pressure vessel testing
garrygun12/01/2016 22:02:53
70 forum posts
Hi guys, i have made several air vessels, 300mm x 34mm x 28mm wp 200 bar
i have tried to get thes tested but have been knocked back several times,
how do i go about getting them tested, certed, etc.?
any help apreciated, thanks Garry.
Jeff Dayman12/01/2016 22:10:18
2356 forum posts
47 photos
For what purpose are these vessels?
What standard do they comply with?
Who did you enquire with?
garrygun12/01/2016 23:07:41
70 forum posts
Posted by Jeff Dayman on 12/01/2016 22:10:18:
For what purpose are these vessels? air rifles
What standard do they comply with? i dont know
Who did you enquire with? company in brum,seen vessels but got bit funny about a/rifles,
some refused as werent profitable enough for them, others couldnt & wouldnt help with info.
this is why i am posing question here,
shaun hill13/01/2016 00:07:16
18 forum posts
Garry, if your cylinder holds under 500cc of air,under current uk laws it does not require testing, i have been making pcp airguns over 25 years,but i test each of my cylinders to a third above the working pressure,.i can assure you the vast majority of british pcps manufacturers dont test each rifle.
When i made my first cylinder i hydrostatically tested it, then i took it to Lloyds british, and got them to test it, to make sure what i was doing was safe and correct.
Rufus Roughcut13/01/2016 21:59:06
83 forum posts
20 photos
Hi Garry
Well cleared Shaun
In a former life I did lots of hydraulic as a norm 1.5 x wp (hydrostatic at various temperatures) testing on hp steam lines on power stations, refineries etc, however over the years some less than safe activities involving pneumatic testing world wide has caused a great deal of fear amongst companies, due to the explosive forces should ruptures occur, I myself have witnessed poorly methodized companies have some quite catastrophic equipment failures where only by the grace of god no serious injuries or fatalities have resulted, however a search on the net will show you that not all companies are so lucky and I'm sure your aware of ballistics and it's affects on people, the US military tent to undertake tests in with the vessel in large tank of water to limit the shock wave when failures occur.
The fittings, gauges and appropriate rated hoses can be attained from hydraulic suppliers who would probably make you up test rig which would be more than adequate for self testing, however the cert is a bit more complexed and would need to be witnessed by a competent person familiar with testing processes and acceptable outcomes and usage of test item.
Clive Hartland13/01/2016 22:24:41
2929 forum posts
41 photos
If for PCP air rifles why not buy from air rifle makers as they have made bottles ready?
garrygun13/01/2016 22:25:46
70 forum posts
thanks guys for your replies,
i have made and tested these cylinders up to 400bar over night hydraulicaly and 300 bar pneumaticaly without failure
i think that would be adaquate, i still have one on my a/rifle for over a year now i would say that is a good test,
several people have asked me if i would supply them one but i was concerned about the laws.
garrygun13/01/2016 22:38:36
70 forum posts
Posted by Clive Hartland on 13/01/2016 22:24:41:
If for PCP air rifles why not buy from air rifle makers as they have made bottles ready?the
the idea of making my own is its cheaper lighter and i think better, OMs too heavy, after market cyls too expensive, i have the equipment why not make them .
mick H14/01/2016 08:35:24
795 forum posts
34 photos
Posted by shaun hill on 13/01/2016 00:07:16:
Shaun....I was interested to read the above quoted post. Does this rule apply to cylinders holding air only or does it apply to any pressure vessel? Do you happen to know the legislation that makes this stipulation?
Mick
David Jupp14/01/2016 09:30:43
978 forum posts
26 photos
It seems likely that in the UK the Pressure Equipment Regulations (UK enactment of the Pressure Equipment Directive) would apply (if supplying these for beyond your own use).
The classification of the vessel described by the OP when used for compressed air would be 'Sound Engineering Practice' (the lowest category) - there is no specific requirement to involve any third party in review/witnessing of either design or manufacture/testing for SEP items.
There are requirements regarding marking, and provision of adequate instructions.
A Technical File should be prepared to cover the design, materials used, inspection & test - this would be a significant part of the manufacturer's defence if an incident did occur.
PED generally expects a pressure test, but does accept (justified) alternatives.
Don't forget to consider the potential for fatigue failure in this application.
Russell Eberhardt14/01/2016 09:47:00
2785 forum posts
87 photos
It might be worth having a look at **LINK**
Russell.
David Jupp14/01/2016 09:51:20
978 forum posts
26 photos
Russell - The Simple Pressure Vessel Directive relates to series produced welded vessels for use up to 30 bar, so is not applicable in this particular case.
Edited By David Jupp on 14/01/2016 09:52:03
duncan webster14/01/2016 10:11:04
5307 forum posts
83 photos
As this pressure vessel is intended to be part of a weapon, it is exempt from PER. Still wants testing tho'
David Jupp14/01/2016 11:16:43
978 forum posts
26 photos
The exemption from PER is for items specifically designed and constructed for military purposes.
I'm honestly not clear if weapons automatically fall under this exemption, or if the exemption only covers use within the armed forces. Happy to be enlightened by those with specific knowledge.
Either way the approach required by PER would be a good place to start and isn't particularly onerous. I suspect materials certification/traceability might well be a stumbling block for some though.
duncan webster14/01/2016 14:03:14
5307 forum posts
83 photos
I've just read schedule 1 which deals with exemptions, it doesn't mention military, just weapons. It might have been intended for the military, but it doesn't say so. The regulations for vessels of less than 250 bar.litres also differ from larger ones. This vessel is 36 bar.litres. It's all very clearly laid out in
another excellent publication from the HSE
David Jupp14/01/2016 14:15:36
978 forum posts
26 photos
We are obviously looking at different legislation - PER and PSSR.
Martin Connelly14/01/2016 20:17:20
2549 forum posts
235 photos
I think pressure vessels or items that are pressurised under normal operation but are not covered by the PED due to exemptions are usually covered by other regulations. Boilers and gas turbine casings are examples.
Martin
garrygun14/01/2016 21:47:14
70 forum posts
thanks for all your replys guys. ive been checking the links& reading up,
as you can see it is a bit complicated and confusing, rules regulations conflicting, this is the problem, finding which rules apply to me.
Cheers Garry.
mick H15/01/2016 09:53:25
795 forum posts
34 photos
This is a very confusing area. My interest is as a small steam loco maker. Reference is still being made to the "3Bar/litre" rule which as far as I am able to establish,was revoked by the PSSR Regs 2000. This piece of legislation is most uncompromising and even Mamod models are caught by it. I did read somewhere that in view of the difficulties this would cause an exception was to be made for small models which would formerly have been included in the 3Bar/litre catchment. Has anyone anything definitive to add to this?
Mick
Michael Gilligan15/01/2016 10:11:58
23121 forum posts
1360 photos
Mick,
I am not qualified to advise, but: The HSE guidance contains this fairly explicit statement:
  1. Under the Pressure Systems Safety Regulations 2000, a written scheme of examination is required for most pressure systems. Exempted systems are listed in the Regulations. Generally speaking, only very small systems are exempted.
  2.
Edit: Free download of PSSR 2000 available here.
Edited By Michael Gilligan on 15/01/2016 10:12:58
Edited By Michael Gilligan on 15/01/2016 10:25:07
