lathe chuck key hex
sourcing lathe chuck key
Deleted Account18/12/2015 11:30:54
45 forum posts
Hi,
Well as you know square lathe chuck keys are cheap enough (probably in quality too!) and readily available but I need an 1/2" hexagonal lathe chuck key and I cannot find one at a reasonable price.
Checked the classified here. No luck!
Probably somebody here has one but that does not seem reasonable to ask - I've put an ad on the classified anyway.
Does anybody know were I could buy one?
John Rudd18/12/2015 11:34:40
1479 forum posts
I guess making one from a 1/2" hex af allen key is out of the question?
jann west18/12/2015 11:47:04
106 forum posts
1/2" hex nut or bolt head on a lever?
Deleted Account18/12/2015 11:59:36
45 forum posts
Posted by John Rudd on 18/12/2015 11:34:40:
well its more that it adds value to the chucck by being complete rather than anything prcatical
Ignatz18/12/2015 12:25:57
173 forum posts
102 photos
Like John Rudd I would think that making a fairly nice looking chuck key would be the answer.
I would opt to turn the body from something like 3/4" or 1" stock,with a long chamfer at the nose end, drill it out for a section of 1/2" hex allen key which you would then fix either by a quick spot weld or by brazing. Add on a simple cross bar at the back end and Bob's your uncle.
And as for adding value, you could always polish the end result to a mirror finish. wink
John Rudd18/12/2015 12:46:11
1479 forum posts
Posted by one pound on 18/12/2015 11:59:36:
So it could be made from anything, but needs to enhance the chuck and doesn't have to be practical but also needs to be cheap?
Sorry cant help....I'd have machined a hex section on the mill, cross drilled, fitted a tommy bar job done....
Deleted Account18/12/2015 13:36:23
45 forum posts
I wonder why I put a sourcing lathe chuck key when I could have posted a how to make one post
oh because I know how to make one. cheeky
Deleted Account18/12/2015 13:44:12
45 forum posts
Posted by John Rudd on 18/12/2015 12:46:11:
Why is what I said taken out of context?
" doesn't have to be practical " why would it not be practical, how would it work? I never said that.
"but needs to enhance the chuck " no key can enhance a chuck unless its imbued with magic
"needs to be cheap?" I said reasonable
Edited By one pound on 18/12/2015 13:45:00
Tim Stevens18/12/2015 14:16:56
1779 forum posts
If you have a socket set (of spanners) then you could add a 1/2 hex driver.
eg: **LINK**
Depending on where you are, this might come within your 'reasonable' definition.
But then, I would have thought a standard ordinary 1/2 hex Allen key was reasonable, too.
Regards, Tim
Tim Stevens18/12/2015 14:21:53
1779 forum posts
Or even a 1/2" hex socket (3/8 or 1/2 square drive) and a short length cut from an Allen key?
Tim
Michael Gilligan18/12/2015 14:30:28
23121 forum posts
1360 photos
So that we understand your motives:
... Is this just to 'restore' a chuck which you plan to sell ?
Martin Connelly18/12/2015 14:32:30
2549 forum posts
235 photos
Can you get a chuck key with a square over 14.66mm across the flats and machine or grind it down to 1/2" hex?
Martin
Deleted Account18/12/2015 15:21:57
45 forum posts
Posted by Tim Stevens on 18/12/2015 14:16:56:
eg: **LINK**
Regards, Tim
I'm using a Britool version of what you suggest at the moment.
Deleted Account18/12/2015 18:44:11
45 forum posts
Text removed by Moderator
I appreciate all the efforts of people suggesting to make one what I dont like is the tongue in cheek derision thats crept in.
In summary there are none available for purchase.
Edited By one pound on 18/12/2015 18:48:05
Edited By JasonB on 20/12/2015 10:10:45
Chris Evans 618/12/2015 20:52:56
2156 forum posts
If you are close enough to me I will make you one. No charge.
Deleted Account18/12/2015 20:56:11
45 forum posts
Posted by Chris Evans 6 on 18/12/2015 20:52:56:
That is very kind of you to offer. I'm Royston.
V8Eng19/12/2015 20:49:15
1826 forum posts
Rotagrip stock metric and imperial hex chuck keys in a range of sizes.
Edited By V8Eng on 19/12/2015 20:52:33
Edited By V8Eng on 19/12/2015 20:52:53
JasonB19/12/2015 20:55:02
I'm locking this thread, Have removed several posts and some text from others.
Edited By JasonB on 20/12/2015 10:13:19
This thread is closed.
