts
749 photos
86 articles
Posted by Brian Wood on 13/01/2016 16:42:03:
We use 300 dpi for print media as the eye's resolving power is about 0.003" at normal reading distance. So to see two separate, tiny, dots they need to be at least 0.003" diameter and at least 0.003" apart - which is as near as spit your 0.010".
martin ranson 213/01/2016 19:16:58
135 forum posts
Roger ... an interesting question ... I assume you have dozens, or even maybe more than a hundred small twist drills in your "shed" ... take the range from 1.5mm up to about 2.5mm ... try putting the shanks of 2 nearly similar bits in line with each other and touching end to end ... with a good light and a light background you may surprise yourself ... you may be able to differentiate "one thou" difference in diameter.
martin
Roger Provins 213/01/2016 20:33:38
344 forum posts
Martin, indeed but in this case it isn't a case of physically comparing items while both are visible but rather holding one image in memory and comparing it with similar visible item. I'm sure it's something we all do subconsciously all the time. It just surprised me how small a difference can be noticed.
Roger
Edited By Roger Provins 2 on 13/01/2016 20:34:15
John Stevenson13/01/2016 20:47:44
5068 forum posts
I can prove this.
It's down to the power of the MKI eyeball.
Take centering a shaft on the mill for cutting a keyway as an example. Many people have many different ways and gadgets to do it but the MKi eyeball still comes off the best.
Take a good look at this picture.
This shaft was lined up exactly central by touching on both sides with a dowel pin and splitting the difference on a DRO so backlash wasn't an issue.
A milling cutter was just allowed to kiss the surface on the left, you can see the 'butterfly' is equal.
It was then moved along at the same zero setting, then moved sideways by one thou, 0.001" and a second mark made, the one on the right.
It's a mile out, so no need for fancy gizmo's, just touch down on the work, look at the spot and trust the MKI eyeball, unless you need to go to specsavers.
Simon Collier13/01/2016 20:52:00
525 forum posts
65 photos
I was after a bit of 1/4 stainless rod once, and a bloke at a fabricators gave me a length, but I told him I thought it was 6 mm. I measured it when I got home and it was 6 mm. I had no reference. I am continually amazed in the workshop what the eye can discriminate.
mark costello 113/01/2016 23:43:59
800 forum posts
16 photos
I can seem to tell Metric threads from Infernal as the pitch is not right for the diameter. (Am a Yank.)wink
Michael Gilligan14/01/2016 09:03:44
23121 forum posts
1360 photos
Roger,
As per Tim Stevens' first response: "It depends a lot on the circumstances"
It would be interesting if you could kindly post a matched-pair of photographs, so that we can see for ourselves.
Roger Provins 214/01/2016 11:17:29
344 forum posts
Michael,
Sorry it's too late I've corrected it now.
Roger
Gordon W14/01/2016 11:51:48
2011 forum posts
Females are better at detecting small errors, at least my wife is.
mark costello 114/01/2016 17:19:04
800 forum posts
16 photos
They remember them better too.
Neil Wyatt14/01/2016 17:34:20
19226 forum posts
749 photos
86 articles
Good at detecting unposted parcels by the front door blush
Chris Denton14/01/2016 21:23:32
275 forum posts
I can see a 0.04mm or greater run-out in the lathe by eyesight.
